3_CTS, EAT_PIN_MODE_UART);
// ret_val =ret_val<<1||eat_pin_set_mode(EAT_PIN34_RTS, EAT_PIN_MODE_UART);
ret_val =ret_val<<1||eat_pin_set_mode(EAT_PIN60_ROW1, EAT_PIN_MODE_GPIO);
ret_val =ret_val<<1||eat_pin_set_mode(EAT_PIN61_ROW2, EAT_PIN_MODE_GPIO);
ret_val =ret_val<<1||eat_pin_set_mode(EAT_PIN62_ROW0, EAT_PIN_MODE_GPIO);
ret_val =ret_val<<1||eat_pin_set_mode(EAT_PIN63_ROW4 , EAT_PIN_MODE_GPIO);
ret_val =ret_val<<1||eat_pin_set_mode(EAT_PIN64_NETLIGHT, EAT_PIN_MODE_GPIO);
ret_val =ret_val<<1||eat_pin_set_mode(EAT_PIN65_PCM_SYNC, EAT_PIN_MODE_GPIO);
ret_val =ret_val<<1||eat_pin_set_mode(EAT_PIN66_PCM_IN, EAT_PIN_MODE_GPIO);
ret_val =ret_val<<1||eat_pin_set_mode(EAT_PIN68_UART1_RI , EAT_PIN_MODE_GPIO);
ret_val =ret_val<<1||eat_pin_set_mode(EAT_PIN69_UART1_DTR, EAT_PIN_MODE_GPIO);
ret_val =ret_val<<1||eat_pin_set_mode(EAT_PIN70_UART1_DCD, EAT_PIN_MODE_GPIO);
ret_val =ret_val<<1||eat_pin_set_mode(EAT_PIN74_SCL , EAT_PIN_MODE_GPIO);
ret_val =ret_val<<1||eat_pin_set_mode(EAT_PIN75_SDA , EAT_PIN_MODE_GPIO);
g_pin_set_result = ret_val;
eat_bool eat_modem_data_parse(u8* buffer, u16 len, u8* param1, u8* param2)
eat_bool ret_val = EAT_FALSE;
u8* buf_ptr = NULL;
/*param:%d,extern_param:%d*/
buf_ptr = (u8*)strstr((const char *)buffer,"param");
if( buf_ptr != NULL)
sscanf((const char *)buf_ptr, "param:%d,extern_param:%d",(int*)param1, (int*)param2);
eat_trace("data parse param1:%d param2:%d",*param1, *param2);
ret_val = EAT_TRUE;
return ret_val;
void eat_app_usb_eint(eat_bool en,EAT_USB_MODE mode)
if(en)
eat_trace(" eat_app_usb_eint ENTRY--TEST+++++++++++++++++");
eat_trace(" eat_app_usb_eint USB PLUG IN-mode=%d",mode);
else
eat_trace(" eat_app_usb_eint ENTRY--TEST-------------------");
* GPIO testing module
eat_bool eat_module_test_gpio(u8 param1, u8 param2)
* example 1
* used eat_gpio_write test EAT_GPIO_TEST1,EAT_GPIO_TEST2
eat_trace("GPIO test param1=%d,param2=%d",param1,param2);
if( 1 == param1 )
if( 1 == param2 )
eat_trace("GPIO test 1,1 start");
eat_gpio_setup(EAT_PIN3_GPIO1, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN4_STATUS, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN5_BPI_BUSI, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN20_COL0, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN21_COL3, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN22_COL2, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN23_ROW3, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN24_COL4, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN25_COL1, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN26_PWM, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN27_GPIO2, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN28_GPIO3, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN29_PCM_CLK, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN30_PCM_OUT, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN60_ROW1, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN61_ROW2, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN62_ROW0, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN63_ROW4 , EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN64_NETLIGHT, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN65_PCM_SYNC, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN66_PCM_IN, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN68_UART1_RI , EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN69_UART1_DTR, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN70_UART1_DCD, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN74_SCL , EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN75_SDA , EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_LOW);
eat_trace("GPIO test 1,1 end");
}else if( 2 == param2)
eat_trace("GPIO test 1,2 start");
eat_gpio_setup(EAT_PIN3_GPIO1, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN4_STATUS, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN5_BPI_BUSI, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN20_COL0, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN21_COL3, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN22_COL2, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN23_ROW3, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN24_COL4, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN25_COL1, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN26_PWM, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN27_GPIO2, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN28_GPIO3, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN29_PCM_CLK, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN30_PCM_OUT, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN60_ROW1, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN61_ROW2, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN62_ROW0, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN63_ROW4 , EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN64_NETLIGHT, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN65_PCM_SYNC, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN66_PCM_IN, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN68_UART1_RI , EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN69_UART1_DTR, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN70_UART1_DCD, EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN74_SCL , EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN75_SDA , EAT_GPIO_DIR_OUTPUT, EAT_GPIO_LEVEL_HIGH);
