查看: 985|回复: 0
RK平台上 BCM203的驱动
社区居民社区明星忠实会员宣传大使奖终身成就奖特殊贡献奖
发表于 2015-7-4 22:07:49 | 显示全部楼层 |阅读模式
return;
    switch (data->state) {
    case BCM203X_LOAD_MINIDRV:
        memcpy(data->buffer, "#", 1);
        usb_fill_bulk_urb(urb, udev, usb_sndbulkpipe(udev, BCM203X_OUT_EP),
                data->buffer, 1, bcm203x_complete, data);
        data->state = BCM203X_SELECT_MEMORY;
        /* use workqueue to have a small delay */
        schedule_work(&data->work);
        break;
    case BCM203X_SELECT_MEMORY:
        usb_fill_int_urb(urb, udev, usb_rcvintpipe(udev, BCM203X_IN_EP),
                data->buffer, 32, bcm203x_complete, data, 1);
        data->state = BCM203X_CHECK_MEMORY;
        if (usb_submit_urb(data->urb, GFP_ATOMIC) < 0)
            BT_ERR("Can't submit URB");
        break;
    case BCM203X_CHECK_MEMORY:
        if (data->buffer[0] != '#') {
            BT_ERR("Memory select failed");
            data->state = BCM203X_ERROR;
            break;
        data->state = BCM203X_LOAD_FIRMWARE;
    case BCM203X_LOAD_FIRMWARE:
        if (data->fw_sent == data->fw_size) {
            data->state = BCM203X_CHECK_FIRMWARE;
        } else {
            len = min_t(uint, data->fw_size - data->fw_sent, 4096);
                data->fw_data + data->fw_sent, len, bcm203x_complete, data);
            data->fw_sent += len;
        break;
    case BCM203X_CHECK_FIRMWARE:
        if (data->buffer[0] != '.') {
            BT_ERR("Firmware loading failed");
            break;
        data->state = BCM203X_RESET;
        break;
static void bcm203x_work(struct work_struct *work)
    struct bcm203x_data *data =
        container_of(work, struct bcm203x_data, work);
    if (atomic_read(&data->shutdown))
        return;
    if (usb_submit_urb(data->urb, GFP_KERNEL) < 0)
static int bcm203x_probe(struct usb_interface *intf, const struct usb_device_id *id)
    const struct firmware *firmware;
    struct usb_device *udev = interface_to_usbdev(intf);
    struct bcm203x_data *data;
    int size;
    BT_DBG("intf %p id %p", intf, id);
    if (intf->cur_altsetting->desc.bInterfaceNumber != 0)
        return -ENODEV;
    data = devm_kzalloc(&intf->dev, sizeof(*data), GFP_KERNEL);
    if (!data) {
        BT_ERR("Can't allocate memory for data structure");
        return -ENOMEM;
    data->udev  = udev;
    data->state = BCM203X_LOAD_MINIDRV;
    data->urb = usb_alloc_urb(0, GFP_KERNEL);
    if (!data->urb) {
        BT_ERR("Can't allocate URB");
        return -ENOMEM;
    if (request_firmware(&firmware, "BCM2033-MD.hex", &udev->dev) < 0) {
        BT_ERR("Mini driver request failed");
        usb_free_urb(data->urb);
        return -EIO;
    BT_DBG("minidrv data %p size %zu", firmware->data, firmware->size);
    size = max_t(uint, firmware->size, 4096);
    data->buffer = kmalloc(size, GFP_KERNEL);
    if (!data->buffer) {
        BT_ERR("Can't allocate memory for mini driver");
        release_firmware(firmware);
        return -ENOMEM;
    memcpy(data->buffer, firmware->data, firmware->size);
    usb_fill_bulk_urb(data->urb, udev, usb_sndbulkpipe(udev, BCM203X_OUT_EP),
            data->buffer, firmware->size, bcm203x_complete, data);
    if (request_firmware(&firmware, "BCM2033-FW.bin", &udev->dev) < 0) {
        BT_ERR("Firmware request failed");
        kfree(data->buffer);
        return -EIO;
    BT_DBG("firmware data %p size %zu", firmware->data, firmware->size);
    data->fw_data = kmemdup(firmware->data, firmware->size, GFP_KERNEL);
    if (!data->fw_data) {
        BT_ERR("Can't allocate memory for firmware image");
        return -ENOMEM;
    data->fw_size = firmware->size;
    data->fw_sent = 0;
    INIT_WORK(&data->work, bcm203x_work);
    usb_set_intfdata(intf, data);
    return 0;
static void bcm203x_disconnect(struct usb_interface *intf)
    struct bcm203x_data *data = usb_get_intfdata(intf);
    BT_DBG("intf %p", intf);
    atomic_inc(&data->shutdown);
    cancel_work_sync(&data->work);
    usb_kill_urb(data->urb);
    usb_set_intfdata(intf, NULL);
    kfree(data->fw_data);
static struct usb_driver bcm203x_driver = {
    .name        = "bcm203x",
    .probe        = bcm203x_probe,
    .disconnect    = bcm203x_disconnect,
    .id_table    = bcm203x_table,
