重要提示:PCB作品文件展下载说明
Name | Value | PCB Decal | Part Type | CE1 | 100uF/10V | CAPE/3216 | CAPE | CE7 | 10uF/25V | CAP1210 | CAPE | CE11 | 10uF/25V | CAP1210 | CAPE | CE13 | 10uF/25V | CAP1210 | CAPE | CE18 | 100uF/10V | CAPE/3216 | CAPE | D2 | IN4007 | SOD-106 | DIO | FB1 | 100R@100MHz | IND-0805 | FB | FB4 | 100R@100MHz | IND-0805 | FB | FB5 | 100R@100MHz | IND-0805 | FB | FB6 | 100R@100MHz | IND-0805 | FB | H1 | | THO | HOLE1 | H2 | | THO | HOLE1 | J1 | BNCí· | JACK-CABLEX5PSEN5AA | BNC | J2 | Fí· | JACK-2PB | F | J3 | Fí· | JACK-2PB | F | J4 | RF_IN | GPS_ANTENNA | GPS_ANTENNA | J7 | 2*14PIN_2.54MM | CON_2.0MM_2X14P | CON_2X14P | J8 | BNCí· | JACK-CABLEX5PSEN5AA | BNC | J9 | BNCí· | JACK-CABLEX5PSEN5AA | BNC | L1 | 2.2uH/2A | CD54 | IND_A | L2 | 2.2uH/2A | CD54 | IND_A | L3 | 3.3nH | IND-0603 | IND | L4 | 10uH | IND-0805 | IND | L5 | 10uH/2A | CD54 | IND_A | L6 | 10uH/2A | CD54 | IND_A | L7 | 10uH/2A | CD54 | IND_A | L8 | 6.2nH | IND_0402 | IND | L9 | 10uH/3A | CD54 | IND_A | M2 | EDU | EDU-10658II8HA | EDU | P5 | | PADD3 | PADD3 | Q1 | MM3904 | SOT-23 | 2SC1815 | Q2 | SI2307DS | SOT-23 | PMOS | Q3 | MM3904 | SOT-23 | 2SC1815 | Q5 | SI2306BDS | SOT-23 | NMOS(SI2306) | Q6 | SI2306BDS | SOT-23 | NMOS(SI2306) | Q7 | SI2307DS | SOT-23 | PMOS | Q8 | MM3904 | SOT-23 | 2SC1815 | Q9 | MM3904 | SOT-23 | 2SC1815 | Q10 | SI2306BDS | SOT-23 | NMOS(SI2306) | Q11 | SI2306BDS | SOT-23 | NMOS(SI2306) | Q12 | MM3906 | SOT-23 | 2SA1015 | Q13 | MM3904 | SOT-23 | 2SC1815 | Q14 | MM3904 | SOT-23 | 2SC1815 | Q15 | MM3904 | SOT-23(T) | 2SC1815 | Q25 | MM3904 | SOT-23 | 2N5551 | Q37 | MM3904 | SOT-23 | 2N5551 | Q40 | MM3904 | SOT-23 | 2SC1815 | Q41 | SI2307DS | SOT-23 | PMOS | RP1 | 47Rx4 | 4XR0603-B | 4XR | RP2 | 47Rx4 | 4XR0603-B | 4XR | RP3 | 47Rx4 | 4XR0603-B | 4XR | RP4 | 47Rx4 | RP0402A | RP0402 | RP5 | 47Rx4 | RP0402A | RP0402 | TC1 | 100uF | CAPE/3216 | CAPE/BILE | TC5 | 100uF | CAPE/3216 | CAPE/BILE | U1 | IMP809TEUR-T | SOT-23 | IMP809 | U2 | LD1117-3.3V | SOT223 | LD1117/A | U3 | SY8009A | SOT23-5 | SY8009A | U4 | SY8009A | SOT23-5 | SY8009A | U5 | AV2012 | QFN28-4X4-AHT | AV2012 | U6 | SY8133 | SOP8-FD\P1.27\B3.9 | SY8133 | U7 | UPG2214TB | SWI-6P-TSSON | UPG2214 | U8 | SY8009B | SOT23-6 | SY8009B | U9 | UPG2214TB | SWI-6P-TSSON | UPG2214 | U10 | LD1117-ADJ | SOT223 | LD1117/A | U11 | GS9092A | LQFP56\P0.5\B14X14 | GS9092A | U12 | M3501B | LQFP64\P0.5\B10X10 | S3501B_2 | U13 | | PAD_7 | PAD_7 | U14 | AMS1117-1.2V | SOT223 | LD1117/A | U15 | M88DS3002B | QFN64 | M88DS3002 | U16 | LD1117-ADJ | SOT223 | LD1117/A | U601 | 74LVC245APW | EEDN_IC_TSSOP20_6.4X0.65 | EEDN_IC_20_74LVC245 | Y1 | 27MHz | SMDOSC | XTAL_P | Y2 | 27MHz | CRY-6X3.6 | XTAL_4 | Y3 | 13.5MHz | CRY-6X3.6 | XTAL_4 |
采用4 层板设计。
PCB 和原理图整套齐全的。
回复可见下载
重要提示:PCB作品文件展下载说明
