重要提示:PCB作品文件展下载说明
这个方案设计还是比较有意思,核心部分。可以采用板载的CPU 焊接上去。也可以采用外接核心板形式贴片上去。
PCB文件来了。PADS9.5版本格式。回复可见下载。
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
Name | Part Type | PCB Decal | Value | ACON1 | GPS-RF | AGPSRF | GPS-RF | ACON2 | BT-RF | AGPSBT | BT-RF | ANT4 | CN1 | CN1_LOCK_1X3A | | CAMEA_IN | C_0 | ZZF-CN1.2 | TEST | CAN_BUS1 | CN2/SMT | WF2/SMT1.25 | SMT-2PW | CN1 | CON20P/DH-AMP | CON-DIP20P-2.5-V/DH-AMP | 20Px2.54mm | CN2 | CN14 | AV8-8.4-13 | AV8-8.4-14 | CN3 | CN40P-2.0-H | 20PX2-2.0 | | CN4 | CN34-0.5-H | CN34 | | CN5 | CN40 | SOCKET40/SMD0.5 | 0.5-40P | CN10 | CN2 | WF2/2 | CAN-BUS | CN11 | CN3 | WF3/2 | AUX-IN | CON3 | TV_CON14 | TV-PCB | 14PIN | CON6 | CON-SMD30P-1.0MM-A | CN30 | 30P立式 | D1 | IN4001(DIP) | 0805D | *** | D2 | DIODE/C | DIO/DO-214AC | 1N4001 | D3 | IN4001(DIP) | D_1206 | IN4148 | D20 | BAT54C | SOT-23 | BAT54C | D21 | D-S3G | S3G | SMCJ30A | D32 | DIODE_Z5W27V | DO-218 | | D57 | DIODE/DO-214 | DIO/DO-214AB | B540C | L1 | INDU/CHOKE | L/TC-28H | EI-28 | L2 | INDUCTOR/CHIP | L0603 | FB310 | LA10 | LQM21PN4R7NGR | A0805R | LQM21PN4R7NGR | LA30 | WCM2012SF-900T04 | 2012F2SF | WCM2012SF-900T04 | Q4 | NPN_123 | SOT-23 | 2N3904 | Q5 | PNP | SOT-23 | S8550 | Q6 | MI3407 | SOT-23 | DMP3098L | Q7 | NPN | SOT-23 | 2N3904 | Q8 | ZZF-2SK3018 | ZZF-FET-SC-70 | 2SK3018 | SAWA1 | FAR-F6KA-1G5754-L4AJ | ASAW5PIN | FAR-F6KA-1G5754-L4AJ | SAWA2 | LFB212G45CF7D291 | ABPF_6611 | LFB212G45CF7D291 | TXD1 | GPS-ANT-5P | GPS-ANT-SMA | SMA | TXD5 | TEST | TESTA | | U1 | TDA7384 | TA8266H | TA7388 | U2 | NJM4558 | SO8-OPT | NJM4558 | U3 | PCM1721E_0A | TSSOP20 | CS4361-CZZ | U4 | TL331 | SOT-23-5 | TL331D | U5 | MTK3360-185P | HK300A-PCB | M25P16/EON F16 | U6 | NJM4558 | SO8-OPT | NJM4558 | U6A | BA5934FP_2 | DIP28\SSOPH | AM5888 | U7 | MP2482DN | SOIC8N | MP2482 | U8 | MTK3360-BT | AGPSBT-PCB | BT-RF | U9 | TJA1041AT | SOP14-3.9-1.27 | TJA1041 | U10 | MTK3360-GPS-RF | AGPSRF-PCB | GPS-RF | U11 | 78XX | 78M09 | 78M05 | U12 | SGM9123 | SOP8-3.9-1.27 | SGM9123 | U14 | TS3DV642 | RUA-TS3DV642 | TS3DV642 | U15 | NJM4558 | SO8-OPT | NJM4558 | U16 | IPOD-CP | IPOD_CP | IPOD-CP | U17 | 78XX | SOT252A | 78M09 | U18 | AMS1117 | SOT-223 | AMS1117(3.3V) | U20 | MB1013 | QFP80-1414-0.65 | STM8AH | U21 | IMP809 | SOT-23 | SGM809_2.93V | U25 | TDA7540 | EAC7540 | TDQ-210V-01(ST6644 | U27 | 6202 | SOT-223 | XC6202 | U31 | TJA1050 | SOP8-3.9-1.27 | NC/TJA1050 | U34 | NC/2 | ATDFN8 | NC | UA1 | MT3360_74 | PBGA500 | MT3360 | UA3 | DDR2_8 | BGA96 | K4B1G1646C-HCL9 | UA4 | K9F1G08U0D-PCB0 | ATSOPI48 | K9F1G08U0D-PCB0 | UA5 | EML3419-OOFF06NRR/2 | AFBP6/2 | EML3419-OOFF06NRR | UA6 | NC/3 | AWSO8 | NC | UA7 | SGM811-SXKA4/TR | ASOT143 | SGM811-SXKA4/TR | UA8 | MAXIM2659 | AMAX2659 | MAXIM2659 | UA9 | AMQFN48/P0.4/6X6 | AMQFN48/P0.4/6X6 | MT3336 QFN (48 Pins | UA10 | TCXO3225 | TCXO3225 | 26MHz/0.5ppm | UA11 | TCXO3225 | TCXO3225 | 26MHz/3.3V | UA12 | HK-02 | ASO8 | HK-02 | UA13 | MT6622_QFN40 | AQFN40/P0.4/5X5 | MT6622_QFN40 | UA14 | HK300A | HK300A | | UA15 | EML3419-OOFF06NRR | AFBP6 | EML3419-OOFF06NRR | UA19 | EMP8739-33VF05GRR | ATDFN6 | EMP8739-33VF05GRR | UA22 | SGM4062YDE8G | ATDFN8X2 | SGM4062YDE8G | UA39 | EMP8041-33VF05NRR | ATSOT23-5 | EMP8041-33VF05NRR | XT1 | CRYSTAL | CRY/HC-49USM | 8MHZ | XTA1 | AXT3225 | AXT3225 | 27MHZ | XTA2 | 32.768K | AXT3215AAAAA | 32.768K |
评分
查看全部评分
重要提示:PCB作品文件展下载说明
