The Artix-7 FPGA is optimized for high performance logic, and offers more capacity, higher performance, and more resources than earlier designs. Artix-7 100T features include:[li]15,850 logic slices, each with four 6-input LUTs and 8 flip-flops[/li][li]4,860 Kbits of fast block RAM[/li][li]Six clock management tiles, each with phase-locked loop (PLL)[/li][li]240 DSP slices[/li][li]Internal clock speeds exceeding 450MHz[/li][li]On-chip analog-to-digital converter (XADC)[/li] The Nexys4 DDR also offers an improved collection of ports and peripherals, including: | [li]16 user switches[/li][li]USB-UART Bridge[/li][li]12-bit VGA output[/li][li]3-axis accelerometer[/li][li]128MiB DDR2[/li][li]Pmod for XADC signals[/li] | [li]16 user LEDs[/li][li]Two tri-color LEDs[/li][li]PWM audio output[/li][li]Temperature sensor[/li][li]Serial Flash[/li][li]Digilent USB-JTAG port for FPGA programming and communication[/li] | [li]Two 4-digit 7-segment displays[/li][li]Micro SD card connector[/li][li]PDM microphone[/li][li]10/100 Ethernet PHY[/li][li]Four Pmod ports[/li][li]USB HID Host for mice, keyboards and memory sticks[/li] | [tr][/tr]
板子实物图:
购买主题
本主题需向作者支付 2 枚金币 才能浏览
