游客,本帖隐藏的内容需要积分高于 600 才可浏览,您当前积分为 0
板子有以下主要元件。
J1 | PIN-HEADER-9P_2.5_DIP | PIN-HEADER-9P_2.5_DIP | J3 | PIN-HEADER-14P_2.5_DIP | PIN-HEADER-14P_2.5_DIP | J4 | SATA_POWER_15P | SATA_POWER_15P | J5 | BOX-HEADER-20P_DIP180D | BOX-HEADER-20P_DIP180D | J6 | BOX-HEADER-20P_DIP180D | BOX-HEADER-20P_DIP180D | J7 | BOX-HEADER-20P_DIP180D | BOX-HEADER-20P_DIP180D | L1 | 1206_1.9_SMD | 1206_1.9_SMD | LB2 | L_5.3X1.9_SCDS4D28T | L_5.3X1.9_SCDS4D28T | LB3 | L_5.3X1.9_SCDS4D28T | L_5.3X1.9_SCDS4D28T | LO1 | 0805_0.73_SMD | 0805_0.73_SMD | LS1 | BEES_11MM | BEES_11MM | O2 | OSCILLATOR_5.0X3.2_SMD | OSCILLATOR_5.0X3.2_SMD | RN1 | RA-8P4R-0.75X0.25_SMD0.5 | RA-8P4R-0.75X0.25_SMD0.5 | RN2 | RA-8P4R-0.75X0.25_SMD0.5 | RA-8P4R-0.75X0.25_SMD0.5 | RN3 | RA-8P4R-0.75X0.25_SMD0.5 | RA-8P4R-0.75X0.25_SMD0.5 | RN4 | RA-8P4R-0.75X0.25_SMD0.5 | RA-8P4R-0.75X0.25_SMD0.5 | RN5 | RA-8P4R-0.75X0.25_SMD0.5 | RA-8P4R-0.75X0.25_SMD0.5 | SD8 | WLCSP25_2.05X2.05_0.225F | WLCSP25_2.05X2.05_0.225 | SD9 | WLCSP25_2.05X2.05_0.225F | WLCSP25_2.05X2.05_0.225 | SD10 | WLCSP25_2.05X2.05_0.225F | WLCSP25_2.05X2.05_0.225 | SD11 | WLCSP25_2.05X2.05_0.225BA | WLCSP25_2.05X2.05_0.225 | SD12 | WLCSP25_2.05X2.05_0.225C | WLCSP25_2.05X2.05_0.225 | SD13 | WLCSP25_2.05X2.05_0.225A | WLCSP25_2.05X2.05_0.225 | SD14 | WLCSP25_2.05X2.05_0.225D | WLCSP25_2.05X2.05_0.225 | SD15 | WLCSP25_2.05X2.05_0.225EA | WLCSP25_2.05X2.05_0.225 | SD16 | SHUIYIN | SHUIYIN | SQ1 | SOT23_3X1.2 | SOT23_3X1.2 | SQ2 | SOT23_3X1.2 | SOT23_3X1.2 | SQ3 | SOT23_3X1.2 | SOT23_3X1.2 | SQ4 | SOT23_3X1.2 | SOT23_3X1.2 | SQ5 | SOT23_3X1.2 | SOT23_3X1.2 | SQ6 | SOT23_3X1.2 | SOT23_3X1.2 | SQ7 | SOT23_3X1.2 | SOT23_3X1.2 | SQ8 | SOT23_3X1.2 | SOT23_3X1.2 | U1 | CSG324_15X15_0.35 | CSG324_15X15_0.35 | U6 | SOP-8P_5.08X3.81_0.6X3.1 | SOP-8P_5.08X3.81_0.6X3.1 | U7 | SOT23_3X1.2 | SOT23_3X1.2 | U8 | SOT23_3X1.2 | SOT23_3X1.2 | U9 | SOT23_3X1.2 | SOT23_3X1.2 | U10 | SOT23_3X1.2 | SOT23_3X1.2 | U11 | SOT23_3X1.2 | SOT23_3X1.2 | U12 | BGA96_9X13_0.35 | BGA96_9X13_0.35 | U13 | SOT23_3X1.2 | SOT23_3X1.2 | U14 | SOT23_3X1.2 | SOT23_3X1.2 | U15 | SOT23_3X1.2 | SOT23_3X1.2 | U16 | SOT23_3X1.2 | SOT23_3X1.2 | U17 | SOT23_3X1.2 | SOT23_3X1.2 | U18 | SOT23_3X1.2 | SOT23_3X1.2 | U19 | SOT23_3X1.2 | SOT23_3X1.2 | U20 | SOT23_3X1.2 | SOT23_3X1.2 | U21 | BOX-HEADER-24P_DIP180D | BOX-HEADER-24P_DIP180D | U22 | SOT23_3X1.2 | SOT23_3X1.2 | U23 | SOT23_3X1.2 | SOT23_3X1.2 | U24 | WAFER-4P_2.5_DIP180D | WAFER-4P_2.5_DIP180D | U25 | SOT23_3X1.2 | SOT23_3X1.2 | U26 | SOT23_3X1.2 | SOT23_3X1.2 | U28 | SOT223_3.3X6.3_2.15X0.95 | SOT223_3.3X6.3_2.15X0.95 | U30 | DFN-10P_2.95X2.95_0.8X0.24 | DFN-10P_2.95X2.95_0.8X0.24 | U31 | DFN-10P_2.95X2.95_0.8X0.24 | DFN-10P_2.95X2.95_0.8X0.24 | U40 | SOT223_3.3X6.3_2.15X0.95 | SOT223_3.3X6.3_2.15X0.95 | U41 | TO252-3L_6.58X5.57 | TO252-3L_6.58X5.57 | Z1 | ZENER_2.5X2.3_SMB | ZENER_2.5X2.3_SMB | Z2 | ZENER_0.71X0.43_SOD323F | ZENER_0.71X0.43_SOD323F |
