#include <linux/console.h>
#include <linux/fb.h>
#include <linux/completion.h>
#include <linux/rk_screen.h>
#include <linux/hdmi.h>
#include "../rk29_fb.h"
/* Base */
#define LCD_ACLK 500000000// 312000000
#define OUT_TYPE SCREEN_HDMI
#define OUT_FACE OUT_P888
#define DCLK_POL 1
#define SWAP_RB 0
/* 720p@50Hz Timing */
#define OUT_CLK0 74250000
#define H_PW0 40
#define H_BP0 220
#define H_VD0 1280
#define H_FP0 440
#define V_PW0 5
#define V_BP0 20
#define V_VD0 720
#define V_FP0 5
/* 720p@60Hz Timing */
#define OUT_CLK1 74250000
#define H_PW1 40
#define H_BP1 220
#define H_VD1 1280
#define H_FP1 110
#define V_PW1 5
#define V_BP1 20
#define V_VD1 720
#define V_FP1 5
/* 576p@50Hz Timing */
#define OUT_CLK2 27000000
#define H_PW2 64
#define H_BP2 68
#define H_VD2 720
#define H_FP2 12
#define V_PW2 5
#define V_BP2 39
#define V_VD2 576
#define V_FP2 5
/* 720x480p@60Hz Timing */
#define OUT_CLK3 27000000
#define H_PW3 62
#define H_BP3 60
#define H_VD3 720
#define H_FP3 16
#define V_PW3 6
#define V_BP3 30
#define V_VD3 480
#define V_FP3 9
/* 1080p@50Hz Timing */
#define OUT_CLK5 148500000
#define H_PW4 44
#define H_BP4 148
#define H_VD4 1920
#define H_FP4 528
#define V_PW4 5
#define V_BP4 36
#define V_VD4 1080
#define V_FP4 4
/* 1080p@60Hz Timing */
#define OUT_CLK4 148500000
#define H_PW5 44
#define H_BP5 148
#define H_VD5 1920
#define H_FP5 88
#define V_PW5 5
#define V_BP5 36
#define V_VD5 1080
#define V_FP5 4
extern int FB_Switch_Screen( struct rk29fb_screen *screen, u32 enable );
static int anx7150_init(void)
return 0;
static int anx7150_standby(u8 enable)
return 0;
struct rk29fb_screen hdmi_info[] = {
.hdmi_resolution = HDMI_1280x720p_50Hz,
.type = OUT_TYPE,
.face = OUT_FACE,
.x_res = H_VD0,
.y_res = V_VD0,
.pixclock = OUT_CLK0,
.lcdc_aclk = LCD_ACLK,
.left_margin = H_BP0,
.right_margin = H_FP0,
.hsync_len = H_PW0,
.upper_margin = V_BP0,
.lower_margin = V_FP0,
.vsync_len = V_PW0,
.pin_hsync = 1,
.pin_vsync = 1,
.pin_den = 0,
.pin_dclk = DCLK_POL,
.swap_rb = SWAP_RB,
.swap_rg = 0,
.swap_gb = 0,
.swap_delta = 0,
.swap_dumy = 0,
.init = anx7150_init,
.standby = anx7150_standby,
}, //HDMI_1280x720p_50Hz
.hdmi_resolution = HDMI_1280x720p_60Hz,
.type = OUT_TYPE,
.face = OUT_FACE,
.x_res = H_VD1,
.y_res = V_VD1,
.pixclock = OUT_CLK1,
.left_margin = H_BP1,
.right_margin = H_FP1,
.hsync_len = H_PW1,
.upper_margin = V_BP1,
.lower_margin = V_FP1,
.vsync_len = V_PW1,
.pin_hsync = 1,
.pin_vsync = 1,
.pin_den = 0,
.swap_rb = SWAP_RB,
.swap_rg = 0,
.swap_gb = 0,
.swap_delta = 0,
.swap_dumy = 0,
}, //HDMI_1280x720p_60Hz
.hdmi_resolution = HDMI_720x576p_50Hz_4x3,
.type = OUT_TYPE,
.face = OUT_FACE,
.x_res = H_VD2,
.y_res = V_VD2,
.pixclock = OUT_CLK2,
.left_margin = H_BP2,
.right_margin = H_FP2,
.hsync_len = H_PW2,
.upper_margin = V_BP2,
.lower_margin = V_FP2,
.vsync_len = V_PW2,
.pin_hsync = 0,
