MK3360车载导航核心板,2G-FLASH,2G-RAM,安卓、WINCE通吃
MT3360-CORE
MTK3360 CORE.zip
(1.07 MB, 下载次数: 101)
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
Name | PCB Decal | Value | Part Type | CE1 | 3216 | 47uF/6.3v | CAP_EC | CE3 | 3216 | 47uF/6.3v | CAP_EC | CE4 | 3216 | 47uF/6.3v | CAP_EC | D1 | SOT23/SMD | BAT54C | DIODE_SMD_BAT54C | D4 | 0402-D | 1N4148WT | DIODE_SMD | FB1 | BEAD/SMD/0603 | BLM18AG601SN1 | L0402 | FB2 | C0402/SMD | BLM18AG601SN1 | INDUCTOR | H3 | H3.5MM | TEST POINT DIP1.0 | TEST_POINT_SMD0.6 | H4 | H3.5MM | TEST POINT DIP1.0 | TEST_POINT_SMD0.6 | HA1 | FPC36-0.5-P | FPC36-0.5 | HEADER_24_SMD0_2.5_TOP | L2 | SFB0603 | FB/BLM15PG121SN1 | BEAD | L4 | L/IND/SMD/LQH6PP_2424 | 2.2uH/2A | INDUCTOR | L7 | PANVGG3X3 | 4.7UH 1A | INDUCTOR | L8 | SFB0603 | FB/BLM18PG121SN1 | BEAD | L9 | SFB0603 | FB/BLM18PG121SN1 | BEAD | L11 | BEAD/SMD/0603 | FB/BLM18PG121SN1 | BEAD | L12 | BEAD/SMD/0402 | 1.8uH/LQM18NN1R8K00 | INDUCTOR | L13 | BEAD/SMD/0402 | 1.8uH/LQM18NN1R8K00 | INDUCTOR | L14 | BEAD/SMD/0402 | 1.8uH/LQM18NN1R8K00 | INDUCTOR | L15 | BEAD/SMD/0402 | 1.8uH/LQM18NN1R8K00 | INDUCTOR | L16 | BEAD/SMD/0603 | FB/BLM18PG121SN1 | BEAD | L17 | BEAD/SMD/0603 | FB/BLM18PG121SN1 | BEAD | L18 | BEAD/SMD/0402 | NC | INDUCTOR | L19 | BEAD/SMD/0402 | NC | INDUCTOR | L20 | BEAD/SMD/0402 | BLM15AG601SN1 | INDUCTOR | L21 | BEAD/SMD/0402 | 27nH/LQW15AN27N | INDUCTOR | L22 | BEAD/SMD/0402 | 5.6nH/LQW15AN5N6 | BEAD | L23 | BEAD/SMD/0402 | 6.8nH/LQW15AN6N8 | BEAD | L24 | L/IND/SMD/0805 | LQM21PN4R7NGR | INDUCTOR | LED2 | LED/SMD/0603 | RED LED | LED_1 | PAD1 | FPAD | TP | TP | PAD7 | FPAD | TP | TP | PAD8 | FPAD | TP | TP | PAD15 | FPAD | TP | TP | U1 | SOT23-5/SMD/P0.95/GMT | QX6219L-40F | G9091-330T11U | U2 | SOT23-5/SMD/P0.95/GMT | SGM2019-2.8 | G9091-330T11U | U3 | SOT23-8 | MP2144 | MP2144 | U4 | SOT-23-5 | MP2104/GM8008 | S-80825ALNP_0 | U5 | SOT23-5/SMD/P0.95/GMT | QX6219L33F | G9091-330T11U | U6 | SOT23/SMD | G691L293T73 | G690L | U7 | SOT23-5/SMD/P0.95/GMT | QX6219L12F | G9091-330T11U | U8 | FBGA96/SMD/P0.8/MICRON | H5TQ1G63DFR-H9C | FBGA96/SMD/P0.8/MICRON | U9 | MT3360/PBGA500/P1.0/B0.45/27X27 | MT3360 | MT3360/PBGA500/P1.0/B0.45/27X27 | U10 | FBGA96/SMD/P0.8/MICRON | H5TQ1G63DFR-H9C | FBGA96/SMD/P0.8/MICRON | U11 | TSOP48/SMD | K9F2G08U0C | TSOP48/SMD | U12 | SC70/5P/SMD | FMS6141S5X | FMS6141 | U13 | CON154_1.27MM-AQQ | MODULE OUTLINE | MODULE_OUTLINE_MTK3360 | U14 | FPC20-0.5-V-HR | CAMMERA | FPC20-0.5-V-HR | U15 | SOT23-5A | EMP8042-33VF05NRR | RT9179 | U16 | FPC30-0.5-V-HR | DTV | FPC30-0.5-V-HR | U17 | BPF_6611 | RFBPB2012060AMST61 | BPF_6611 | U18 | MT6612/QFN40/P0.4/5X5 | MT6612_QFN40 | MT6612/QFN40/P0.4/5X5 | U19 | SAW/SMD/1.05X1.35 | SAFEB1G57KE0F00 | SAFEB1G57KA0F00 | U20 | DFN6/SMD/DALLAS/MAX2659 | BGU7005/BGU7007 | NJG1107HB | U21 | MT3336/MQFN48/SMD/P0.4/6X6 | MT3336 QFN (48 Pins, 0.4mm pitch) | MT3301-140_SMD_PBGA-140_0 | Y4 | SSP-T7 | 32.768KHZ | Y_32.768KHZ-MC-146 | Y5 | SMD4 | 27.000MHZ | Y_12MHZ-4025 | Y6 | OSC3225 | IT3205CE/26MHZ+/-0.5ppm (TX5070) | OSC3225 | Y7 | SSP-T7 | 32.768KHZ | Y_32.768KHZ-MC-146 |
评分
查看全部评分
