查看: 802|回复: 0
单片机stc51开发温度传感器ds18b20
发表于 2016-6-15 21:22:50 | 显示全部楼层 |阅读模式
/*************************此部分为18B20的驱动程序*************************************/
#include <reg52.H>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
sbit D18B20 = P3^7; // 18b20的引脚定义
sbit  red_led = P1^4;
sbit  GREEN_led = P1^5;
#define  NOP()   _nop_()   /* 定义空指令 */
#define  _Nop()  _nop_()   /*定义空指令*/
void TempDelay (unsigned char idata us);
void Init18b20 (void);
void WriteByte (unsigned char idata wr);  //单字节写入
void read_bytes (unsigned char idata j);
unsigned char CRC (unsigned char j);
void GemTemp (void);
void Config18b20 (void);
void ReadID (void);
void TemperatuerResult(void);
void delay(uchar a);//1602分函数声明
bit  flag;
unsigned int  idata Temperature;
unsigned char idata temp_buff[9]; //存储读取的字节,read scratchpad为9字节,read rom ID为8字节
unsigned char idata id_buff[8];
unsigned char idata *p,TIM;
unsigned char idata crc_data;
unsigned char code CrcTable [256]={
0,  94, 188,  226,  97,  63,  221,  131,  194,  156,  126,  32,  163,  253,  31,  65,
157,  195,  33,  127,  252,  162,  64,  30,  95,  1,  227,  189,  62,  96,  130,  220,
35,  125,  159,  193,  66,  28,  254,  160,  225,  191,  93,  3,  128,  222,  60,  98,
190,  224,  2,  92,  223,  129,  99,  61,  124,  34,  192,  158,  29,  67,  161,  255,
70,  24,  250,  164,  39,  121,  155,  197,  132,  218,  56,  102,  229,  187,  89,  7,
219,  133, 103,  57,  186,  228,  6,  88,  25,  71,  165,  251,  120,  38,  196,  154,
101,  59, 217,  135,  4,  90,  184,  230,  167,  249,  27,  69,  198,  152,  122,  36,
248,  166, 68,  26,  153,  199,  37,  123,  58,  100,  134,  216,  91,  5,  231,  185,
140,  210, 48,  110,  237,  179,  81,  15,  78,  16,  242,  172,  47,  113,  147,  205,
17,  79,  173,  243,  112,  46,  204,  146,  211,  141,  111,  49,  178,  236,  14,  80,
175,  241, 19,  77,  206,  144,  114,  44,  109,  51,  209,  143,  12,  82,  176,  238,
50,  108,  142,  208,  83,  13,  239,  177,  240,  174,  76,  18,  145,  207,  45,  115,
202,  148, 118,  40,  171,  245,  23,  73,  8,  86,  180,  234,  105,  55,  213, 139,
87,  9,  235,  181,  54,  104,  138,  212,  149,  203,  41,  119,  244,  170,  72,  22,
233,  183,  85,  11,  136,  214,  52,  106,  43,  117,  151,  201,  74,  20,  246,  168,
116,  42,  200,  150,  21,  75,  169,  247,  182,  232,  10,  84,  215,  137,  107,  53
*Function:延时处理
*parameter:
*Return:
*Modify:
    while(us--);
*Function:18B20初始化
*parameter:
*Return:
*Modify:
    D18B20=1;
    _nop_();
    D18B20=0;
    TempDelay(80);   //delay 530 uS//80
    _nop_();
    D18B20=1;
    TempDelay(14);   //delay 100 uS//14
    _nop_();
    _nop_();
    _nop_();
    if(D18B20==0)
        flag = 1;   //detect 1820 success!
    else
        flag = 0;    //detect 1820 fail!
    TempDelay(20);       //20
    _nop_();
    _nop_();
    D18B20 = 1;
*Function:向18B20写入一个字节
*parameter:
*Return:
*Modify:
void WriteByte (unsigned char idata wr)  //单字节写入
    unsigned char idata i;
    for (i=0;i<8;i++)
        D18B20 = 0;
        _nop_();
        D18B20=wr&0x01;
        TempDelay(3);   //delay 45 uS //5
        _nop_();
        _nop_();
        D18B20=1;
        wr >>= 1;
*Function:读18B20的一个字节
*parameter:
*Return:
*Modify:
unsigned char ReadByte (void)     //读取单字节
    unsigned char idata i,u=0;
    for(i=0;i<8;i++)
        D18B20 = 0;
        u >>= 1;
        D18B20 = 1;
        if(D18B20==1)
        u |= 0x80;
        TempDelay (2);
        _nop_();
    return(u);
*Function:读18B20
*parameter:
*Return:
*Modify:
void read_bytes (uchar j)
     for(i=0;i<j;i++)
          *p = ReadByte();
          p++;
*Function:内部配置
*parameter:
*Return:
*Modify:
void Config18b20 (void)  //重新配置报警限定值和分辨率
     Init18b20();
     WriteByte(0xcc);  //skip rom
     WriteByte(0x4e);  //write scratchpad
     WriteByte(0x19);  //上限
     WriteByte(0x1a);  //下限
     WriteByte(0x7f);     //set 11 bit (0.125)
     Init18b20();
     WriteByte(0x48);  //保存设定值
     Init18b20();
     WriteByte(0xb8);  //回调设定值
*Function:读18B20ID
*parameter:
*Return:
*Modify:
void ReadID (void)//读取器件 id
    Init18b20();
    WriteByte(0x33);  //read rom
    read_bytes(8);
*Function:CRC校验
*parameter:
*Return:
*Modify:
       unsigned char idata i,crc_data=0;
      for(i=0;i<j;i++)  //查表校验
        crc_data = CrcTable[crc_data^temp_buff];
    return (crc_data);
*Function:读取温度
*parameter:
*Return:
*Modify:
int intT,decT;//温度值的整数部分和小数部分
bit get_temp=0;//设置标志位永远判断是否执行完,读取温度值
xdata uchar temp[3];
void GemTemp (void)
        Temperature = temp_buff[1]*0x100 + temp_buff[0];
//      temp_buff[1]整数部分高八位, temp_buff[0]高4位是整数部分 ,低四位小数部分
//        Temperature *= 0.0625;
//        Temperature /= 16;
        SBUF = temp_buff[1];
        while(TI==0);
            TI=0;
        SBUF = temp_buff[0];
        while(TI==1);
            TI=0;
        intT = Temperature >> 4;//分离出整数部分
        decT = Temperature & 0xf;//分离出温度值小数部分;
        temp[0] =  decT;
        temp[1] =  intT & 0x0f;
        temp[2] =  (intT >> 8) & 0x0f;
        TempDelay(1);
//        get_temp = 1;
*Function:18B20ID全处理
*parameter:
*Return:
*Modify:
//      p = id_buff;
//      ReadID();
//      Config18b20();
    Init18b20 ();
    WriteByte(0x44);   //Temperature convert
    Init18b20 ();
    WriteByte(0xbe);   //read Temperature
//    p = temp_buff;
    GemTemp();
extern count;
void GetTemp()
     if(count >= 2000) //每隔1ms*2000=2s 读取温度
        EA = 0;
        GREEN_led = ~GREEN_led;
        red_led = ~red_led;
        count = 0;
        TemperatuerResult();
        EA = 1;
