TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 20875
M3606.zip
(612 KB, 下载次数: 11)
C2 | 10uF/16V | CAP1206 | CAP | C3 | 0.1uF | CAP0402 | CAP | C4 | 0.1uF | CAP0402 | CAP | C5 | 0.1uF | CAP0402 | CAP | C6 | 0.1uF | CAP0402 | CAP | C7 | 0.1uF | CAP0402 | CAP | C8 | 1uF | CAP0402 | CAP | C9 | 22pF | CAP0402 | CAP | C10 | 0.1uF | CAP0402 | CAP | C11 | 10uF | CAP0805 | CAP | C12 | NC | CAP0402 | CAP | C13 | 0.1uF | CAP0402 | CAP | C14 | 0.1uF | CAP0402 | CAP | C15 | 10uF | CAP0805 | CAP | C16 | 30pF | CAP0402 | CAP | C17 | 30pF | CAP0402 | CAP | C18 | 1uF | CAP0402 | CAP | C19 | 0.1uF | CAP0402 | CAP | C20 | 47uF/6V | CAPE/3216 | CAPE/BILE | C21 | 0.1uF | CAP0402 | CAP | C22 | 4.7uF | CAP0805 | CAP | C23 | 0.1uF | CAP0402 | CAP | C24 | 0.1uF | CAP0402 | CAP | C25 | 0.1uF | CAP0402 | CAP | C26 | 0.1uF | CAP0402 | CAP | C27 | 0.1uF | CAP0402 | CAP | C28 | 0.1uF | CAP0402 | CAP | C29 | 0.1uF | CAP0402 | CAP | C30 | 0.1uF | CAP0402 | CAP | C31 | 0.1uF | CAP0402 | CAP | C32 | 0.1uF | CAP0402 | CAP | C33 | 0.1uF | CAP0402 | CAP | C34 | 0.1uF | CAP0402 | CAP | C35 | 0.1uF | CAP0402 | CAP | C36 | 47uF/6V | CAPE/3216 | CAPE/BILE | C37 | 0.1uF | CAP0402 | CAP | C38 | 0.1uF | CAP0402 | CAP | C39 | 0.1uF | CAP0402 | CAP | C40 | 0.1uF | CAP0402 | CAP | C41 | 10NF | CAP0402 | CAP | C42 | 0.1uF | CAP0402 | CAP | C43 | 0.1uF | CAP0402 | CAP | C44 | 0.1uF | CAP0402 | CAP | C45 | 47uF/6V | CAPE/3216 | CAPE/BILE | C46 | 0.1uF | CAP0402 | CAP | C47 | 0.1uF | CAP0402 | CAP | C48 | 0.1uF | CAP0402 | CAP | C49 | 0.1uF | CAP0402 | CAP | C50 | 0.1uF | CAP0402 | CAP | C51 | 47uF/6V | CAPE/3216 | CAPE/BILE | C52 | 0.1uF | CAP0402 | CAP | C53 | 1uF | CAP0402 | CAP | C54 | 4.7uF | CAP0805 | CAP | C55 | 4.7uF | CAP0805 | CAP | C56 | 0.1uF | CAP0402 | CAP | C57 | 0.1uF | CAP0402 | CAP | C58 | 10uF | CAP0805 | CAP | C59 | 0.1uF | CAP0402 | CAP | C60 | 0.1uF | CAP0402 | CAP | C61 | 0.1uF | CAP0402 | CAP | C62 | 0.1uF | CAP0402 | CAP | C63 | 0.1uF | CAP0402 | CAP | C64 | 0.1uF | CAP0402 | CAP | C65 | 0.1uF | CAP0402 | CAP | C66 | 0.1uF | CAP0402 | CAP | C67 | 0.1uF | CAP0402 | CAP | C68 | 0.1uF | CAP0402 | CAP | C69 | 0.1uF | CAP0402 | CAP | C70 | 0.1uF | CAP0402 | CAP | C71 | 0.1uF | CAP0402 | CAP | C72 | 0.1uF | CAP0402 | CAP | C73 | 0.1uF | CAP0402 | CAP | C74 | 0.1uF | CAP0402 | CAP | C75 | 0.1uF | CAP0402 | CAP | C76 | 1uF | CAP0402 | CAP | C77 | 0.1uF | CAP0402 | CAP | C78 | 10uF | CAP0805 | CAP | C79 | 10uF | CAP0805 | CAP | C80 | 220pF | CAP0402 | CAP | C81 | 220pF | CAP0402 | CAP | C82 | 0.1uF | CAP0402 | CAP | C83 | 0.01uF | CAP0402 | CAP | C84 | 0.1uF | CAP0402 | CAP | C85 | 0.1uF | CAP0402 | CAP | C86 | 0.1uF | CAP0402 | CAP | C87 | 0.1uF | CAP0402 | CAP | C88 | 0.01uF | CAP0402 | CAP | C89 | 10uF | CAP0805 | CAP | C90 | 0.1uF | CAP0402 | CAP | C91 | 0.1uF | CAP0402 | CAP | C92 | 10uF | CAP0805 | CAP | C94 | 0.1uF | CAP0402 | CAP | C95 | 0.1uF | CAP0402 | CAP | C96 | 0.1uF | CAP0402 | CAP | C97 | 0.1uF | CAP0402 | CAP | C98 | 10NF | CAP0402 | CAP | C99 | 0.1uF | CAP0402 | CAP | C105 | 0.1uF | CAP0402 | CAP | C106 | 0.1uF | CAP0402 | CAP | C107 | 0.1uF | CAP0402 | CAP | C109 | 10uF | CAP0805 | CAP | C110 | 1uF | CAP0402 | CAP | C111 | 10uF | CAP0805 | CAP | C112 | 10uF | CAP0805 | CAP | C113 | 10uF | CAP0805 | CAP | C122 | 0.1uF | CAP0402 | CAP | C125 | 0.1uF,20% | CAP0402 | CAP | C126 | 0.1uF,20% | CAP0402 | CAP | C127 | 0.1uF | CAP0603 | CAP | C128 | 10uF | CAP0805 | CAP | C130 | 10NF | CAP0402 | CAP | C132 | 0.1uF | CAP0402 | CAP | C133 | 0.1uF,20% | CAP0402 | CAP | C136 | 10uF | CAP0805 | CAP | C137 | 220uF/10V | CAPE/2.5/6 | CAPE | C138 | 0.1uF | CAP0402 | CAP | C141 | 10uF | CAP0805 | CAP | C144 | 1uF | CAP0402 | CAP | C145 | 0.1uF | CAP0402 | CAP | C147 | 1uF | CAP0402 | CAP | C150 | 0.1uF | CAP0402 | CAP | C172 | 1uF | CAP0402 | CAP | C174 | 0.1uF | CAP0402 | CAP | C184 | 1nF/2KV | CAP-5 | CAP | C213 | 0.1uF | CAP0402 | CAP | C215 | 1uF | CAP0402 | CAP | C216 | 1uF | CAP0402 | CAP | C217 | 1uF | CAP0402 | CAP | C218 | 0.1uF | CAP0402 | CAP | C220 | 0.1uF | CAP0402 | CAP | C221 | 3.3NF | CAP0402 | CAP | C223 | 10uF | CAP0805 | CAP | C224 | 10uF | CAP0805 | CAP | C225 | 10uF | CAP0805 | CAP | C226 | 10uF | CAP0805 | CAP | C227 | 10uF | CAP0402 | CAP | C240 | 0.1uF | CAP0402 | CAP | C306 | 0.1uF | CAP0402 | CAP | C307 | 22pF | CAP0402 | CAP | C309 | 0.1uF | CAP0402 | CAP | C313 | 0.1uF | CAP0402 | CAP | C314 | 22pF | CAP0402 | CAP | C316 | 0.1uF | CAP0402 | CAP | C485 | 22NF | CAP0402 | CAP | C486 | 0.1uF | CAP0402 | CAP | C487 | 0.1uF | CAP0402 | CAP | CON1 | CON4-2.0MM-90 | CON-4/2MM-90 | CON-4A | CON3 | 2.54MM,2*13PIN,DIP | CON-2X13H-2.54MM-DIP | CON_P13X2 | CON4 | 2.54MM,2*13PIN,DIP | CON-2X13H-2.54MM-DIP | CON_P13X2 | D1 | 1N4007 | DIO-214AC | DIO | D2 | SS24 | DIO-214AC | DIO | D3 | BAV99 | SOT-23 | BAV99 | D7 | SS24 | DIO-214AC | DIO | D9 | LL4148 | DIO-1206 | DIO | DZ1 | TL431_0.5% | SOT-23 | TVL431 | EC1 | 100uF/25V | CAPE/2.5/6 | CAPE | EC2 | 220uF/16V | CAPE/2.5/6 | CAPE | EC3 | 100uF/25V | CAPE/2.5/6 | CAPE | ESD1 | NC | CAP0402 | ESD1 | ESD2 | NC | CAP0402 | ESD1 | F3 | 0R | F1206 | FUSE_1 | FB1 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB2 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB3 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB4 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB5 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB6 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB7 