查看: 1119|回复: 0
RK3288  MIPI接口  LD089WU1 驱动源码
社区居民社区明星忠实会员宣传大使奖终身成就奖特殊贡献奖
发表于 2015-7-8 15:01:23 | 显示全部楼层 |阅读模式
#ifndef __LCD_LD089WU1__
#define __LCD_LD089WU1__
#if defined(CONFIG_MIPI_DSI)
#include "../transmitter/mipi_dsi.h"
#endif
#if  defined(CONFIG_RK610_LVDS) || defined(CONFIG_RK616_LVDS)
#define SCREEN_TYPE            SCREEN_LVDS
#else
#define SCREEN_TYPE            SCREEN_MIPI
#endif
#define LVDS_FORMAT         0     //mipi lcd don't need it, so 0 would be ok.
#define OUT_FACE            OUT_P888
#define DCLK                  150*1000000
#define LCDC_ACLK             300000000           //29 lcdc axi DMA ÆμÂê
/* Timing */
#define H_PW            16
#define H_BP            40
#define H_VD            1920
#define H_FP            24
#define V_PW            10
#define V_BP            10
#define V_VD            1200
#define V_FP            16
#define LCD_WIDTH              204
#define LCD_HEIGHT             136
/* Other */
#if defined(CONFIG_RK610_LVDS) || defined(CONFIG_RK616_LVDS) || defined(CONFIG_MIPI_DSI)
#define DCLK_POL    1
#else
#define DCLK_POL    0
#endif
#define DEN_POL        0
#define VSYNC_POL    0
#define HSYNC_POL    0
#define SWAP_RB        0
#define SWAP_RG        0
#define SWAP_GB        0
//#define RK_SCREEN_INIT     1
/* about mipi */
#define MIPI_DSI_LANE 4
#define MIPI_DSI_HS_CLK 1000*1000000
#if defined(RK_SCREEN_INIT)
static struct rk29lcd_info *gLcd_info = NULL;
int rk_lcd_init(void) {
    u8 dcs[16] = {0};
    if(dsi_is_active() != 1)
        return -1;
    /*below is changeable*/
    dsi_enable_hs_clk(1);
    dsi_enable_video_mode(0);
    dsi_enable_command_mode(1);
    dcs[0] = dcs_exit_sleep_mode;
    dsi_send_dcs_packet(dcs, 1);
    msleep(1);
    dcs[0] = dcs_set_display_on;
    msleep(10);
    dsi_enable_command_mode(0);
    dsi_enable_video_mode(1);
    //printk("++++++++++++++++%s:%d\n", __func__, __LINE__);
int rk_lcd_standby(u8 enable) {
    u8 dcs[16] = {0};
        return -1;
    if(enable) {
        dcs[0] = dcs_set_display_off;
        msleep(1);
        dcs[0] = dcs_enter_sleep_mode;
        msleep(1);
    } else {
        rk_lcd_init();
#endif
#endif