.pin_vsync = 0,
.pin_den = 0,
.swap_rb = SWAP_RB,
.swap_rg = 0,
.swap_gb = 0,
.swap_delta = 0,
.swap_dumy = 0,
}, //HDMI_720x576p_50Hz_4x3
.hdmi_resolution = HDMI_720x576p_50Hz_16x9,
.type = OUT_TYPE,
.face = OUT_FACE,
.x_res = H_VD2,
.y_res = V_VD2,
.hsync_len = H_PW2,
.vsync_len = V_PW2,
.pin_hsync = 0,
.pin_vsync = 0,
.pin_den = 0,
.swap_rb = SWAP_RB,
.swap_rg = 0,
.swap_gb = 0,
.swap_delta = 0,
.swap_dumy = 0,
}, //HDMI_720x576p_50Hz_16x9
.hdmi_resolution = HDMI_720x480p_60Hz_4x3,
.type = OUT_TYPE,
.face = OUT_FACE,
.x_res = H_VD3,
.y_res = V_VD3,
.pixclock = OUT_CLK3,
.left_margin = H_BP3,
.right_margin = H_FP3,
.hsync_len = H_PW3,
.upper_margin = V_BP3,
.lower_margin = V_FP3,
.vsync_len = V_PW3,
.pin_hsync = 0,
.pin_vsync = 0,
.pin_den = 0,
.swap_rb = SWAP_RB,
.swap_rg = 0,
.swap_gb = 0,
.swap_delta = 0,
.swap_dumy = 0,
}, //HDMI_720x480p_60Hz_4x3
.hdmi_resolution = HDMI_720x480p_60Hz_16x9,
.type = OUT_TYPE,
.face = OUT_FACE,
.x_res = H_VD3,
.y_res = V_VD3,
.hsync_len = H_PW3,
.vsync_len = V_PW3,
.pin_hsync = 0,
.pin_vsync = 0,
.pin_den = 0,
.swap_rb = SWAP_RB,
.swap_rg = 0,
.swap_gb = 0,
.swap_delta = 0,
.swap_dumy = 0,
}, //HDMI_720x480p_60Hz_16x9
.hdmi_resolution = HDMI_1920x1080p_50Hz,
.type = OUT_TYPE,
.face = OUT_FACE,
.x_res = H_VD4,
.y_res = V_VD4,
.pixclock = OUT_CLK4,
.left_margin = H_BP4,
.right_margin = H_FP4,
.hsync_len = H_PW4,
.upper_margin = V_BP4,
.lower_margin = V_FP4,
.vsync_len = V_PW4,
.pin_hsync = 1,
.pin_vsync = 1,
.pin_den = 0,
.swap_rb = SWAP_RB,
.swap_rg = 0,
.swap_gb = 0,
.swap_delta = 0,
.swap_dumy = 0,
}, //HDMI_1920x1080p_50Hz
.hdmi_resolution = HDMI_1920x1080p_60Hz,
.type = OUT_TYPE,
.face = OUT_FACE,
.x_res = H_VD5,
.y_res = V_VD5,
.pixclock = OUT_CLK5,
.left_margin = H_BP5,
.right_margin = H_FP5,
.hsync_len = H_PW5,
.upper_margin = V_BP5,
.lower_margin = V_FP5,
.vsync_len = V_PW5,
.pin_hsync = 1,
.pin_vsync = 1,
.pin_den = 0,
.swap_rb = SWAP_RB,
.swap_rg = 0,
.swap_gb = 0,
.swap_delta = 0,
.swap_dumy = 0,
}, //HDMI_1920x1080p_60Hz
int hdmi_switch_fb(struct hdmi *hdmi, int type)
int rc = 0;
switch(hdmi->resolution)
case HDMI_1280x720p_50Hz:
rc = FB_Switch_Screen(&hdmi_info[0], type);
break;
case HDMI_1280x720p_60Hz:
rc = FB_Switch_Screen(&hdmi_info[1], type);
break;
case HDMI_720x576p_50Hz_4x3:
rc = FB_Switch_Screen(&hdmi_info[2], type);
break;
case HDMI_720x576p_50Hz_16x9:
rc = FB_Switch_Screen(&hdmi_info[3], type);
break;
case HDMI_720x480p_60Hz_4x3:
rc = FB_Switch_Screen(&hdmi_info[4], type);
break;
case HDMI_720x480p_60Hz_16x9:
rc = FB_Switch_Screen(&hdmi_info[5], type);
break;
case HDMI_1920x1080p_50Hz:
rc = FB_Switch_Screen(&hdmi_info[6], type);
break;
case HDMI_1920x1080p_60Hz:
rc = FB_Switch_Screen(&hdmi_info[7], type);
break;
default:
break;
if(hdmi->wait == 1) {
complete(&hdmi->complete);
hdmi->wait = 0;
return rc;
