查看: 657|回复: 1
I2c测试
天行健,君子以自强不
社区居民
发表于 2015-8-26 08:37:16 | 显示全部楼层 |阅读模式
主函数
#include <string.h>
#include <stdio.h>
#include "Target\44blib.h"
#include "Target\Def.h"
#include "Target\44b.h"
#include "iictest\iic.h"
//   ARMSYS实验十一:IIC接口应用测试(AT24C04)
//   描述:读写IIC接口EEPROM
void * function[][2]=
    (void *)Test_Iic,            "IIC(AT24LCxx)   ",
    0,0
void Isr_Init(void)
    rINTCON=0x5;          //Non-vectored,IRQ enable,FIQ disable //
    rINTMOD=0x0;          //All=IRQ mode//
    rINTMSK=~(BIT_EINT0 | BIT_GLOBAL);
void Main(void)
    char aa;
    int i;
    Port_Init();
    Uart_Init(0,115200);
    Isr_Init();//it's needed.
    Led_Display(0xf);
    Delay(0);
    Beep(0x1);
    Uart_Select(0); //Select UART0//
    Uart_Printf("\n\n*************************************************************************");
    Beep(0x0);
    Uart_Printf("\n*                             立泰电子                                   *");
    Uart_Printf("\n*                     -S3C44B0X功能部件:IIC测试-                         *");
    Uart_Printf("\n*                          Version 1.11                                 *");
    Uart_Printf("\n*                     Email:rao_dali@263.net                            *");
    Uart_Printf("\n*             UART Config--COM:115.2kbps,8Bit,NP,UART0                  *");
    Uart_Printf("\n*------------------Begin to Start IIC test,OK? (Y/N)--------------------*");
    Led_Display(0x0);
    aa= Uart_Getch();
    if((aa=='Y')||(aa=='y'))
    while(1)
            i=0;
            Uart_Printf("\n");
            while(1)
            {   //display menu
                Uart_Printf("%2d:%s",i+1,function[1]);
                i++;
                if((int)(function[0])==0)
                    Uart_Printf("\n");
                    break;
                if((i%4)==0)
                    Uart_Printf("\n");
            Uart_Printf("\nSelect the function to test?");
            i=Uart_GetIntNum();
            i--;
            Uart_Printf("\n");
            if(i>=0 && (i<(sizeof(function)/8)) )
                ( (void (*)(void)) (function[0]) )();
#include <string.h>
#include "..\Target\44b.h"
#include "..\Target\44blib.h"
#include "..\Target\def.h"
#include "iic.h"
#define WRDATA        (1)
#define POLLACK     (2)
#define RDDATA        (3)
#define SETRDADDR   (4)
#define IICBUFSIZE 0x20
U8 _iicData[IICBUFSIZE];
volatile int _iicDataCount;
volatile int _iicStatus;
volatile int _iicMode;
int _iicPt;
void __irq IicInt(void);
void Test_Iic(void)
    unsigned int i,j,save_F,save_PF;
    static U8 data[256];
    Uart_Printf("[IIC Test using AT24LCxx]\n");
    save_F=rPCONF;
    save_PF=rPUPF;
    rPCONF |=0xa;    //PF0:IICSCL, PF1:IICSDA
    rPUPF |=0x3;    //pull-up disable
    pISR_IIC=(unsigned)IicInt;
    rINTMSK=~(BIT_GLOBAL|BIT_IIC);
    rIICCON=(1<<7)|(0<<6)|(1<<5)|(0xf);
    //Enable interrupt, IICCLK=MCLK/16, Enable ACK
    //40Mhz/16/(15+1) = 257Khz
    rIICADD=0x10;   // S3C44B0X slave address
    rIICSTAT=0x10;
    Uart_Printf("Write test data into AT24LCxx\n");
    for(i=0;i<256;i++)
    Wr24LCxx(0xa0,(U8)i,i);
    for(i=0;i<256;i++)
    data=0;
    Uart_Printf("Read test data from AT24LCxx\n");
    for(i=0;i<256;i++)
    Rd24LCxx(0xa0,(U8)i,&(data));
    for(i=0;i<16;i++)
    for(j=0;j<16;j++)
        Uart_Printf("%2x ",data[i*16+j]);
    Uart_Printf("\n");
    rPCONF=save_F;
    rPUPF=save_PF;
void Wr24LCxx(U32 slvAddr,U32 addr,U8 data)
    _iicMode=WRDATA;
    _iicPt=0;
    _iicData[0]=(U8)addr;
    _iicData[1]=data;
    _iicDataCount=2;
    rIICDS=slvAddr;//0xa0
    rIICSTAT=0xf0; //MasTx,Start
    //Clearing the pending bit isn't needed because the pending bit has been cleared.
    while(_iicDataCount!=-1);
    _iicMode=POLLACK;
    while(1)
    rIICDS=slvAddr;
    _iicStatus=0x100;
    rIICCON=0xaf;  //resumes IIC operation.
    while(_iicStatus==0x100);
    if(!(_iicStatus&0x1))
        break; // when ACK is received
    rIICSTAT=0xd0;  //stop MasTx condition
    Delay(1);        //wait until stop condtion is in effect.
    //write is completed.
void Rd24LCxx(U32 slvAddr,U32 addr,U8 *data)
    _iicMode=SETRDADDR;
    _iicPt=0;
    _iicDataCount=1;
    rIICDS=slvAddr;
    _iicMode=RDDATA;
    _iicPt=0;
    _iicDataCount=1;
    rIICDS=slvAddr;
    rIICSTAT=0xb0; //MasRx,Start
    *data=_iicData[1];
    U32 iicSt,i;
    rI_ISPC=BIT_IIC;
    iicSt=rIICSTAT;
    if(iicSt&0x8){} // when bus arbitration is failed.
    if(iicSt&0x4){} // when a slave address is matched with IICADD
    if(iicSt&0x2){} // when a slave address is 0000000b
    if(iicSt&0x1){} // when ACK isn't received
    switch(_iicMode)
    case POLLACK:
        _iicStatus=iicSt;
        break;
    case RDDATA:
        if((_iicDataCount--)==0)
        _iicData[_iicPt++]=rIICDS;
        rIICSTAT=0x90;  //stop MasRx condition
                //too long time...
        //The pending bit will not be set after issuing stop condition.
        break;
                //The last data has to be read with no ack.
        if((_iicDataCount)==0)
        rIICCON=0x2f;    //resumes IIC operation with NOACK.
        else
        rIICCON=0xaf;    //resumes IIC operation with ACK
        break;
    case WRDATA:
        break;
        rIICDS=_iicData[_iicPt++];  //_iicData[0] has dummy.
        for(i=0;i<10;i++);        //for setup time until rising edge of IICSCL
        break;
    case SETRDADDR:
        //Uart_Printf("[S%d]",_iicDataCount);
        break;  //IIC operation is stopped because of IICCON[4]
        break;
    default:
        break;
刚把得
PCB画板兼职QQ469573335
社区居民忠实会员社区劳模最爱沙发社区明星原创达人终身成就奖优秀斑竹奖宣传大使奖
发表于 2015-8-26 09:00:09 | 显示全部楼层
