/******************** (C) COPYRIGHT 2007 STMicroelectronics ********************
* File Name : main.c
* Author : MCD Application Team
* Date First Issued : 05/21/2007
* Description : Main program body
* History:
* 05/21/2007: V0.3
* THE PRESENT SOFTWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH SOFTWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
#include "stdio.h"
#include "stm32f10x_usart.h"
/* Local includes ------------------------------------------------------------*/
/* Private typedef -----------------------------------------------------------*/
typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus;
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
vu32 ret; /* for return of the interrupt handling */
volatile TestStatus TestRx;
ErrorStatus HSEStartUpStatus;
/* Private functions ---------------------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
TestStatus CAN_Polling(void);
TestStatus CAN_Interrupt(void);
void SetupUART (void) ;
void SetupClock (void);
* Function Name : main
* Input : None
* Output : None
* Return : None
int main(void)
#ifdef DEBUG
debug();
#endif
/* System Clocks Configuration */
RCC_Configuration();
/* NVIC Configuration */
NVIC_Configuration();
/* GPIO ports pins Configuration */
GPIO_Configuration();
/* CAN transmit at 100Kb/s and receive by polling in loopback mode -1*/
/* CAN transmit at 100Kb/s and receive by polling in normal mode -2*/
TestRx = CAN_Polling();
if (TestRx == FAILED)
/* Turn on led connected to PC.08 pin (LD3) */
GPIO_SetBits(GPIOC, GPIO_Pin_8);
else
/* Turn on led connected to PC.06 pin (LD1) */
GPIO_SetBits(GPIOC, GPIO_Pin_6);
/* CAN transmit at 500Kb/s and receive by interrupt in loopback mode*/
TestRx = CAN_Interrupt();
/* Turn on led connected to PC.09 pin (LD4) */
GPIO_SetBits(GPIOC, GPIO_Pin_9);
else
/* Turn on led connected to PC.07 pin (LD2) */
GPIO_SetBits(GPIOC, GPIO_Pin_7);
while(1)
* Function Name : RCC_Configuration
* Description : Configures the different system clocks.
* Input : None
* Output : None
* Return : None
/* RCC system reset(for debug purpose) */
RCC_DeInit();
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
/* HCLK = SYSCLK */
RCC_HCLKConfig(RCC_SYSCLK_Div1);
/* PCLK2 = HCLK */
RCC_PCLK2Config(RCC_HCLK_Div1);
/* PCLK1 = HCLK/2 */
RCC_PCLK1Config(RCC_HCLK_Div2);
/* Enable Prefetch Buffer */
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* Select HSE as system clock source */
RCC_SYSCLKConfig(RCC_SYSCLKSource_HSE);
/* Wait till HSE is used as system clock source */
while(RCC_GetSYSCLKSource() != 0x04)
/* GPIOA and GPIOC clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOC, ENABLE);
/* CAN Periph clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN, ENABLE);
* Function Name : GPIO_Configuration
* Description : Configures the different GPIO ports.
* Input : None
* Output : None
* Return : None
GPIO_InitTypeDef GPIO_InitStructure;
/* Configure PC.06, PC.07, PC.08 and PC.09 as Output push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOC, &GPIO_InitStructure);
/* Configure CAN pin: RX */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_Init(GPIOD, &GPIO_InitStructure);
/* Configure CAN pin: TX */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
* Function Name : NVIC_Configuration
* Description : Configures the NVIC and Vector Table base address.
