- /* //file -> drivers/leds/leds-gpio.c
- * LEDs driver for GPIOs
- * author by jiangdou qq:344283973
- * Copyright (C) 2007 8D Technologies inc.
- * Raphael Assenat <raph@8d.com>
- * Copyright (C) 2008 Freescale Semiconductor, Inc.
- * This program is free software; you can redistribute it and/or modify
- * it under the terms of the GNU General Public License version 2 as
- * published by the Free Software Foundation.
- #include <linux/kernel.h>
- #include <linux/init.h>
- #include <linux/platform_device.h>
- #include <linux/leds.h>
- #include <linux/of_platform.h>
- #include <linux/of_gpio.h>
- #include <linux/slab.h>
- #include <linux/workqueue.h>
- #include <asm/gpio.h>
- //###############add by jiangdou ################
- //#define RK30_PIN1_PA5 197
- static struct gpio_led gpio_leds = {
- .name = "HB_A5",
- .default_trigger = "heartbeat",
- .gpio = RK30_PIN1_PA5,//modify for board LED gpio
- .active_low = 0,//1,//初始化为0
- .default_state = LEDS_GPIO_DEFSTATE_OFF,
- static struct gpio_led_platform_data gpio_led_info = {
- .leds = &gpio_leds,
- .num_leds = 1,//ARRAY_SIZE(gpio_leds),
- static struct platform_device leds_gpio = {
- .name = "leds-gpio",
- .id = -1,
- .dev = {
- .platform_data = &gpio_led_info,
- //##################add end#############################
- struct gpio_led_data {
- struct led_classdev cdev;
- unsigned gpio;
- struct work_struct work;
- u8 new_level;
- u8 can_sleep;
- u8 active_low;
- u8 blinking;
- int (*platform_gpio_blink_set)(unsigned gpio, int state,
- unsigned long *delay_on, unsigned long *delay_off);
- static void gpio_led_work(struct work_struct *work)
- struct gpio_led_data *led_dat =
- container_of(work, struct gpio_led_data, work);
- if (led_dat->blinking) {
- led_dat->platform_gpio_blink_set(led_dat->gpio,
- led_dat->new_level,
- NULL, NULL);
- led_dat->blinking = 0;
- } else
- gpio_set_value_cansleep(led_dat->gpio, led_dat->new_level);
- static void gpio_led_set(struct led_classdev *led_cdev,
- enum led_brightness value)
- container_of(led_cdev, struct gpio_led_data, cdev);
- int level;
- if (value == LED_OFF)
- level = 0;
- else
- level = 1;
- if (led_dat->active_low)
- level = !level;
- /* Setting GPIOs with I2C/etc requires a task context, and we don't
- * seem to have a reliable way to know if we're already in one; so
- * let's just assume the worst.
- if (led_dat->can_sleep) {
- led_dat->new_level = level;
- schedule_work(&led_dat->work);
- } else {
- led_dat->platform_gpio_blink_set(led_dat->gpio, level,
- NULL, NULL);
- } else
- gpio_set_value(led_dat->gpio, level);
- static int gpio_blink_set(struct led_classdev *led_cdev,
- led_dat->blinking = 1;
- return led_dat->platform_gpio_blink_set(led_dat->gpio, GPIO_LED_BLINK,
- delay_on, delay_off);
- static int __devinit create_gpio_led(const struct gpio_led *template,
- struct gpio_led_data *led_dat, struct device *parent,
- int (*blink_set)(unsigned, int, unsigned long *, unsigned long *))
- int ret, state;
- led_dat->gpio = -1;
- /* skip leds that aren't available */
- if (!gpio_is_valid(template->gpio)) {
- printk(KERN_INFO "Skipping unavailable LED gpio %d (%s)\n",
- template->gpio, template->name);
- return 0;
- ret = gpio_request(template->gpio, template->name);
- if (ret < 0)
- return ret;
- led_dat->cdev.name = template->name;
- led_dat->cdev.default_trigger = template->default_trigger;
- led_dat->gpio = template->gpio;
- led_dat->can_sleep = gpio_cansleep(template->gpio);
- led_dat->active_low = template->active_low;
- if (blink_set) {
- led_dat->platform_gpio_blink_set = blink_set;
- led_dat->cdev.blink_set = gpio_blink_set;
- led_dat->cdev.brightness_set = gpio_led_set;
- if (template->default_state == LEDS_GPIO_DEFSTATE_KEEP)
- state = !!gpio_get_value(led_dat->gpio) ^ led_dat->active_low;
- else
- state = (template->default_state == LEDS_GPIO_DEFSTATE_ON);
- led_dat->cdev.brightness = state ? LED_FULL : LED_OFF;
- if (!template->retain_state_suspended)
- led_dat->cdev.flags |= LED_CORE_SUSPENDRESUME;
- ret = gpio_direction_output(led_dat->gpio, led_dat->active_low ^ state);
- if (ret < 0)
- goto err;
- INIT_WORK(&led_dat->work, gpio_led_work);
