查看: 1103|回复: 0
[其他器件] HS0038A2_红外接收头_38KHZ
社区居民
发表于 2015-7-18 22:01:53 | 显示全部楼层 |阅读模式
HS0038A_红外接收.pdf (92 KB, 下载次数: 2)
Description
The HS0038A2. – series are miniaturized receivers for
infrared remote control systems. PIN diode and
preamplifier are assembled on lead frame, the epoxy
package is designed as IR filter.
The demodulated output signal can directly be
decoded by a microprocessor. HS0038A2. is the
standard IR remote control receiver series, supporting
all major transmission codes.
Features
Photo detector and preamplifier in one package
Internal filter for PCM frequency
Improved shielding against electrical field
disturbance
TTL and CMOS compatibility
Output active low
Low power consumption
High immunity against ambient light
Continuous data transmission possible
(800 bit/s)
Suitable burst length .10 cycles/burst
