** Copyright 2012 The Android Open Source Project
** Licensed under the Apache License Version 2.0(the "License");
** you may not use this file except in compliance with the License.
** You may obtain a copy of the License at
** http://www.apache.org/licenses/LICENSE-2.0
** Unless required by applicable law or agreed to in writing software
** distributed under the License is distributed on an "AS IS" BASIS
** WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND either express or implied.
** See the License for the specific language governing permissions and
** limitations under the License.
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <errno.h>
#include <cutils/log.h>
#include <utils/String8.h>
#include <ui/Rect.h>
#include <EGL/egl.h>
#include <hardware/hardware.h>
#include <gui/Surface.h>
#include <gui/GraphicBufferAlloc.h>
#include <ui/GraphicBuffer.h>
#include "FramebufferSurface.h"
#include "HWComposer.h"
#ifndef NUM_FRAMEBUFFER_SURFACE_BUFFERS
#define NUM_FRAMEBUFFER_SURFACE_BUFFERS (3)
#endif
namespace android {
* This implements the (main) framebuffer management. This class is used
* mostly by SurfaceFlinger, but also by command line GL application.
FramebufferSurface::FramebufferSurface(HWComposer& hwc, int disp,
const sp<IGraphicBufferConsumer>& consumer) :
ConsumerBase(consumer),
mDisplayType(disp),
mCurrentBufferSlot(-1),
mCurrentBuffer(0),
mHwc(hwc)
mName = "FramebufferSurface";
mConsumer->setConsumerName(mName);
if(disp == 1)
mConsumer->setConsumerUsageBits(GRALLOC_USAGE_HW_RENDER |
GRALLOC_USAGE_HW_COMPOSER);
else
mConsumer->setConsumerUsageBits(GRALLOC_USAGE_HW_FB |
mConsumer->setDefaultBufferFormat(mHwc.getFormat(disp));
mConsumer->setDefaultBufferSize(mHwc.getWidth(disp), mHwc.getHeight(disp));
mConsumer->setDefaultMaxBufferCount(NUM_FRAMEBUFFER_SURFACE_BUFFERS);
status_t FramebufferSurface::beginFrame() {
return NO_ERROR;
status_t FramebufferSurface::prepareFrame(CompositionType compositionType) {
return NO_ERROR;
status_t FramebufferSurface::advanceFrame() {
// Once we remove FB HAL support, we can call nextBuffer() from here
// instead of using onFrameAvailable(). No real benefit, except it'll be
// more like VirtualDisplaySurface.
return NO_ERROR;
status_t FramebufferSurface::nextBuffer(sp<GraphicBuffer>& outBuffer, sp<Fence>& outFence) {
Mutex::Autolock lock(mMutex);
BufferQueue::BufferItem item;
status_t err = acquireBufferLocked(&item, 0);
if (err == BufferQueue::NO_BUFFER_AVAILABLE) {
outBuffer = mCurrentBuffer;
return NO_ERROR;
} else if (err != NO_ERROR) {
ALOGE("error acquiring buffer: %s (%d)", strerror(-err), err);
return err;
// If the BufferQueue has freed and reallocated a buffer in mCurrentSlot
// then we may have acquired the slot we already own. If we had released
// our current buffer before we call acquireBuffer then that release call
// would have returned STALE_BUFFER_SLOT, and we would have called
// freeBufferLocked on that slot. Because the buffer slot has already
// been overwritten with the new buffer all we have to do is skip the
// releaseBuffer call and we should be in the same state we'd be in if we
// had released the old buffer first.
if (mCurrentBufferSlot != BufferQueue::INVALID_BUFFER_SLOT &&
item.mBuf != mCurrentBufferSlot) {
// Release the previous buffer.
err = releaseBufferLocked(mCurrentBufferSlot, mCurrentBuffer,
EGL_NO_DISPLAY, EGL_NO_SYNC_KHR);
if (err < NO_ERROR) {
ALOGE("error releasing buffer: %s (%d)", strerror(-err), err);
return err;
mCurrentBufferSlot = item.mBuf;
mCurrentBuffer = mSlots[mCurrentBufferSlot].mGraphicBuffer;
outFence = item.mFence;
return NO_ERROR;
// Overrides ConsumerBase:nFrameAvailable(), does not call base class impl.
void FramebufferSurface:nFrameAvailable() {
sp<GraphicBuffer> buf;
sp<Fence> acquireFence;
status_t err = nextBuffer(buf, acquireFence);
ALOGE("error latching nnext FramebufferSurface buffer: %s (%d)",
return;
err = mHwc.fbPost(mDisplayType, acquireFence, buf);
ALOGE("error posting framebuffer: %d", err);
void FramebufferSurface::freeBufferLocked(int slotIndex) {
ConsumerBase::freeBufferLocked(slotIndex);
if (slotIndex == mCurrentBufferSlot) {
mCurrentBufferSlot = BufferQueue::INVALID_BUFFER_SLOT;
void FramebufferSurface:nFrameCommitted() {
sp<Fence> fence = mHwc.getAndResetReleaseFence(mDisplayType);
if (fence->isValid() &&
mCurrentBufferSlot != BufferQueue::INVALID_BUFFER_SLOT) {
status_t err = addReleaseFence(mCurrentBufferSlot,
mCurrentBuffer, fence);
ALOGE_IF(err, "setReleaseFenceFd: failed to add the fence: %s (%d)",
status_t FramebufferSurface::compositionComplete()
return mHwc.fbCompositionComplete();
// Since DisplaySurface and ConsumerBase both have a method with this
// signature, results will vary based on the static pointer type the caller is
// using:
// void dump(FrameBufferSurface* fbs, String8& s) {
// // calls FramebufferSurface::dump()
// fbs->dump(s);
// // calls ConsumerBase::dump() since it is non-virtual
// static_cast<ConsumerBase*>(fbs)->dump(s);
// // calls FramebufferSurface::dump() since it is virtual
// static_cast<DisplaySurface*>(fbs)->dump(s);
// To make sure that all of these end up doing the same thing, we just redirect
// to ConsumerBase::dump() here. It will take the internal lock, and then call
// virtual dumpLocked(), which is where the real work happens.
void FramebufferSurface::dump(String8& result) const {
ConsumerBase::dump(result);
void FramebufferSurface::dumpLocked(String8& result, const char* prefix) const
mHwc.fbDump(result);
ConsumerBase::dumpLocked(result, prefix);
}; // namespace android
