查看: 760|回复: 0
电子密码锁LCD12864中文显示
发表于 2015-5-11 13:31:20 | 显示全部楼层 |阅读模式
[/free]/***** LCD 12864 with KS0108B controller display driver *****/
#define uchar unsigned char
#include<drive_functions.h>
#include<get_keys.h>
bit verify=0;
bit cursor=1;
bit modify_flag=0,modify=0;
uint time_counter=0;
uchar counter=0,j=0,i,k;
uchar PASS[8]={1,2,3,4,5,6,7,8};
uchar PW[8]={0,0,0,0,0,0,0,0};
uchar PW_NULL[8]={0,0,0,0,0,0,0,0};
uchar MODIFY_BUF[8]={0,0,0,0,0,0,0,0};
/****************************verify pw  ************************/
bit VerifyAray(void)
        uchar i;
        bit temp=FAULSE;
        for(i=0;i<8;i++)
            if(PW==PASS)temp=TRUE;
              else
                 temp=FAULSE;
                 i=8;                       //end for loop
               return(temp);
/*********************** main ************************/
void main(void)
    E=1;
    DspOn();
    ClearLCD();
//    IT0=1;
//    IT1=1;
//    EX0=1;
//    EX1=1;
    TMOD=0x10;
    ET1=1;
    EA=1;
    TH1=0x00;
    TL1=0x00;
    TR1=1;
    while(1)
        /******************fist line****************************/
    uchar i;
    SetStartLine(0);
re_input:
    for(i=0;i<4;i++)
    SetPage(0);
    SetColumn(i<<4);                           // i*16
    DspUp(&QING_SHU[i-1][32],1);
    DspUp(&QING_SHU[i-1+4][32],2);
    SetPage(1);
    DspDown(&QING_SHU[i-1][32],1);
    DspDown(&QING_SHU[i-1+4][32],2);
    /**************second line***************************/
    for(i=0;i<4;i++)
    SetPage(6);
    DspUp(&QING_CHU[i-1][32],1);
    DspUp(&QING_CHU[i+4-1][32],2);
    SetPage(7);
    DspDown(&QING_CHU[i-1][32],1);
    DspDown(&QING_CHU[i+4-1][32],2);
/***************************光标显示***********************************/
if(counter<8)           //如果输入到第8位,光标不再显示
if(cursor)
    i=counter;
    SetPage(2);
    SetColumn((i<4)?(i*16)(i-4)*16));
    DspUp(&GUANG_BIAO_KONG[-1][32],(i<4)?1:2);
    SetPage(3);
    DspDown(&GUANG_BIAO_KONG[-1][32],(i<4)?1:2);
else
    i=counter;
    SetPage(2);
    DspUp(&GUANG_BIAO_KONG[0][32],(i<4)?1:2);
    SetPage(3);
    DspDown(&GUANG_BIAO_KONG[0][32],(i<4)?1:2);
/***********************get key's value**************************/
if(CheckState())
            delay();
            if(CheckState())
                key=GetKeys();
               if(key==0x82)                     //clear input
                     if(modify_flag){counter=0;MODIFY_BUF[8]=PW_NULL[8];}
                  else {counter=0W[8]=PW_NULL[8];}
                    for(i=0;i<8;i++)
                        SetPage(2);
                        SetColumn(i<<4);
                        DspUp(&GUANG_BIAO_KONG[0][32],1);
                        DspUp(&GUANG_BIAO_KONG[0][32],2);
                        SetPage(3);
                        SetColumn(i<<4);
                        DspDown(&GUANG_BIAO_KONG[0][32],1);
                        DspDown(&GUANG_BIAO_KONG[0][32],2);
              else if(key==0x88)                       //verify password
                    if(modify_flag){modify=1;goto modify_operation;}
                      else {verify=1;goto verify_password;}
              else if(counter<8)                      //get keys
                    switch(key)
                          case 0x84:
                                      if(modify_flag)MODIFY_BUF[counter]=0;
                                    else PW[counter]=0;
                                    break;
                         case 0x42:
                                     if(modify_flag)MODIFY_BUF[counter]=1;
                                    else PW[counter]=1;
                                    break;
                         case 0x44:
                                     if(modify_flag)MODIFY_BUF[counter]=2;
                                    else PW[counter]=2;
                                    break;
                         case 0x48:
                                     if(modify_flag)MODIFY_BUF[counter]=3;
                                    else PW[counter]=3;
                                    break;
                         case 0x22:
                                     if(modify_flag)MODIFY_BUF[counter]=4;
                                    else PW[counter]=4;
                                    break;
                         case 0x24:
                                     if(modify_flag)MODIFY_BUF[counter]=5;
                                    else PW[counter]=5;
                                    break;
                         case 0x28:
                                     if(modify_flag)MODIFY_BUF[counter]=6;
                                    else PW[counter]=6;
                                    break;
                         case 0x12:
                                     if(modify_flag)MODIFY_BUF[counter]=7;
                                    else PW[counter]=7;
                                    break;
                         case 0x14:
                                     if(modify_flag)MODIFY_BUF[counter]=8;
                                    else PW[counter]=8;
                                    break;
                         case 0x18:
                                     if(modify_flag)MODIFY_BUF[counter]=9;
                                    else PW[counter]=9;