- ret = led_classdev_register(parent, &led_dat->cdev);
- if (ret < 0)
- goto err;
- return 0;
- err:
- gpio_free(led_dat->gpio);
- return ret;
- static void delete_gpio_led(struct gpio_led_data *led)
- if (!gpio_is_valid(led->gpio))
- return;
- led_classdev_unregister(&led->cdev);
- cancel_work_sync(&led->work);
- gpio_free(led->gpio);
- struct gpio_leds_priv {
- int num_leds;
- struct gpio_led_data leds[];
- static inline int sizeof_gpio_leds_priv(int num_leds)
- return sizeof(struct gpio_leds_priv) +
- (sizeof(struct gpio_led_data) * num_leds);
- /* Code to create from OpenFirmware platform devices */
- #ifdef CONFIG_LEDS_GPIO_OF
- static struct gpio_leds_priv * __devinit gpio_leds_create_of(struct platform_device *pdev)
- struct device_node *np = pdev->dev.of_node, *child;
- struct gpio_leds_priv *priv;
- int count = 0, ret;
- /* count LEDs in this device, so we know how much to allocate */
- for_each_child_of_node(np, child)
- count++;
- if (!count)
- return NULL;
- priv = kzalloc(sizeof_gpio_leds_priv(count), GFP_KERNEL);
- if (!priv)
- return NULL;
- for_each_child_of_node(np, child) {
- struct gpio_led led = {};
- enum of_gpio_flags flags;
- const char *state;
- led.gpio = of_get_gpio_flags(child, 0, &flags);
- led.active_low = flags & OF_GPIO_ACTIVE_LOW;
- led.name = of_get_property(child, "label", NULL) ? : child->name;
- led.default_trigger =
- of_get_property(child, "linux,default-trigger", NULL);
- state = of_get_property(child, "default-state", NULL);
- if (state) {
- if (!strcmp(state, "keep"))
- led.default_state = LEDS_GPIO_DEFSTATE_KEEP;
- else if (!strcmp(state, "on"))
- led.default_state = LEDS_GPIO_DEFSTATE_ON;
- else
- led.default_state = LEDS_GPIO_DEFSTATE_OFF;
- ret = create_gpio_led(&led, &priv->leds[priv->num_leds++],
- &pdev->dev, NULL);
- if (ret < 0) {
- of_node_put(child);
- goto err;
- return priv;
- err:
- for (count = priv->num_leds - 2; count >= 0; count--)
- delete_gpio_led(&priv->leds[count]);
- kfree(priv);
- return NULL;
- static const struct of_device_id of_gpio_leds_match[] = {
- { .compatible = "gpio-leds", },
- #else
- return NULL;
- #define of_gpio_leds_match NULL
- #endif
- static int __devinit gpio_led_probe(struct platform_device *pdev)
- struct gpio_led_platform_data *pdata = pdev->dev.platform_data;
- int i, ret = 0;
- //gpio_led_info;
- if (pdata && pdata->num_leds) {
- priv = kzalloc(sizeof_gpio_leds_priv(pdata->num_leds),
- GFP_KERNEL);
- if (!priv)
- return -ENOMEM;
- priv->num_leds = pdata->num_leds;
- for (i = 0; i < priv->num_leds; i++) {
- ret = create_gpio_led(&pdata->leds[i],
- &priv->leds[i],
- &pdev->dev, pdata->gpio_blink_set);
- if (ret < 0) {
- /* On failure: unwind the led creations */
- for (i = i - 1; i >= 0; i--)
- delete_gpio_led(&priv->leds[i]);
- kfree(priv);
- return ret;
- } else {
- priv = gpio_leds_create_of(pdev);
- if (!priv)
- return -ENODEV;
- platform_set_drvdata(pdev, priv);
- return 0;
- static int __devexit gpio_led_remove(struct platform_device *pdev)
- struct gpio_leds_priv *priv = dev_get_drvdata(&pdev->dev);
- int i;
- dev_set_drvdata(&pdev->dev, NULL);
- kfree(priv);
- return 0;
- static struct platform_driver gpio_led_driver = {
- .probe = gpio_led_probe,
- .remove = __devexit_p(gpio_led_remove),
- .driver = {
- .owner = THIS_MODULE,
- .of_match_table = of_gpio_leds_match,
- struct platform_device *pdev;
- MODULE_ALIAS("platform:leds-gpio");
- static int __init gpio_led_init(void)
- //**** add by jiangou ******
- int err = 0;
- pdev = platform_device_alloc("leds-gpio", -1);
- if (!pdev)
- return err;
- err = platform_device_add_data(pdev, &gpio_led_info,
- sizeof(gpio_led_info));
- if (err)
- return err;
- err = platform_device_add(pdev);
- if (err)
- return err;
- //**** add end by jiangou ******
- return platform_driver_register(&gpio_led_driver);
- static void __exit gpio_led_exit(void)
- platform_driver_unregister(&gpio_led_driver);
- module_init(gpio_led_init);
- module_exit(gpio_led_exit);
- MODULE_AUTHOR("Raphael Assenat <raph@8d.com>, Trent Piepho <tpiepho@freescale.com>");
- MODULE_DESCRIPTION("GPIO LED driver");
- MODULE_LICENSE("GPL");
复制代码 |
