#include "reg52.h"
//电机IO
#define GPIO_MOTOR P1
//sbit F1 = P1^0;
//sbit F2 = P1^1;
//sbit F3 = P1^2;
//sbit F4 = P1^3;
//按键IO
sbit K1=P3^0;
sbit K2=P3^1;
sbit K3=P3^2;
sbit K4=P3^3;
unsigned char code FFW[8]={0xf1,0xf3,0xf2,0xf6,0xf4,0xfc,0xf8,0xf9}; //反转顺序
unsigned char code FFZ[8]={0xf9,0xf8,0xfc,0xf4,0xf6,0xf2,0xf3,0xf1}; //正转顺序
unsigned char Direction,Speed;
void Delay(unsigned int t);
void Motor();
void main(void)
unsigned char i;
Speed=3000;
while(1)
if(K1==0) //检测按键K1是否按下
Delay(1); //消除抖动
if(K1==0)
Direction=1;
while((i<200)&&(K1==0)) //检测按键是否松开
Delay(1);
i++;
i=0;
if(K2==0) //检测按键K1是否按下
Delay(1); //消除抖动
if(K2==0)
Direction=2;
while((i<200)&&(K2==0)) //检测按键是否松开
Delay(1);
i++;
i=0;
if(K3==0) //检测按键K1是否按下
Delay(1); //消除抖动
if(K3==0)
Speed=13;
while((i<200)&&(K3==0)) //检测按键是否松开
Delay(1);
i++;
i=0;
if(K4==0) //检测按键K1是否按下
Delay(1); //消除抖动
if(K4==0)
Speed=40;
while((i<200)&&(K4==0)) //检测按键是否松开
Delay(1);
i++;
i=0;
Motor();
void Motor()
unsigned char i;
for(i=0;i<8;i++)
if(Direction==1)
GPIO_MOTOR = FFW&0x1f; //取数据
if(Direction==2)
GPIO_MOTOR = FFZ&0x1f;
Delay(Speed); //调节转速
unsigned int k;
while(t--)
for(k=0; k<80; k++)