                                    break;
                         default:
                                     break;
                        counter++;
/************************display password input **************************/
for(i=0;i<counter;i++)
      if(modify_flag==1)j=MODIFY_BUF;
    else j=PW;
    SetPage(2);
    DspUp(&NUMBER_ARRY[j-1][32],(i<4)?1:2);
    SetPage(3);
    DspDown(&NUMBER_ARRY[j-1][32],(i<4)?1:2);
/*******************************verify_password*************************/
verify_password:    if(verify)
                        if(VerifyAray())
                           ClearLCD();
                loop1:     for(i=0;i<4;i++)
                            SetPage(0);
                            DspUp(&TONG_GUO[i-1][32],1);
                            DspUp(&TONG_GUO[i-1+4][32],2);
                            SetPage(1);
                            DspDown(&TONG_GUO[i-1][32],1);
                            DspDown(&TONG_GUO[i-1+4][32],2);
                            SetPage(6);
                            DspUp(&TONG_GUO_TI_SHI[i-1][32],1);
                            DspUp(&TONG_GUO_TI_SHI[i-1+4][32],2);
                            SetPage(7);
                            DspDown(&TONG_GUO_TI_SHI[i-1][32],1);
                            DspDown(&TONG_GUO_TI_SHI[i-1+4][32],2);
                            if(CheckState())
                                delay();
                                if(CheckState())
                                        key=GetKeys();
                                           if(key==0x82)
                                        {counter=0;verify=0;goto re_input;}
                                        else if(key==0x88)
                                        {counter=0;modify_flag=1;verify=0;goto re_input;}
                         else  goto loop1;
                      else
                              ClearLCD();
                    loop2:    for(i=0;i<4;i++)
                            SetPage(0);
                            DspUp(&BU_TONG_GUO[i-1][32],1);
                            DspUp(&BU_TONG_GUO[i-1+4][32],2);
                            SetPage(1);
                            DspDown(&BU_TONG_GUO[i-1][32],1);
                            DspDown(&BU_TONG_GUO[i-1+4][32],2);
                            SetPage(6);
                            SetPage(7);
                            if(CheckState())
                                    delay();
                                if(CheckState())
                                        key=GetKeys();
                                           if(key==0x82)
                            else goto loop2;
/*********************modify password operation *********************/
modify_operation:  if(modify)
                        modify_flag=0;
                          if(1)
                             for(i=0;i<8;i++){PASS=MODIFY_BUF;}
                              //PASS[8]=MODIFY_BUF[8];
                            ClearLCD();
                    loop3:    for(i=0;i<4;i++)
                            SetPage(0);
                            DspUp(&GAI_CHENG_GONG[i-1][32],1);
                            DspUp(&GAI_CHENG_GONG[i-1+4][32],2);
                            SetPage(1);
                            DspDown(&GAI_CHENG_GONG[i-1][32],1);
                            DspDown(&GAI_CHENG_GONG[i-1+4][32],2);
                            SetPage(2);
                            DspUp(&GAI_HOU_TI_SHI[i-1][32],1);
                            DspUp(&GAI_HOU_TI_SHI[i-1+4][32],2);
                            SetPage(3);
                            DspDown(&GAI_HOU_TI_SHI[i-1][32],1);
                            DspDown(&GAI_HOU_TI_SHI[i-1+4][32],2);
                            j=PASS;
                            k=PASS[i+4];
                            SetPage(4);
                            SetColumn(i<<4);
                            DspUp(&NUMBER_ARRY[j-1][32],1);
                            DspUp(&NUMBER_ARRY[k-1][32],2);
                            SetPage(5);
                            SetColumn(i<<4);
                            DspDown(&NUMBER_ARRY[j-1][32],1);
                            DspDown(&NUMBER_ARRY[k-1][32],2);
                            SetPage(6);
                            SetPage(7);
                            if(CheckState())
                                    delay();
                                if(CheckState())
                                        key=GetKeys();
                                           if(key==0x82)
                                        {counter=0;modify=0;ClearLCD();goto re_input;}
                            else goto loop3;
/*******timer1 interrupt to change cursor display on and off ******/
void Timer1(void) interrupt 3 using 1
    TH1=0x00;
    TL1=0x00;
    TR1=1;
    if(time_counter>10)
        time_counter=0;
        cursor=~cursor;
     else time_counter++;
/************* INT0 interrupt to scroll up by press switch P3.2 **********************/
/*void INT0_ON(void) interrupt 0 using 2
    direction=UP;
/************** INT1 interrupt to scroll down by press switch P3.3***********************/
/*void INT1_OFF(void) interrupt 2 using 3
    direction=DOWN;
[free]
购买主题 本主题需向作者支付 1 枚金币 才能浏览
