查看: 1196|回复: 15
[IC] DC/DC电源芯片
社区居民忠实会员终身成就奖
发表于 2016-7-7 08:39:19 | 显示全部楼层 |阅读模式
4.75V to 20V Input, 2A Synchronous Step-Down
Converter with Fast Transient Response
1. Introduction
The FD1482 is a current mode synchronous buck converter, and has a proprietary
W-mode™® Gm curvature circuit that enables fast transient response, enables the device to
adopt to both low ESR output capacitors, such as POSCAP or SP-CAP, and ultra-low ESR
ceramic capacitors.
2. Features.
 W-mode™® Gm CurvatureEnables Fast Transient Response
 2AOutput Current
 High Efficient Integrated FETs Optimized for portable application:
 95mΩ (High side) and 90mΩ (Low side)
 High Efficiency
 Up to 95% Efficiency @ 5V Input, 3.3V Output Up to 93% efficiency @ 12V Input, 3.3V
Output
 Wide Input Voltage Range: 4.75V to 20V @ 2A loading
 Wide Output Voltage Range: 0.918V to 14V @ 2Aloading ( 32Watt output @max)
 Low Output Ripple andAllows Ceramic Output Capacitor
 Thermal Shutdown Protection
 340-KHz Switching Frequency(fsw)
 Cycle By Cycle Over Current Limit
 +/-1.5% High Accuracy Feedback Voltage
3. Applications
WideRange ofApplications for Low Voltage System
Digital TV Power Supply
High Definition Blu-ray Disc Players
Networking Home Terminal
Digital STB
Ideal for Portable Applications QQ截图20160707083808.png FD1482_DATASHEET.pdf (1.61 MB, 下载次数: 0)
社区居民忠实会员终身成就奖
 楼主| 发表于 2016-7-7 08:39:36 | 显示全部楼层
社区居民忠实会员社区劳模原创达人最爱沙发终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
发表于 2016-7-7 08:44:04 | 显示全部楼层
    4 天前
  • 签到天数: 164 天
    你必须非常努力才能显
    发表于 2016-7-7 08:56:25 | 显示全部楼层
    忠实会员社区居民社区劳模终身成就奖优秀斑竹奖
    发表于 2016-7-7 08:59:52 | 显示全部楼层
    发表于 2016-7-7 09:00:06 | 显示全部楼层
    发表于 2016-7-7 09:00:21 | 显示全部楼层
  • 签到天数: 139 天
    终身成就奖社区居民忠实会员社区劳模
    发表于 2016-7-7 09:08:33 | 显示全部楼层
    发表于 2016-7-7 09:45:08 | 显示全部楼层
    终身成就奖社区居民忠实会员社区劳模最爱沙发原创达人优秀斑竹奖
    发表于 2016-7-7 12:09:53 | 显示全部楼层
