BOM如下:
物料名称 | 规格型号 | 辅助属性(*) | 用量 | 环保PCB双面板 | SX-23-600B REV:1.0,FR4/1盎司,301.0*103.2*1mm/6拼,绿油白字(UL),兴海容 | | 1.0000 | 环保贴片0805电容 | 22pF±5%,50V,NPO,国巨T0.6 | | 1.0000 | 环保贴片0805电容 | 100pF±10%,50V,X7R,国巨T0.6 | | 2.0000 | 环保贴片0805电容 | 6.8nF±10%,50V,X7R,国巨T0.6 | | 1.0000 | 环保贴片0805电容 | 100nF±10%,50V,X7R,国巨T0.85 | | 1.0000 | 环保贴片0805电容 | 470nF±10%,25V,X7R,国巨T1.25 | | 1.0000 | 环保贴片0805电容 | 220nF±10%,50V,X7R,国巨T1.25 | | 3.0000 | 环保贴片0805电容 | 2.2nF±10%,500V,X7R,国巨T0.85/禾伸堂T1.0 | | 1.0000 | 环保贴片1206电容 | 100pF±5%,1KV,NPO,国巨T1.25/禾伸堂T1.25 | | 2 | 环保贴片0805电阻 | 22Ω±5%,1/8W,国巨 | | 1.0000 | 环保贴片0805电阻 | 47Ω±5%,1/8W,国巨 | | 2 | 环保贴片1206电阻 | 100Ω±5%,1/4W,国巨 | | 1.0000 | 环保贴片0805电阻 | 1KΩ±5%,1/8W,国巨 | | 2.0000 | 环保贴片0805电阻 | 2KΩ±5%,1/8W,国巨 | | 1.0000 | 环保贴片0805电阻 | 27KΩ±1%,1/8W,国巨 | | 1.0000 | 环保贴片0805电阻 | 18KΩ±1%,1/8W,国巨 | | 1.0000 | 环保贴片0805电阻 | 24KΩ±1%,1/8W,国巨 | | 1.0000 | 环保贴片0805电阻 | 3.3KΩ±1%,1/8W,国巨 | | 1.0000 | 环保贴片0805电阻 | 4.7KΩ±5%,1/8W,国巨 | | 5.0000 | 环保贴片0805电阻 | 10KΩ±5%,1/8W,国巨 | | 2.0000 | 环保贴片0805电阻 | 68KΩ±5%,1/8W,国巨 | | 1.0000 | 环保贴片0805电阻 | 100KΩ±1%,1/8W,国巨 | | 2.0000 | 环保贴片0805电阻 | 120KΩ±1%,1/8W,国巨 | | 1.0000 | 环保贴片0805电阻 | 130KΩ±5%,1/8W,国巨 | | 3.0000 | 环保贴片0805电阻 | 330KΩ±1%,1/8W,国巨 | | 3.0000 | 环保贴片0805电阻 | 1MΩ±5%,1/8W,国巨 | | 3.0000 | 环保贴片0805电阻 | 2.4MΩ±1%,1/8W,国巨 | | 3.0000 | 环保贴片1206电阻 | 1Ω±1%,1/4W,国巨 | | 1 | 环保贴片1206电阻 | 22Ω±1%,1/4W,国巨 | | 1.0000 | 环保贴片1206电阻 | 2Ω±1%,1/4W,国巨 | | 4.0000 | 环保贴片1206电阻 | 3.6Ω±1%,1/4W,国巨 | | 1.0000 | 环保贴片1206电阻 | 4.7Ω±1%,1/4W,国巨 | | 4.0000 | 环保贴片1206电阻 | 10K±1%,1/4W,国巨 | | 2 | 环保贴片1206电阻 | 200KΩ±5%,1/4W,国巨 | | 1.0000 | 环保贴片1206电阻 | 220Ω±5%,1/4W,国巨 | | 1.0000 | 环保贴片1206电阻 | 56Ω±5%,1/4W,国巨 | | 1.0000 | 环保贴片1206电阻 | 10Ω±5%,1/4W,国巨 | | 1.0000 | 环保贴片1206电阻 | 330KΩ±5%,1/4W,国巨 | | 2.0000 | 环保贴片PWM+PFC IC | UCC28811,Ta105℃,SOIC-8,TI | | 1.0000 | 环保贴片恒压恒流IC | AP4313K(G6G),Ta105℃,SOT23-6,BCD | | 1.0000 | 环保贴片整流二极管 | M7G,1A(30A)/1000V,VF≤1.1V,SMA,GPP,150℃,康索美 | | 5.0000 | 环保贴片整流二极管 | GS1MWZ,1A(30A)/1000V,VF≤1.1V,SMA,GPP,150℃,强茂 | | 0.0001 | 环保贴片稳压二极管 | 18V,0.3W,VF≤0.9V,SOD-123,先科5J/长电乐山无线电WL | | 3.0000 | 环保贴片超快恢复二极管 | ES2G,2A(50A)/400V,35nS,VF≤1.3V,SMB,GPP,150℃,康索美 | | 2 | 环保贴片快恢复二极管 | RS1J,1A(35A)/600V,250nS,VF≤1.3V,SMA,GPP,150℃,康索美/强茂 | | 3.0000 | 环保贴片NPN三极管 | MMBT3904,0.2A40V,0.2W,100-300(1V10mA),SOT-23 | | 1.0000 | 环保N-MOS | STP10NK80ZFP,9A(36A)/800V,0.9Ω,40W,TO-220F,ST | | 1.0000 | 环保光耦 | EL817C,CTR200-400%,Ta110℃,DIP-4,F=8.7mm,亿光 | | 1.0000 | 环保微型慢熔引脚保险丝 | T1A/350VAC,30TS,Φ4*12mm,(UL),HOLLYLAND | | 1.0000 | 环保压敏电阻 | 10D561K,350VAC,最大宽12.5*高16.5*厚6mm,(UL,VDE,CSA),松田/兴勤/联顺 | | 1.0000 | 环保X2电容(黄色) | 150nF±10%,305VAC,P=15mm,长脚,最大宽18*厚6*高12mm,(UL,VDE),110℃,京昊CBB62B | | 1.0000 | 环保Y1电容 | 1nF±20%,400V,125℃,Y5U,P=10mm,长脚,最大厚4.5*高10.5mm,(UL,VDE),嘉耐 | | 1.0000 | 环保CBB21(MMX)金属膜电容(红色) | 150nF±10%,630V,P=10mm,长脚,最大宽12.5*厚7.7*高13.8mm(日精) | | 1.0000 | 环保CBB21(MMX)金属膜电容(红色) | 220nF±10%,630V,P=10mm,长脚,最大宽 *厚 *高 mm(日精) | | 1.0000 | 环保铝电解电容 | 1000uF±20%,50V,Φ10*40, A/ mΩ,105℃5KH,RF系列,艾华 | | 1 | 环保铝电解电容 | 22uF±20%,50V,Φ5*12,238mA/0.34Ω,105℃6KH,RZ系列,艾华 | | 1.0000 | 环保铝电解电容 | 33uF±20%,35V,Φ6.3*11,200mA/0.57Ω,105℃5KH,RS系列,艾华 | | 1.0000 | 环保工型电感(卧式) | DR6*10mm,P=3mm,Φ0.18*197mm,1mH±10%,鸿富邦 | | 2.0000 | 环保环型电感(卧式) | T9*5*3mm,Φ0.2mm*16Ts,L=1.2mHMin,三层绝缘线,吴桥鹏峰 | | 2 | 环保共模电感 | EE12,Φ0.18mm,L=60mHMin,QS-108003R00B,卧式双槽,广得利/吴桥鹏峰 | | 1.0000 | 环保EDR28变压器 | 600uH±7%, ,SX-23-600B,吴桥鹏峰 | | 1.0000 | 环保单排针座 | P=2.54mm,上针长4mm,下针长3mm,5缺3,留两边PIN,欧朗 | | 1.0000 | 环保单排针座 | P=2.54mm,上针长4mm,下针长3mm,3缺1,留两边PIN,欧朗 | | 1.0000 | 环保导热硅胶 | XS1110 希顺 | | 1.0000 | 环保圆形QC PASS标签 | Φ5mm,绿底黑字 | | 1.0000 | 环保电源型号标签 | SX-23-600B-600(38.4V),长17*宽10mm,白底黑字,#54合成纸+表面光膜,耐120℃,绝缘 | | 1.0000 | 环保RoHS标签 | Φ25mm,厚0.1mm铜版纸,白底绿字 | | 0.0100 | 环保纸箱 | A=B,长507*宽325*高175mm | | 0.0050 | 环保平卡 | B=B,长495*宽312mm | | 0.0100 |
