重要提示:PCB作品文件展下载说明
LCD主板.Pcb
(2.55 MB, 下载次数: 96)
纯手工,非搬运,请多多指教,以下是器件表
Comment | Designator | Footprint | | 220V | 220V | 2P-5.08 | | AVDD | AVDD | 1PIN | | BUZZER | BEEP1 | BEEP-9.5X5.5 | | CR1220 | BT1 | BATERY | | 0.1UF | C1, C7, C8, C10, C11,C12, C14, C15, C16, C18, C80 | 0603 | | 2.2UF | C2, C3 | 0603 | | 22P | C4, C5, C48, C50 | C_0603 | | 0.1UF/NC | C6, C9 | 0603 | | 10P | C13, C17, C34, C35,C36, C37 | C_0603 | | 0.1U | C19, C20, C21, C22,C23, C24, C25, C26, C27, C28, C29, C30, C31, C32, C33 | C_0603 | | 10UF | C38, C43 | C_0603 | | 0.1UF | C39, C40, C41, C42,C44, C45, C46, C47, C51, C52, C55, C61, C62, C77, C78 | C_0603 | | C_4.7NF_1206 | C49 | 1206C | | 10UF25V | C53, C54 | AVX_B_3528-21 | | 47UF | C56, C57, C58 | EC_47UF_6.5X6.5 | | 10UF16V | C59, C60 | AVX_B_3528-21 | | 2.7N | C63 | C_0603 | | | C64 | 贴片电解电容6.3*5.4 | | 0.22UF/0603/25V | C65, C66, C69, C71 | C_0603 | | 2.2UF | C67, C75 | C_0603 | | 220PF | C68, C76 | C_0603 | | 10UF/1206/25V | C70 | 1210 | | 2.2UF/0603/25V | C72 | C_0603 | | 10UF/1206/25V | C73, C74 | 1206 | | DIODE | D1 | D4148 | | LED_BLUE_0603 | D2 | LED_0603 | | SMAJ5.0CA | D3 | DO-214 | | LED1 | D4 | 0805_+- | | 1N4001 | D5 | D4148 | | SS14 | D6, D11 | SS24_1206 | | BAV99W | D7, D9 | SOT-23 | | SMBJ7.5CA | D8 | SOD323 | | SMBJ18CA | D10 | SOD323 | | el817 | EL1 | EL817 | | FUSE500MA | F1 | C1812 | | 40PIN | J1 | FPC_Conector_40 | | XH2.54-5P | J2 | XH2.54-5P | | RJ45 | J3 | RJ45 | | CON2 | J4 | 2P-5.08 | | CON_2PIN | J9 | 2P-5.08 | | HEADER 10 | JP1 | 1*10PIN_1.25 | | BEAD-0603 | L1 | R_0603 | | 600R | L2 | 0603 | | L_6.8UH_4532 | L3 | GDCD4532 | | L_33UH_4532 | L4, L5 | GDCD4532 | | MB6M | MB1 | LC-MBS | | 6P | P1 | HDR1X6 | | BAT54C | Q1 | SOT-23 | | NPN | Q2 | SOT23_8050&8550 | | 10K | R1, R2, R3, R4, R16,R24, R25, R32, R33, R34, R67, R68, R69, R70, R71 | 0603 | | 0R | R5, R7, R9, R11, R18,R20, R50, R56, R60 | 0603 | | 0R/NC | R6, R8, R10, R12 | 0603 | | 10K/NC | R13 | 0603 | | 100R | R14, R17, R19, R21,R23 | 0603 | | NC/0R | R15, R22 | 0603 | | 51R | R26, R27, R28, R29 | 0603 | | 1K | R30, R38, R41 | 0603 | | 510R | R31, R36, R37 | 0603 | | 12.4K | R35 | 0603 | | 1M | R39 | 1206C | | 100K | R40 | 0603 | | 62K | R42 | 0603 | | 180K | R43 | 0603 | | 24K | R44 | 0603 | | 11.8K | R45 | R_0603 | | Res2 | R46 | 限流电阻 | | Res3 | R47 | 0603 | | 15R 2W | R48 | 限流电阻 | | 27R | R49, R53 | 0603 | | 47K | R51, R59 | 0603 | | 75K | R52 | 0603 | | 0R | R54, R88 | R_0603 | | 13K | R55 | 0603 | | 13K/1% | R57, R61 | 0603 | | 75K/1% | R58 | 0603 | | 10K/1% | R62 | 0603 | | 120R | R64 | 0603 | | 10R | R65, R66 | 0603 | | 13K/1% | R87 | R_0603 | | 10K/1% | R89 | R_0603 | | TF_CARD | TF1 | TF_CARD | | STM32F429XGT6 | U1 | LQFP176 | | DS90C385 | U2 | TSSOP56_61MM_05P | | IS42S16400J | U3 | TSOP-54 | | LAN8720A | U4 | QFN24 | | RT7272 | U5 | RT7272 | | LM2733 | U6, U7 | SOT-23-5 | | SP485RE | U9 | MAX485 | | 1086-3.3 | UP1 | TO-252-2L | | VCOM | VCOM | 1PIN | | VGH | VGH | 1PIN | | VGL | VGL | 1PIN | | VR10K | VR1, VR2, VR5 | VR-SMD | | XTAL_25M_3225 | Y1 | CRYSTAL_25MHZ | | XTAL_32.768KHZ | Y2 | CRYS-3X8 | | XTAL_25M_3225 | Y3 | 3225 | |
评分
查看全部评分
重要提示:PCB作品文件展下载说明
