MSP430单片机LED点阵控制程序。测试通过。
#include "msp430x14x.h"
#define uchar unsigned char
#define uint unsigned int
#define LT0 P3OUT&=~BIT0
#define LT1 P3OUT|=BIT0
#define SK0 P3OUT&=~BIT1
#define SK1 P3OUT|=BIT1
#define EN0 P3OUT&=~BIT2
#define EN1 P3OUT|=BIT2
#define R0 P3OUT&=~BIT3
#define R1 P3OUT|=BIT3
#define LS P1OUT
uchar count_move=0; //移动计数器
uchar flag_move=0; //移动标准位
uchar Move=0; //移位
uchar line=0; //扫描的行
uint zimuo=0; //字模计数器
uint all_date; //定义汉字字模的长度
uchar BUFF[10]; //显示缓冲区,多加1个汉字,即2个字节
const char Table[]={
0xFF,0xFF,0x00,0x80,0xDF,0xFD,0xDF,0xFD,0x01,0xC0,0xDD,0xDD,0xDD,0xDD,0xDD,0xDD,
0xDD,0xDD,0xED,0xC3,0xF5,0xDF,0xF9,0xDF,0xFD,0xDF,0x01,0xC0,0xFD,0xDF,0xFF,0xFF,/*"西",0*/
0xFF,0xFF,0xFD,0xFE,0xF3,0xFE,0xF7,0xFE,0x0F,0xC0,0xFF,0xFE,0xFF,0xFE,0xF8,0xFE,
0x7B,0xFD,0x7B,0xFB,0xBB,0xE7,0xDB,0xCF,0xEB,0xEF,0xF5,0xBF,0x0E,0xC0,0xFF,0xFF,/*"达",1*/
0x7F,0xFF,0x7F,0xFF,0x7F,0xFF,0x03,0xE0,0x7B,0xEF,0x7B,0xEF,0x03,0xE0,0x7B,0xEF,//电
0x7B,0xEF,0x7B,0xEF,0x03,0xE0,0x7B,0xEF,0x7F,0xBF,0x7F,0xBF,0xFF,0x80,0xFF,0xFF,
0xFF,0xFF,0x03,0xF0,0xFF,0xFB,0xFF,0xFD,0xFF,0xFE,0x7F,0xFF,0x7F,0xFF,0x7F,0xDF,//子
0x00,0x80,0x7F,0xFF,0x7F,0xFF,0x7F,0xFF,0x7F,0xFF,0x7F,0xFF,0x5F,0xFF,0xBF,0xFF,
0xBF,0xFF,0x7F,0xFF,0x03,0x80,0xFB,0xDF,0xDD,0xEF,0x9F,0xFF,0xDF,0xFF,0x00,0x80,//安
0xEF,0xFB,0xEF,0xFB,0xEF,0xFD,0x9F,0xFE,0x7F,0xFF,0x9F,0xFC,0xE7,0xE3,0xF8,0xF7,
0x7F,0xFF,0x7F,0xFF,0xBF,0xFE,0xDF,0xFD,0xEF,0xF3,0xF7,0xC7,0x03,0xE0,0x7D,0xFF,//全
0x7F,0xFF,0x7F,0xF7,0x07,0xE0,0x7F,0xFF,0x7F,0xFF,0x7F,0xDF,0x01,0x80,0xFF,0xFF,
0xFD,0xFF,0x3B,0xC0,0xF3,0xFF,0xFB,0xFF,0xFF,0xFF,0x1F,0x80,0xF8,0xFE,0x7B,0xFB,//运
0x7B,0xF7,0xBB,0xEF,0xDB,0xC1,0x0B,0xCC,0xFB,0xEF,0xE5,0xFF,0x1E,0x80,0xFF,0xFF,
0xEF,0xFF,0xC7,0xFF,0x73,0xC0,0xFD,0xFF,0xEE,0xFF,0xCF,0xFF,0x27,0x80,0xF3,0xFB,//行
0xF5,0xFB,0xF6,0xFB,0xF7,0xFB,0xF7,0xFB,0xF7,0xFB,0xF7,0xFB,0xF7,0xFA,0xF7,0xFD,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFD,0x0F,0xFC,0xFF,0xFC,0xFF,0xFC,0xFF,0xFC,
0xFF,0xFC,0xFF,0xFC,0xFF,0xFC,0xFF,0xFC,0xFF,0xFC,0x0F,0xC0,0xFF,0xFF,0xFF,0xFF,/*"1",0*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x1F,0xF0,0xE7,0xC7,0xFB,0xCF,0xF3,0xCF,0xFF,0xE7,
0xFF,0xFB,0xFF,0xFC,0x3F,0xFF,0xCF,0xDF,0xF7,0xCF,0x03,0xE0,0xFF,0xFF,0xFF,0xFF,/*"2",1*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0xF8,0xF3,0xE3,0xF3,0xE7,0xFF,0xF3,0x3F,0xFC,
0xFF,0xE3,0xFF,0xCF,0xFF,0xCF,0xF3,0xCF,0xF3,0xE3,0x0F,0xF8,0xFF,0xFF,0xFF,0xFF,/*"3",2*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF3,0xFF,0xF0,0x7F,0xF1,0xBF,0xF1,0xDF,0xF1,
0xE7,0xF1,0xFB,0xF1,0x01,0x80,0xFF,0xF1,0xFF,0xF1,0x3F,0x80,0xFF,0xFF,0xFF,0xFF,/*"4",3*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0xC0,0xEF,0xFF,0xEF,0xFF,0xF7,0xFF,0x17,0xF0,
0xE7,0xE7,0xFF,0xCF,0xFF,0xCF,0xF3,0xCF,0xFB,0xE3,0x07,0xF8,0xFF,0xFF,0xFF,0xFF,/*"5",4*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x3F,0xE0,0x8F,0xCF,0xE7,0xFF,0xF7,0xFF,0x33,0xE0,
