查看: 1650|回复: 2
[PCB封装] ADV7619 Dual Port, Xpressview,  3 GHz HDMI Receiver
社区居民原创达人终身成就奖
发表于 2015-3-6 20:00:27 | 显示全部楼层 |阅读模式
FEATURES
High-Definition Multimedia Interface (HDMI®) 1.4a features
supported
All mandatory and additional 3D video formats supported
Extended colorimetry, including sYCC601, Adobe® RGB,
Adobe YCC601, xvYCC extended gamut color
CEC 1.4-compatible
HDMI 3 GHz receiver
297 MHz maximum TMDS clock frequency
Supports 4k × 2k resolution
Xpressview fast switching of HDMI ports
Up to 48-bit Deep Color with 36-/30-/24-bit support
High-bandwidth Digital Content Protection (HDCP) 1.4
support with internal HDCP keys
HDCP repeater support: up to 127 KSVs supported
Integrated CEC controller
Programmable HDMI equalizer
5 V detect and Hot Plug assert for each HDMI port
Audio support
Audio support including high bit rate (HBR) and
Direct Stream Digital (DSD)
S/PDIF (IEC 60958-compatible) digital audio support
Supports up to four I
2S outputs
Advanced audio mute feature
Dedicated, flexible audio output port
Super Audio CD® (SACD) with DSD output interface
HBR audio
Dolby® TrueHD
DTS-HD Master Audio™
General
Interrupt controller with 2 interrupt outputs
Standard identification (STDI) circuit
Highly flexible, 48-bit pixel output interface
36-bit output for resolutions up to 1080p Deep Color
2 × 24-bit pass-through outputs for HDMI formats
greater than 2.25 GHz
Internal EDID RAM
Any-to-any, 3 × 3 color space conversion (CSC) matrix
128-lead TQFP_EP, 14 mm × 14 mm package
APPLICATIONS
Projectors
Video conferencing
HDTV
AVR, HTiB
Soundbar
Video switch
ADV7619.pdf (556 KB, 下载次数: 0)
终身成就奖社区居民忠实会员社区劳模最爱沙发原创达人优秀斑竹奖
发表于 2015-3-6 23:15:14 | 显示全部楼层
社区居民忠实会员社区劳模优秀斑竹奖终身成就奖最爱沙发原创达人
发表于 2015-3-7 08:47:10 | 显示全部楼层