* Input : None
* Output : None
* Return : None
NVIC_InitTypeDef NVIC_InitStructure;
#ifdef VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
/* enabling interrupt */
NVIC_InitStructure.NVIC_IRQChannel=USB_LP_CAN_RX0_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
* Function Name : CAN_Polling
* Description : Configures the CAN and transmit and receive by polling
* Input : None
* Output : None
* Return : PASSED if the reception is well done, FAILED in other case
CAN_InitTypeDef CAN_InitStructure;
CAN_FilterInitTypeDef CAN_FilterInitStructure;
CanTxMsg TxMessage;
CanRxMsg RxMessage;
u16 i=0;
u8 TransmitMailbox;
/* CAN register init */
CAN_DeInit();
CAN_StructInit(&CAN_InitStructure);
/* CAN cell init */
CAN_InitStructure.CAN_TTCM=ENABLE;
// CAN_InitStructure.CAN_TTCM=DISABLE;
// CAN_InitStructure.CAN_ABOM=DISABLE;
CAN_InitStructure.CAN_ABOM=ENABLE;
CAN_InitStructure.CAN_AWUM=ENABLE;
//CAN_InitStructure.CAN_AWUM=DISABLE;
CAN_InitStructure.CAN_NART=DISABLE;
CAN_InitStructure.CAN_RFLM=DISABLE;
CAN_InitStructure.CAN_TXFP=ENABLE;
// CAN_InitStructure.CAN_TXFP=DISABLE;
CAN_InitStructure.CAN_Mode=CAN_Mode_LoopBack;
CAN_InitStructure.CAN_SJW=CAN_SJW_1tq;
CAN_InitStructure.CAN_BS1=CAN_BS1_8tq;
CAN_InitStructure.CAN_BS2=CAN_BS2_7tq;
CAN_InitStructure.CAN_Prescaler=5;
CAN_Init(&CAN_InitStructure);
/* CAN filter init */
CAN_FilterInitStructure.CAN_FilterNumber=0;
CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000;
CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
CAN_FilterInitStructure.CAN_FilterFIFOAssignment=0;
CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
CAN_FilterInit(&CAN_FilterInitStructure);
/* transmit */
TxMessage.StdId=0x11;
TxMessage.RTR=CAN_RTR_DATA;
TxMessage.IDE=CAN_ID_STD;
// TxMessage.DLC=8;
TxMessage.DLC=2;
TxMessage.Data[0]=0xAA;
TxMessage.Data[1]=0xAA;
TransmitMailbox=CAN_Transmit(&TxMessage);
i=0;
// while((CAN_TransmitStatus(TransmitMailbox)!=CANTXOK)&&(i!=0xFF))
i++;
i=0;
while((CAN_MessagePending(CAN_FIFO0)<1)&&(i!=0xFF))
i++;
/* receive */
RxMessage.StdId=0x00;
RxMessage.IDE=CAN_ID_STD;
RxMessage.DLC=0;
RxMessage.Data[0]=0x00;
RxMessage.Data[1]=0x00;
CAN_Receive(CAN_FIFO0, &RxMessage);
if (RxMessage.StdId!=0x11) return FAILED;
if (RxMessage.IDE!=CAN_ID_STD) return FAILED;
if (RxMessage.DLC!=2) return FAILED;
if ((RxMessage.Data[0]<<8|RxMessage.Data[1])!=0xAAAA) return FAILED;
return PASSED; /* Test Passed */
* Function Name : CAN_Interrupt
* Description : Configures the CAN and transmit and receive by interruption
* Input : None
* Output : None
CanTxMsg TxMessage;
u8 i=0;
CAN_DeInit();
/* CAN cell init */
CAN_InitStructure.CAN_Prescaler=1;
CAN_FilterInitStructure.CAN_FilterNumber=1;
CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_FIFO0;
/* CAN FIFO0 message pending interrupt enable */
CAN_ITConfig(CAN_IT_FMP0, ENABLE);
/* transmit 1 message */
TxMessage.StdId=0x12;
TxMessage.ExtId=0x34;
TxMessage.IDE=CAN_ID_EXT;
TxMessage.DLC=2;
TxMessage.Data[0]=0xBB;
TxMessage.Data[1]=0xBB;
/* initialize the value that will be returned */
ret=0xFF;
/* receive message with interrupt handling */
i=0;
while((ret==0xFF)&&(i<0XFFF))
i++;
if (i==0xFFF)
ret=0;
/* disable interrupt handling */
CAN_ITConfig(CAN_IT_FMP0, DISABLE);
return (TestStatus)ret;
#ifdef DEBUG
* Function Name : assert_failed
* Description : Reports the name of the source file and the source line number
* where the assert error has occurred.
* Input : - file: pointer to the source file name
* - line: assert error line source number
* Output : None
* Return : None
void assert_failed(u8* file, u32 line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
/******************* (C) COPYRIGHT 2007 STMicroelectronics *****END OF FILE****/ |