0xC3,0xCF,0xF3,0x9F,0xF3,0x9F,0xE7,0x9F,0xCF,0xCF,0x1F,0xF0,0xFF,0xFF,0xFF,0xFF,/*"6",5*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0x80,0xE7,0xDF,0xF7,0xEF,0xFF,0xF7,0xFF,0xFB,
0xFF,0xFD,0xFF,0xFE,0xFF,0xFE,0x7F,0xFE,0x7F,0xFE,0x7F,0xFE,0xFF,0xFF,0xFF,0xFF,/*"7",0*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0xF0,0xE3,0xC7,0xF3,0xCF,0xE3,0xCF,0x8F,0xF7,
0x4F,0xF8,0xF3,0xE3,0xF9,0xCF,0xF9,0xCF,0xF3,0xE7,0x0F,0xF8,0xFF,0xFF,0xFF,0xFF,/*"8",1*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0xF8,0xF3,0xE3,0xF9,0xEF,0xF9,0xCF,0xF9,0xCF,
0xF3,0xC3,0x07,0xCC,0xFF,0xE7,0xFF,0xE7,0xF3,0xF1,0x07,0xFC,0xFF,0xFF,0xFF,0xFF,/*"9",2*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x3F,0xF0,0xCF,0xE7,0xE7,0xCF,0xF3,0x9F,0xF3,0x9F,
0xF3,0x9F,0xF3,0x9F,0xF3,0x9F,0xE7,0xCF,0xCF,0xE7,0x3F,0xF8,0xFF,0xFF,0xFF,0xFF,/*"0",3*/
0xFF,0xFF,0x03,0xC0,0x7F,0xFF,0x7F,0xFF,0x7F,0xFF,0x7F,0xFF,0x01,0x80,0x7F,0xFF,//天
0x7F,0xFF,0xBF,0xFE,0xBF,0xFD,0xDF,0xFB,0xEF,0xE7,0xF7,0x8F,0xFB,0xDF,0xFD,0xFF,
void delay(unsigned int n) //延时函数
{ unsigned int k;
for(k=0;k<n;k++);
void IO_Init(void)
//IO初始化---------------------------------------
P1DIR |=0xFF;
P3DIR |=0xFF;
void variable_init()//变量初始化
all_date = sizeof( Table )-128; //计算出字模的长度,在减去16X64的缓存区
void load_data(void) //装载数据 16*64点阵的 缓存区
char s;
for(s=5;s>0;s--)
BUFF[2*(s-1)]=Table[zimuo+32*(s-1)+2*line];
BUFF[2*(s-1)+1]=Table[zimuo+1+32*(s-1)+2*line];
void send_data (void) //发送数据
uchar s;
uchar inc,tempyid,temp,k;
if(Move<8) inc=0;
else inc=1;
for(s=0+inc;s<8+inc;s++) //发送8字节数据
if(Move<8) tempyid=Move;
else tempyid=Move-8;
temp= ((BUFF>>tempyid)|(BUFF[s+1]<<(8-tempyid)));//h1左移tempyid位后和h2右移8-tempyid相或,取出移位后的数据。
for(k = 0; k < 8; k++)
if(temp&0x01) R1; //串行输出Data数据
else R0;
SK0;
temp=temp>>1;
//_NOP();
SK1;
void led_show1()//左移显示16X64
for(line=0;line<16;line++)
load_data(); //调整移动数据
send_data(); //装载移动数据
EN1; //关显示屏片选
delay(500);
//_NOP();//消影
LT1;
LT0; //输出锁存
LS=line; //16行地址
//_NOP();//消影
EN0; //开显示屏片选
void main( void )
char z;
WDTCTL = WDTPW + WDTHOLD;
IO_Init();
variable_init();
/*------选择系统主时钟为8MHz-------*/
BCSCTL1 &= ~XT2OFF; //打开XT2高频晶体振荡器
do
IFG1 &= ~OFIFG; //清除晶振失败标志
for (z = 0xFF; z > 0; z--); //等待8MHz晶体起振
while ((IFG1 & OFIFG)); //晶振失效标志仍然存在?
BCSCTL2 |= SELM_2 + SELS; //MCLK和SMCLK选择高频晶振
/*------选择定时器时钟为32768Hz-------*/
CCTL0= CCIE;
CCR0 =327;
TACTL = TASSEL_1 +TACLR+MC_1;
_EINT(); //使能中断,每100ms中断一次
while(1)
led_show1();
if(flag_move)
flag_move=0;
Move++;
if(Move>=16) //一个汉字已经全部移出
Move=0;
zimuo=zimuo+32; //换下一个字
if(zimuo>= all_date)
zimuo = 0;
#pragma vector=TIMERA0_VECTOR
__interrupt void Timer_A (void) //定时器A的CC0中断处理程序
count_move++; //点阵屏移动计数器
if(count_move>=6)
count_move=0; //点阵屏移动计数器清零
flag_move=1; //移动标准位置一
