* include/linux/goodix_touch.h
* Copyright (C) 2010 - 2011 Goodix, Inc.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
#ifndef _LINUX_GOODIX_TOUCH_H
#define _LINUX_GOODIX_TOUCH_H
#include <linux/hrtimer.h>
#include <linux/i2c.h>
#include <linux/input.h>
#include "tp_suspend.h"
//*************************TouchScreen Work Part*****************************
#define GOODIX_I2C_NAME "Goodix-TS"
#define TS_MAX_X CONFIG_TOUCH_MAX_X
#define TS_MAX_Y CONFIG_TOUCH_MAX_Y
#if 1
#define INT_PORT RK29_PIN0_PA2
#ifdef INT_PORT
#define TS_INT gpio_to_irq(INT_PORT)
// #define INT_CFG S3C_GPIO_SFN(2) //IO configer as EINT
#else
#define TS_INT 0
#endif
//whether need send cfg?
//#define DRIVER_SEND_CFG
//set trigger mode
#define INT_TRIGGER 0
#endif
#define POLL_TIME 10 //actual query spacing intervalOLL_TIME+6
#define GOODIX_MULTI_TOUCH
#ifdef GOODIX_MULTI_TOUCH
#define MAX_FINGER_NUM 10
#else
#endif
//#define swap(x, y) do { typeof(x) z = x; x = y; y = z; } while (0)
struct rk_touch_info
u32 press;
u32 x ;
u32 y ;
int status ; // 0 1
struct rk_ts_data{
struct i2c_client *client;
struct input_dev *input_dev;
int irq;
int irq_pin;
int pwr_pin;
int rst_pin;
int rst_val;
int read_mode; //read moudle mode,20110221 by andrew
char phys[32];
int (*power)(struct rk_ts_data * ts, int on);
int (*ts_init)(struct rk_ts_data*ts);
int (*input_parms_init)(struct rk_ts_data *ts);
void (*get_touch_info)(struct rk_ts_data *ts,char *point_num,struct rk_touch_info *info_buf); //get touch data info
uint16_t abs_x_max;
uint16_t abs_y_max;
uint8_t max_touch_num;
bool pendown;
struct rk_touch_info *info_buf;
struct tp_device tp;
struct goodix_ts_data {
uint16_t addr;
uint8_t bad_data;
int use_reset; //use RESET flag
int use_irq; //use EINT flag
struct hrtimer timer;
struct delayed_work work;
char phys[32];
int retry;
int (*power)(struct goodix_ts_data * ts, int on);
uint16_t abs_x_max;
uint16_t abs_y_max;
uint8_t int_trigger_type;
bool pendown;
static const char *rk_ts_name = "Goodix Capacitive TouchScreen";
struct i2c_client * i2c_connect_client = NULL;
#ifdef CONFIG_TOUCHSCREEN_GOODIX_IAP
static struct proc_dir_entry *goodix_proc_entry;
#endif
//static struct kobject *goodix_debug_kobj;
#define READ_COOR_ADDR 0x01
//*****************************End of Part I *********************************
//*************************Touchkey Surpport Part*****************************
//#define HAVE_TOUCH_KEY
#ifdef HAVE_TOUCH_KEY
#define READ_COOR_ADDR 0x00
const uint16_t touch_key_array[]={
KEY_MENU, //MENU
KEY_HOME, //HOME
KEY_SEND //CALL
#define MAX_KEY_NUM (sizeof(touch_key_array)/sizeof(touch_key_array[0]))
#else
#endif
//*****************************End of Part II*********************************
#if 1
//*************************Firmware Update part*******************************
//#define CONFIG_TOUCHSCREEN_GOODIX_IAP
#define UPDATE_NEW_PROTOCOL
unsigned int oldcrc32 = 0xFFFFFFFF;
unsigned int crc32_table[256];
unsigned int ulPolynomial = 0x04c11db7;
unsigned char rd_cfg_addr;
unsigned char rd_cfg_len;
unsigned char g_enter_isp = 0;
static int goodix_update_write(struct file *filp, const char __user *buff, unsigned long len, void *data);
static int goodix_update_read( char *page, char **start, off_t off, int count, int *eof, void *data );
#define PACK_SIZE 64 //update file package size
#define MAX_TIMEOUT 60000 //update time out conut
#define MAX_I2C_RETRIES 20 //i2c retry times
//I2C buf address
#define ADDR_CMD 80
#define ADDR_STA 81
#ifdef UPDATE_NEW_PROTOCOL
#define ADDR_DAT 0
#else
#define ADDR_DAT 82
#endif
//moudle state
#define NEW_UPDATE_START 0x01
#define UPDATE_START 0x02
#define SLAVE_READY 0x08
#define UNKNOWN_ERROR 0x00
#define FRAME_ERROR 0x10
#define CHECKSUM_ERROR 0x20
#define TRANSLATE_ERROR 0x40
#define FLASH_ERROR 0X80
//error no
#define ERROR_NO_FILE 2 //ENOENT
#define ERROR_FILE_READ 23 //ENFILE
#define ERROR_FILE_TYPE 21 //EISDIR
#define ERROR_GPIO_REQUEST 4 //EINTR
#define ERROR_I2C_TRANSFER 5 //EIO
#define ERROR_NO_RESPONSE 16 //EBUSY
#define ERROR_TIMEOUT 110 //ETIMEDOUT
//update steps
#define STEP_SET_PATH 1
#define STEP_CHECK_FILE 2
#define STEP_WRITE_SYN 3
#define STEP_WAIT_SYN 4
#define STEP_WRITE_LENGTH 5
#define STEP_WAIT_READY 6
#define STEP_WRITE_DATA 7
#define STEP_READ_STATUS 8
#define FUN_CLR_VAL 9
#define FUN_CMD 10
#define FUN_WRITE_CONFIG 11
//fun cmd
#define CMD_DISABLE_TP 0
#define CMD_ENABLE_TP 1
#define CMD_READ_VER 2
#define CMD_READ_RAW 3
#define CMD_READ_DIF 4
#define CMD_READ_CFG 5
#define CMD_SYS_REBOOT 101
//read mode
#define MODE_RD_VER 1
#define MODE_RD_RAW 2
#define MODE_RD_DIF 3
#define MODE_RD_CFG 4
#endif
//*****************************End of Part III********************************
#endif
struct goodix_i2c_platform_data {
uint32_t version; /* Use this entry for panels with */
//reservation
#endif /* _LINUX_GOODIX_TOUCH_H */ |