eat_trace("GPIO test 1,2 end");
}else if(3 == param2)
eat_trace("GPIO test 1,3 start");
eat_gpio_setup(EAT_PIN3_GPIO1, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN4_STATUS, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN5_BPI_BUSI, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN20_COL0, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN21_COL3, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN22_COL2, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN23_ROW3, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN24_COL4, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN25_COL1, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN26_PWM, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN27_GPIO2, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN28_GPIO3, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN29_PCM_CLK, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN30_PCM_OUT, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN60_ROW1, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN61_ROW2, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN62_ROW0, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN63_ROW4 , EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN64_NETLIGHT, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN65_PCM_SYNC, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN66_PCM_IN, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN68_UART1_RI , EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN69_UART1_DTR, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN70_UART1_DCD, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN74_SCL , EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_gpio_setup(EAT_PIN75_SDA , EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_HIGH);
eat_trace("GPIO test 1,3 end");
eat_trace("EAT_PIN3_GPIO1= %d",eat_gpio_read(EAT_PIN3_GPIO1));
eat_trace("EAT_PIN4_STATUS= %d",eat_gpio_read(EAT_PIN4_STATUS));
eat_trace("EAT_PIN5_BPI_BUSI= %d",eat_gpio_read(EAT_PIN5_BPI_BUSI));
eat_trace("EAT_PIN20_COL0= %d",eat_gpio_read(EAT_PIN20_COL0));
eat_trace("EAT_PIN21_COL3= %d",eat_gpio_read(EAT_PIN21_COL3));
eat_trace("EAT_PIN22_COL2= %d",eat_gpio_read(EAT_PIN22_COL2));
eat_trace("EAT_PIN23_ROW3= %d",eat_gpio_read(EAT_PIN23_ROW3));
eat_trace("EAT_PIN24_COL4= %d",eat_gpio_read(EAT_PIN24_COL4));
eat_trace("EAT_PIN25_COL1= %d",eat_gpio_read(EAT_PIN25_COL1));
eat_trace("EAT_PIN26_PWM= %d",eat_gpio_read(EAT_PIN26_PWM));
eat_trace("EAT_PIN27_GPIO2= %d",eat_gpio_read(EAT_PIN27_GPIO2));
eat_trace("EAT_PIN28_GPIO3= %d",eat_gpio_read(EAT_PIN28_GPIO3));
eat_trace("EAT_PIN29_PCM_CLK= %d",eat_gpio_read(EAT_PIN29_PCM_CLK));
eat_trace("EAT_PIN30_PCM_OUT= %d",eat_gpio_read(EAT_PIN30_PCM_OUT));
eat_trace("EAT_PIN60_ROW1= %d",eat_gpio_read(EAT_PIN60_ROW1));
eat_trace("EAT_PIN61_ROW2= %d",eat_gpio_read(EAT_PIN61_ROW2));
eat_trace("EAT_PIN62_ROW0= %d",eat_gpio_read(EAT_PIN62_ROW0));
eat_trace("EAT_PIN63_ROW4= %d",eat_gpio_read(EAT_PIN63_ROW4 ));
eat_trace("EAT_PIN64_NETLIGHT= %d",eat_gpio_read(EAT_PIN64_NETLIGHT));
eat_trace("EAT_PIN65_PCM_SYNC= %d",eat_gpio_read(EAT_PIN65_PCM_SYNC));
eat_trace("EAT_PIN66_PCM_IN= %d",eat_gpio_read(EAT_PIN66_PCM_IN));
eat_trace("EAT_PIN68_UART1_RI= %d",eat_gpio_read(EAT_PIN68_UART1_RI) );
eat_trace("EAT_PIN69_UART1_DTR= %d",eat_gpio_read(EAT_PIN69_UART1_DTR));
eat_trace("EAT_PIN70_UART1_DCD= %d",eat_gpio_read(EAT_PIN70_UART1_DCD));
eat_trace("EAT_PIN74_SCL= %d",eat_gpio_read(EAT_PIN74_SCL ));
eat_trace("EAT_PIN75_SDA= %d",eat_gpio_read(EAT_PIN75_SDA ));
}else if(4 == param2)
eat_pin_set_mode(EAT_PIN25_COL1, EAT_PIN_MODE_GPIO);
eat_pin_set_mode(EAT_PIN22_COL2, EAT_PIN_MODE_GPIO);
eat_pin_set_mode(EAT_PIN21_COL3, EAT_PIN_MODE_GPIO);
eat_pin_set_mode(EAT_PIN24_COL4, EAT_PIN_MODE_GPIO);
eat_gpio_setup(EAT_PIN25_COL1, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN22_COL2, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN21_COL3, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_setup(EAT_PIN24_COL4, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_LOW);
eat_gpio_set_pull(EAT_PIN25_COL1, EAT_TRUE, EAT_GPIO_LEVEL_HIGH);
eat_gpio_set_pull(EAT_PIN22_COL2, EAT_TRUE, EAT_GPIO_LEVEL_HIGH);
eat_gpio_set_pull(EAT_PIN21_COL3, EAT_TRUE, EAT_GPIO_LEVEL_HIGH);
eat_gpio_set_pull(EAT_PIN24_COL4, EAT_TRUE, EAT_GPIO_LEVEL_HIGH);
eat_gpio_set_pull(EAT_PIN26_PWM, EAT_TRUE, EAT_GPIO_LEVEL_HIGH);
}else if(5 == param2)
eat_gpio_setup(EAT_PIN21_COL3, EAT_GPIO_DIR_INPUT, EAT_GPIO_LEVEL_LOW); |