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB8 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB9 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB10 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB11 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB12 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB13 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB14 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB15 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB16 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB17 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB18 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB19 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB20 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB21 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB22 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB23 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | FB25 | 60ohm@100MHz | EEDN_CM_FB_0603 | FB | H1 | | HOLE/3.3MM | HOLE1 | H2 | | HOLE/3.3MM | HOLE1 | H7 | | HOLE/3.3MM | HOLE1 | H8 | | HOLE/3.3MM | HOLE1 | H11 | | HOLE/3.3MM | HOLE1 | H14 | | HOLE/3.3MM | HOLE1 | J1 | DC5.5 | DC-JACK | DC_5.5MM | J2 | 1*6Pin,2.0mm/NC | CON-6/2MM | CON-6 | J3 | H1102 | H1102 | H1102 | J5 | HDMI | HDMI\YKF45-7012 | HDMI_0 | J6 | USB-4P-AF-90 | ST-001-03A | USBA_DIP4P-90-1 | J8 | NC | CON-2/2MM(LP) | CON-2 | J20 | | RJ45HL1W60BQ16MM | RJ45_LED | L2 | 2.2uH/2A | CD43 | IND_SMD | L6 | 2.7uH | IND-0805 | IND | L9 | 22uH | LGB8X10 | IND_DIP | L10 | 10uH/3A | CD75 | IND_A | L35 | 2.2uH/2A | CD43 | IND_SMD | L36 | 2.2uH/2A | CD43 | IND_SMD | M1 | | MTOP | MTOP | M2 | | MTOP | MTOP | M3 | | MTOP | MTOP | M4 | | MTOP | MTOP | M5 | | MTOP | MTOP | M6 | | MTOP | MTOP | P1 | | PAD | PAD | P5 | | PAD | PAD | Q1 | MMBT3904 | SOT23 | Q\NPN | Q2 | MMBT3906 | SOT23 | Q\PNP | Q3 | MMBT3904 | SOT23 | Q\NPN | Q4 | MMBT3904 | SOT23 | Q\NPN | Q5 | MMBT3906 | SOT23 | Q\PNP | Q6 | MMBT3906 | SOT23 | Q\PNP | Q7 | MMBT3904 | SOT23 | Q\NPN | Q9 | HD882 | SOT-89 | 2SC1803 | Q13 | S8550 | SOT23 | Q\PNP | Q14 | MMBT3904 | SOT23 | Q\NPN | Q15 | MMBT3904 | SOT23 | Q\NPN | Q16 | MMBT3904 | SOT23 | Q\NPN | QP2 | AO4407 | SO8NB | PMOS(PJ4435) | QP3 | AO4407 | SO8NB | PMOS(PJ4435) | QP4 | AO4407 | SO8NB | PMOS(PJ4435) | QP5 | AO4407 | SO8NB | PMOS(PJ4435) | R1 | 10K | RES0402 | RES | R2 | 15K 1% | RES0402 | RES | R3 | 68K 1% | RES0402 | RES | R4 | 100K | RES0402 | RES | R5 | 100K | RES0402 | RES | R6 | 15K_1% | RES0402 | RES | R7 | 68K_1% | RES0402 | RES | R8 | 100K | RES0402 | RES | R9 | 100K | RES0402 | RES | R10 | 100K | RES0402 | RES | R11 | 100K | RES0402 | RES | R12 | 10K | RES0402 | RES | R13 | 10K_1% | RES0402 | RES | R14 | 3.3K | RES0402 | RES | R15 | 1K | RES0402 | RES | R16 | 15K_1% | RES0402 | RES | R17 | 33R | RES0402 | RES | R18 | 33R | RES0402 | RES | R19 | 10K | RES0402 | RES | R20 | 1M | RES0402 | RES | R21 | 4.7K | RES0402 | RES | R22 | 33R | RES0402 | RES | R23 | 1M_1% | RES0402 | RES | R24 | 10K | RES0402 | RES | R25 | 470R | RES0402 | RES | R31 | 10K | RES0402 | RES | R32 | 4.7K | RES0402 | RES | R33 | 4.7K | RES0402 | RES | R34 | 4.7K | RES0402 | RES | R35 | 33R | RES0402 | RES | R36 | 1K_1% | RES0402 | RES | R37 | 1K_1% | RES0402 | RES | R38 | 1K_1% | RES0402 | RES | R39 | 1K_1% | RES0402 | RES | R40 | 10K | RES0402 | RES | R41 | 2.2K | RES0402 | RES | R42 | 2.2K | RES0402 | RES | R43 | 10K | RES0402 | RES | R45 | 10K | RES0402 | RES | R46 | 0R | RES0402 | RES | R47 | 75R | RES0402 | RES | R48 | 4.7K | RES0402 | RES | R49 | 75R | RES0402 | RES | R50 | 75R | RES0402 | RES | R51 | 330R | RES0402 | RES | R52 | 10K | RES0402 | RES | R53 | 100K | RES0402 | RES | R54 | 4.7K | RES0402 | RES | R55 | 330R | RES0402 | RES | R56 | 33R | RES0402 | RES | R57 | 0R | RES0402 | RES | R58 | 33R | RN_0402 | RN | R59 | 33R | RN_0402A | RN | R60 | 150R | RES0402 | RES | R61 | NC | RES0402 | RES | R62 | NC | RES0402 | RES | R63 | 560R | RES0402 | RES | R64 | 10K | RES0402 | RES | R65 | 2.2K | RES0402 | RES | R66 | 10K(NC) | RES0402 | RES | R67 | 10K(NC) | RES0402 | RES | R68 | 100K | RES0402 | RES | R76 | 2.2K | RES0402 | RES | R78 | 75R | RES0402 | RES | R83 | 1K | RES0402 | RES | R84 | 1K | RES0402 | RES | R85 | 15K_1% | RES0402 | RES | R89 | 10K | RES0402 | RES | R90 | 12.1K 1% | RES0402 | RES | R91 | NC | RES0402 | RES | R94 | 33R | RES0402 | RES | R95 | 33R | RES0402 | RES | R98 | 0R | RES0402 | RES | R99 | 1K | RES0402 | RES | R101 | 47K | RES0402 | RES | R126 | 10R | RES0402 | RES | R129 | 2.2K | RES0402 | RES | R130 | 470R | RES0402 | RES | R134 | 1K | RES0402 | RES | R135 | 4.7K | RES0402 | RES | R136 | 10R | RES0402 | RES | R137 | 10R | RES0402 | RES | R138 | 1K | RES0402 | RES | R139 | 33R | RES0402 | RES | R142 | 3.3K | RES0402 | RES | R143 | 499K_1% | RES0402 | RES | R144 | 33R | RES0402 | RES | R145 | 33R | RES0402 | RES | R146 | 5.1K | RES0402 | RES | R148 | 1K | RES0402 | RES | R150 | 0R | RES0402 | RES | R152 | 1M | RES0402 | RES | R153 | 47K | RES0402 | RES | R154 | 47K | RES0402 | RES | R155 | 5.1K | RES0402 | RES | R156 | NC | RES0402 | RES | R160 | 33R | RES0402 | RES | R161 | 10K | RES0402 | RES | R162 | 10K | RES0402 | RES | R164 | 10K | RES0402 | RES | R165 | 51R | RES0402 | RES | R170 | 1K | RES0402 | RES | R171 | 1K | RES0402 | RES | R177 | 0.02R_1% | RES2010 | RES | R178 | 1.5K | RES0402 | RES | R179 | 3.9K | RES0402 | RES | R180 | 0.2R_1% | RES2010 | RES | R183 | 27K | RES0402 | RES | R184 | 1.8K | RES0402 | RES | R185 | 1.8K | RES0402 | RES | R186 | 0.2R_1% | RES2010 | RES | R187 | 10K_1% | RES0402 | RES | R188 | 12K | RES0402 | RES | R189 | 4.7K | RES0402 | RES | R190 | 39R_1% | RES0402 | RES | R191 | 10K | RES0402 | RES | R192 | 10K | RES0402 | RES | R193 | 10K(NC) | RES0402 | RES | R194 | 10K | RES0402 | RES | R195 | 15K | RES0402 | RES | R197 | 33R | RES0402 | RES | R198 | 33R | RES0402 | RES | R199 | 100K | RES0402 | RES | R202 | 75R | RES0402 | RES | R255 | 10K(NC) | RES0402 | RES | R256 | 10K | RES0402 | RES | R260 | 10K | RES0402 | RES | R261 | 10K | RES0402 | RES | R263 | 10K | RES0402 | RES | R265 | 10K | RES0402 | RES | R266 | 10K(NC) | RES0402 | RES | R267 | 10K(NC) | RES0402 | RES | R269 | 10K(NC) | RES0402 | RES | R272 | 470R | RES0402 | RES | R273 | 10K(NC) | RES0402 | RES | R276 | 10K | RES0402 | RES | R277 | 10K | RES0402 | RES | R278 | 4.7K | RES0402 | RES | R284 | 10K(NC) | RES0402 | RES | R287 | 2.4K_1% | RES0402 | RES | R289 | 10K(NC) | RES0402 | RES | R291 | 10K | RES0402 | RES | R296 | 10K | RES0402 | RES | R300 | 10K | RES0402 | RES | R305 | 10K(NC) | RES0402 | RES | R306 | 10K | RES0402 | RES | R310 | 10K(NC) | RES0402 | RES | R311 | 330R | RES0402 | RES | R313 | 10K | RES0402 | RES | R322 | 10K | RES0402 | RES | R323 | 10K | RES0402 | RES | R324 | 10K(NC) | RES0402 | RES | R325 | 4.7K | RES0402 | RES | R326 | 4.7K | RES0402 | RES | R327 | 30K | RES0402 | RES | R328 | 33R | RES0402 | RES | R329 | 33R | RES0402 | RES | R552 | 15K_1% | RES0402 | RES | R554 | 15K_1% | RES0402 | RES | R557 | 33K_1% | RES0402 | RES | R559 | 15K_1% | RES0402 | RES | R616 | 49.9R_1% | RES0402 | RES | R617 | 49.9R_1% | RES0402 | RES | R618 | 49.9R_1% | RES0402 | RES | R619 | 49.9R_1% | RES0402 | RES | RN1 | 33R | RN_0402 | RN | RN2 | 33R | RN_0402 | RN | RN3 | 33R | RN_0402 | RN | RN4 | 33R | RN_0402 | RN | RN5 | 33R | RN_0402 | RN | RN6 | 33R | RN_0402 | RN | U1 | AP3503/MP1484 | SOIC8 | MPS1482A | U2 | H5PS1G63EFR-S6C(800Mhz) | FPBGA84\P0.8\B8X13 | HY5PS1G1631C(64MX16) | U3 | AP3407 | SOT23-5 | SY8009A | U4 | S25FL032 | SOP8-300 | S25FL004/008/016 | U5 | RCLAMP0524P/NC | ESD0524 | RCLAMP0524P | U8 | NC/RClamp0504P | ESD0504 | RCLAMP0504P | U10 | M3606-LT | LQFP256\P0.4\B28X28\EP9X9 | M3606-LT | U13 | AR8032 | QFN32\B5X5 | AR8032 | U15 | AT24C04 | SOP8 | 24C02 | U18 | AP3407 | SOT23-5 | SY8009A | U19 | S-8254AAKFT | SOP_16_0.65MM | S-8254 | U21 | ALPU_MR004 | 6L_SOT23 | ALPU_MR | U22 | RCLAMP0524P/NC | ESD0524 | RCLAMP0524P | U23 | CK235 | SO-8 | CK235 | U24 | CT1088 | SOP_14_1.25MM | CT1088 | U29 | AP3407 | SOT23-6 | SY8009B | Y1 | 27MHz | CRY-6X3.6 | XTAL_4 |
