查看: 748|回复: 0
TortoiseGit 2.1.0.0 发布,Git客户端
社区居民忠实会员社区劳模原创达人终身成就奖
发表于 2016-3-28 21:40:15 | 显示全部楼层 |阅读模式
淡漠悠然    11小时前
TortoiseGit 2.1.0.0 发布了,TortoiseGit (海龟Git)是TortoiseSVN的Git版本,tortoisegit用于迁移TortoiseSVN到TortoiseGit,一直以来Git在Windows平台没有好用GUI客户端,现在tortoisegit的出现给Windows开发者带来福音。
更新日志:
We disabled the stripping of comments on commit messages by default again (see issue #2715)
已知问题:
TortoiseGit may crash at startup if git config is broken (see issue #2745)
新特性:
Update PuTTY to 0.67
Fixed issue #2733: Hide commit button after file add when invoked from commit dialog
Fixed issue #2734: When pull.rebase is set, start rebase just after fetch, not after OK button
Fixed issue #2731: Improved autolist.txt regex for C# files
Update libgit2 to 0.24.0
Update Scintilla to 3.6.4
bug修复:
Fixed issue #2719: Commit & Push in CommitDlg doesn't respect default remote and pushbranch settings
Fixed issue #1902: CommitDlg: Do not lose SQUASH_MSG contents
Fixed issue #2732: Commit dialog: Message field should have focus (when patch is shown)
Fixed issue #2730: Pull with rebase with preserve merges not working for noops
Fixed issue #2728: Cherry Pick is not working in case of conflict and empty message
Fixed issue #2715: Cannot commit with a commit message starting with a hash (#) character
Updated libgit to 2.5.5 which includes fixes for CVE-2016-2315 and CVE-2016-2324
Fix the the credential helper settings dialog
下载地址:
for 32-bit OS
for 64-bit OS
更多关于: TortoiseGit 的详细信息
相关资讯
Git 项目推荐 | Java 用户线程模型
Git 项目推荐 | 基于 zynq 的 VGA 驱动
Git For Windows 2.7.4 发布下载
Git 2.4.11 2.5.5 2.6.6 2.7.4 发布
Git 项目推荐 | jQuery 原生滑动插件
Git for Windows 2.7.3 发布
Git 项目推荐 | 基于 MQTT 的实时发布订阅平台
Git 项目推荐 | ThinkPHP V5.0 版本
SmartGit 7.2 发布,Git 客户端
Git 2.7.3 和 2.8.0 RC2 发布
