查看: 1222|回复: 0
RK3288  PS2鼠标驱动源码
社区居民社区明星忠实会员宣传大使奖终身成就奖特殊贡献奖
发表于 2015-7-9 09:27:37 | 显示全部楼层 |阅读模式
*  Copyright (c) 2000-2001 Vojtech Pavlik
*  Based on the work of:
*    Alan Cox    Robin O'Leary
* IBM PC110 touchpad driver for Linux
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
* Should you need to contact me, the author, you can do so either by
* e-mail - mail your message to <vojtech@ucw.cz>, or by paper mail:
* Vojtech Pavlik, Simunkova 1594, Prague 8, 182 00 Czech Republic
#include <linux/module.h>
#include <linux/kernel.h>
#include <linux/errno.h>
#include <linux/ioport.h>
#include <linux/input.h>
#include <linux/init.h>
#include <linux/interrupt.h>
#include <linux/pci.h>
#include <linux/delay.h>
#include <asm/io.h>
#include <asm/irq.h>
MODULE_AUTHOR("Vojtech Pavlik <vojtech@ucw.cz>");
MODULE_DESCRIPTION("IBM PC110 touchpad driver");
MODULE_LICENSE("GPL");
#define PC110PAD_OFF    0x30
#define PC110PAD_ON    0x38
static int pc110pad_irq = 10;
static int pc110pad_io = 0x15e0;
static struct input_dev *pc110pad_dev;
static int pc110pad_data[3];
static int pc110pad_count;
static irqreturn_t pc110pad_interrupt(int irq, void *ptr)
    int value     = inb_p(pc110pad_io);
    int handshake = inb_p(pc110pad_io + 2);
    outb(handshake |  1, pc110pad_io + 2);
    udelay(2);
    outb(handshake & ~1, pc110pad_io + 2);
    udelay(2);
    inb_p(0x64);
    pc110pad_data[pc110pad_count++] = value;
    if (pc110pad_count < 3)
        return IRQ_HANDLED;
    input_report_key(pc110pad_dev, BTN_TOUCH,
        pc110pad_data[0] & 0x01);
    input_report_abs(pc110pad_dev, ABS_X,
        pc110pad_data[1] | ((pc110pad_data[0] << 3) & 0x80) | ((pc110pad_data[0] << 1) & 0x100));
    input_report_abs(pc110pad_dev, ABS_Y,
        pc110pad_data[2] | ((pc110pad_data[0] << 4) & 0x80));
    input_sync(pc110pad_dev);
    pc110pad_count = 0;
    return IRQ_HANDLED;
static void pc110pad_close(struct input_dev *dev)
    outb(PC110PAD_OFF, pc110pad_io + 2);
static int pc110pad_open(struct input_dev *dev)
    pc110pad_interrupt(0, NULL);
    outb(PC110PAD_ON, pc110pad_io + 2);
    pc110pad_count = 0;
    return 0;
* We try to avoid enabling the hardware if it's not
* there, but we don't know how to test. But we do know
* that the PC110 is not a PCI system. So if we find any
* PCI devices in the machine, we don't have a PC110.
static int __init pc110pad_init(void)
    int err;
    if (!no_pci_devices())
        return -ENODEV;
    if (!request_region(pc110pad_io, 4, "pc110pad")) {
        printk(KERN_ERR "pc110pad: I/O area %#x-%#x in use.\n",
                pc110pad_io, pc110pad_io + 4);
        return -EBUSY;
    if (request_irq(pc110pad_irq, pc110pad_interrupt, 0, "pc110pad", NULL)) {
        printk(KERN_ERR "pc110pad: Unable to get irq %d.\n", pc110pad_irq);
        err = -EBUSY;
        goto err_release_region;
    pc110pad_dev = input_allocate_device();
    if (!pc110pad_dev) {
        printk(KERN_ERR "pc110pad: Not enough memory.\n");
        err = -ENOMEM;
        goto err_free_irq;
    pc110pad_dev->name = "IBM PC110 TouchPad";
    pc110pad_dev->phys = "isa15e0/input0";
    pc110pad_dev->id.bustype = BUS_ISA;
    pc110pad_dev->id.vendor = 0x0003;
    pc110pad_dev->id.product = 0x0001;
    pc110pad_dev->id.version = 0x0100;
    pc110pad_dev->evbit[0] = BIT_MASK(EV_KEY) | BIT_MASK(EV_ABS);
    pc110pad_dev->absbit[0] = BIT_MASK(ABS_X) | BIT_MASK(ABS_Y);
    pc110pad_dev->keybit[BIT_WORD(BTN_TOUCH)] = BIT_MASK(BTN_TOUCH);
    input_abs_set_max(pc110pad_dev, ABS_X, 0x1ff);
    input_abs_set_max(pc110pad_dev, ABS_Y, 0x0ff);
    pc110pad_dev->open = pc110pad_open;
    pc110pad_dev->close = pc110pad_close;
    err = input_register_device(pc110pad_dev);
    if (err)
        goto err_free_dev;
    return 0;
err_free_dev:
    input_free_device(pc110pad_dev);
err_free_irq:
    free_irq(pc110pad_irq, NULL);
err_release_region:
    release_region(pc110pad_io, 4);
    return err;
static void __exit pc110pad_exit(void)
    input_unregister_device(pc110pad_dev);
module_init(pc110pad_init);
module_exit(pc110pad_exit);
