查看: 920|回复: 1
java 层  3288的HDMI和LVDS应用代码
社区居民社区明星忠实会员宣传大使奖终身成就奖特殊贡献奖
发表于 2015-7-14 20:33:12 | 显示全部楼层 |阅读模式
package com.android.settings.dualscreen;
import android.app.ActionBar;
import android.app.Activity;
import android.os.Bundle;
import android.preference.CheckBoxPreference;
import android.preference.Preference;
import android.preference.PreferenceActivity;
import android.preference.PreferenceScreen;
import android.provider.Settings;
import android.test.PerformanceTestCase;
import android.util.Log;
import android.view.Gravity;
import android.view.View;
import android.widget.Switch;
import android.widget.TextView;
import com.android.settings.R;
import com.android.settings.SettingsPreferenceFragment;
public class DualScreenSettings extends SettingsPreferenceFragment {
    private static final String LOGTAG = "DualScreenSettings";
    private static final boolean DEBUG = true;
    private void LOGD(String msg){
        if(DEBUG){
            Log.d(LOGTAG,msg);
    private static final String KEY_DUALSCREEN_MANUAL = "dualscreen_manual";
    private static final String EXTRA_CHECKED = "checked";
    private static final String EXTRA_TITLE = "title";
    private static final String EXTRA_SUMMARY = "summary";
    private static final String EXTRA_PREFERENCE_KEY = "preference_key";
    private PreferenceScreen mManual;
    private DualScreenEnabler mDualScreenEnabler;
    @Override
    public void onCreate(Bundle icicle) {
        super.onCreate(icicle);
        addPreferencesFromResource(R.xml.dualscreen);
        mManual = (PreferenceScreen)findPreference(KEY_DUALSCREEN_MANUAL);
        Activity activity = getActivity();
        Switch actionBarSwitch = new Switch(activity);
        if (activity instanceof PreferenceActivity) {
            PreferenceActivity preferenceActivity = (PreferenceActivity) activity;
            if (preferenceActivity.onIsHidingHeaders()
                    || !preferenceActivity.onIsMultiPane()) {
                final int padding = activity.getResources()
                        .getDimensionPixelSize(
                                R.dimen.action_bar_switch_padding);
                actionBarSwitch.setPadding(0, 0, padding, 0);
                activity.getActionBar().setDisplayOptions(
                        ActionBar.DISPLAY_SHOW_CUSTOM,
                        ActionBar.DISPLAY_SHOW_CUSTOM);
                activity.getActionBar().setCustomView(
                        actionBarSwitch,
                        new ActionBar.LayoutParams(
                                ActionBar.LayoutParams.WRAP_CONTENT,
                                Gravity.CENTER_VERTICAL | Gravity.END));
        mDualScreenEnabler = new DualScreenEnabler(activity, actionBarSwitch);
        setHasOptionsMenu(true);
    @Override
    public void onResume() {
        super.onResume();
        if (mDualScreenEnabler != null) {
            mDualScreenEnabler.resume();
发表于 2015-7-14 20:49:00 | 显示全部楼层
