重要提示:PCB作品文件展下载说明
这个方案做网络摄像机就比较多。用来做行车记录仪很少见。
板子有以下主要元件。
Name | Value | PCB Decal | Part Type | 1V8 | TP_SMD | SMD30 | SMD30 | 33V | TP_SMD | GPS_PAD | GPS_PAD | ADC | TP_SMD | GPS_PAD | GPS_PAD | BAT1 | BAT | BAT_DIP | BAT_DIP | D+ | TP_SMD | SMD30 | SMD30 | D- | TP_SMD | SMD30 | SMD30 | D1 | IN4148 | D0805 | D0805 | D3 | ASK24 | D_SS24A | D_SS24A | D4 | IN5819 | SOD123A | D1206 | D5 | IN5819 | SOD123A | D1206 | D6 | IN4148 | D0805 | D0805 | GND | TP_SMD | PAD16_1BAAAA | PAD16_1 | GPS_5V | TP_SMD | GPS_PAD | GPS_PAD | GPS_G | TP_SMD | GPS_PAD | GPS_PAD | GPS_RX | TP_SMD | GPS_PAD | GPS_PAD | GPS_TX | TP_SMD | SMD30 | SMD30 | HS2 | TP_SMD | SMD30 | SMD30 | J1 | NC | R0402 | R0402 | J2 | NC | R0402 | R0402 | J3 | TV | PJ-311D | PJ-5J7 | J11 | 10PINMINI_USB | USB-10P-DIP | USB-10P-DIP | L | TP_SMD | PAD16_10 | PAD16_10 | L5 | 4.7UH | L_SR0302 | L_SR0302 | L6 | 4.7UH | L_SR0302 | L_SR0302 | L20 | 4.7UH | L_SR0302 | L_SR0302 | LCD | FPC-24P-D-0.5MM | FPC-24-LCD | FPC-24-LCD | LD0 | TP_SMD | SMD30 | SMD30 | LED3 | BLUE | LED0603 | LED0603 | LED6 | LED | DIP-LED | DIP-LED | LED7 | LED | DIP-LED | DIP-LED | Q1 | AO3415 | SOT23 | SOT23 | Q2 | MMBT3904 | SOT23 | SOT23 | Q3 | AO3415 | SOT23 | SOT23 | Q10 | AO3415 | SOT23 | SOT23 | Q11 | MMBT3904 | SOT23 | SOT23 | Q14 | MMBT3904 | SOT23 | SOT23 | Q15 | MMBT3904 | SOT23 | SOT23 | QN10 | AO3415 | SOT23 | SOT23 | QN11 | AO3415 | SOT23 | SOT23 | QN12 | MMBT3904 | SOT23 | SOT23 | QN13 | MMBT3904 | SOT23 | SOT23 | RP5 | 22R | RP_4_0402 | RP_4_0402 | RP6 | 22R | RP_4_0402 | RP_4_0402 | RU1 | 10K | R0402 | R0402 | RU3 | 0R | R0402 | R0402 | RX | TP_SMD | PAD16_10 | PAD16_10 | S2 | BST-1114A | KEY18MM | KEY18MM | S5 | BST-1114A | KEY18MM | KEY18MM | S6 | KFC-A03-07 | SW-2-BIG | SW-2-BIG | SD2 | TP_SMD | SMD30 | SMD30 | SENSOR | FPC-30P-DOWN | FPC-0.5-30PIN | FPC-05-30D | SP1 | 8R/1W | PAD2 | PAD2 | SW2 | BST-1114A | KEY18MM | KEY18MM | TF1 | TF | TF-CARD | TF-CARD | TX | TP_SMD | PAD16_10 | PAD16_10 | U1 | GM8126_TFBGA256_27 | BGA256_065_12X12 | BGA256_065_12X12 | U2 | BMA250 | LGA12_050_2X2 | LGA12_050_2X2 | U3 | K4T1G164QE-HCE7 | DDR2_FBGA_X16 | DDR2_FBGA_X16 | U4 | W25Q64/128 | SOIC8_208 | SOIC8_208 | U5 | XS3145_MSOP8 | MSOP8 | MSOP8 | U6 | TW9900 | QFP32_20 | QFP32_20 | U7 | LN6206P332VR | SOT23 | SOT23 | U9 | SGM7222_MSOP10 | MSOP10 | MSOP10 | U12 | PJ4056 | SOT26 | SOT26 | U14 | G5725ADJT1U | SOT25 | SOT25 | U16 | G5699 | TDFN12_045_3X3 | TDFN12_045_3X3 | U20 | OCH168 | TO92AA | TO92 | VS2 | TP_SMD | SMD30 | SMD30 | Y1 | 32.768K | XIAT | XIAT | Y2 | 30MHZ/SMD3225 | SMD3225 | SMD3225 |
重要提示:PCB作品文件展下载说明
