config LCDC_RK2928
tristate "rk2928 lcdc support"
depends on FB_ROCKCHIP && ARCH_RK2928
help
Driver for rk2928 lcdc .
config LCDC_RK30
tristate "rk30 lcdc support"
depends on FB_ROCKCHIP && ARCH_RK30XX
help
Driver for rk30 lcdc .There are two lcd controllers on rk30
config LCDC0_RK30
bool "lcdc0 support"
depends on LCDC_RK30
default y
help
Support rk30 lcdc0 if you say y here
config LCDC1_RK30
bool "lcdc1 support"
default y if HDMI_RK30
help
Support rk30 lcdc1 if you say y here
config LCDC_RK3066B
tristate "rk3066b lcdc support"
depends on FB_ROCKCHIP && ARCH_RK3066B
help
Driver for rk3066b lcdc.
config LCDC0_RK3066B
depends on LCDC_RK3066B
default y
help
Support lcdc0 if you say y here
config RK3066B_LCDC0_IO_18V
bool "lcdc0 1.8v io support"
depends on LCDC0_RK3066B
default n
help
LCDC0 io voltage is 1.8V if you say y here,the default voltage is 3.3V
config LCDC1_RK3066B
default n
help
Support lcdc1 if you say y here
config RK3066B_LCDC1_IO_18V
bool "lcdc1 1.8v io support"
depends on LCDC1_RK3066B
default n
help
LCDC1 io voltage is 1.8V if you say y here,the default voltage is 3.3V
config LCDC_RK3188
bool "rk3188/rk3026/rk319x lcdc support"
depends on FB_ROCKCHIP && (ARCH_RK3188 || ARCH_RK3026 || ARCH_RK319X)
help
Driver for rk3188 lcdc.There are two lcd controllers on rk3188
config LCDC0_RK3188
depends on LCDC_RK3188
help
Support rk3188 lcdc0 if you say y here
config LCDC0_IO_18V
depends on LCDC0_RK3188
default n
help
config LCDC1_RK3188
help
Support rk3188 lcdc1 if you say y here
config LCDC1_IO_18V
depends on LCDC1_RK3188
default n
help
LCDC1 io voltage is 1.8V if you say y here,the default voltage is 3.3V |
