Comment | Description | Designator | Footprint | Battery | Multicell Battery | BT1 | BAT1_SMT | tongbu_phone_1 | | CON1, CON2 | tongbu_phone | BAT54 | | D1, D2, D14, D15 | SOT-23 | 1N4148 | | D6, D7 | IN4148 | LED | Typical INFRARED GaAsLED | D8, D9, D10, D11,D12, D13 | LED | 1N914 | High Conductance FastDiode | D19, D22, D27, D31 | 1N914 | MBRS330T3 | Schottky Diode | D20, D24, D25, D29,D33 | MBRS330T3 | Fuse 2A | Fuse | F1 | PIN-W2/E2.8 | Connector 15 | Receptacle Assembly,15-Pin, Sim Line Connector | J2 | DB15_VGA | D Connector 9 | Receptacle Assembly,9 Position, Right Angle | J3, J4 | DSUB1.385-2H9 | Inductor | Inductor | L1, L2, L3, L4, L7,L8, L9, L10 | 3216[1206] | 470nH | | L5, L6 | 3216[1206] | murataDLW5BSN152SQ2 | | L11 | DLW4 | LQH32C | Inductor | L12, L13, L14, L15,L16 | 1212_L | AS_MODE | Header, 5-Pin, Dualrow | P1, P4 | JTAG_10P | JTAG_MODE | Header, 5-Pin, Dualrow | P2, P5 | JTAG_10P | Header 2 | Header, 2-Pin | P3 | HDR1X2 | Header 5X2 | Header, 5-Pin, Dualrow | P6 | HDR2X5 | Header 7 | Header, 7-Pin | P7 | AUDIO_int | Header 2X2 | Header, 2-Pin, Dualrow | P8, P23, P25, P29 | HDR2X2 | Header 19X2 | Header, 19-Pin, Dualrow | P17 | HDR2X19 | Header 5 | Header, 5-Pin | P18 | HDR1X5 | Header 2 | Header, 2-Pin | P19, P20, P22 | tiger | Header 5 | Header, 5-Pin | P21 | AUDIO_int | Header 4X2 | Header, 4-Pin, Dualrow | P26, P30 | HDR2X4 | varister | Header, 3-Pin, Dualrow | P27 | varister | Header 10X2 | Header, 10-Pin, Dualrow | P31 | HDR2X10 | Header 13X2 | Header, 13-Pin, Dualrow | P32 | HDR2X13 | Header 6X2 | Header, 6-Pin, Dualrow | P33 | HDR2X6 | Header 15X2 | Header, 15-Pin, Dualrow | P38 | HDR2X15 | BC857 | | Q1, Q2, Q3 | SOT-23 | MMBT8050 | | Q4, Q5 | SOT-23 | 9012 | | Q6, Q8 | SOT-23 | 2N222 | | Q7, Q9 | SOT-23 | 10K | Square TrimmingPotentiometer | R106 | POT4MM-2 | 120R | Resistor, 100R 1%0402 (1005) | R134 | 1608[0603]_R | SW-PB | Switch | S1, S6 | key | SW-PB | Switch | S2, S3, S8 | KEY_SMT | | Switch | S4, S5 | key | SW-SPDT | SPDT SubminiatureToggle Switch, Right Angle Mounting, Vertical Actuation | S9 | switch_two | EP3C25E144C8N | Cyclone III FamilyFPGA, 82 I/O Pins, 4 PLLs, 144-Pin EQFP, Speed Grade 8, Commercial Grade,Pb-Free | U1 | EQFP144_N | LPC1788FBD208 | LPC1788FBD208 | U2 | LPC1788 | EP3C25Q240C8 | Cyclone III FamilyFPGA, 148 I/O Pins, 4 PLLs, 240-Pin PQFP, Speed Grade 8, Commercial Grade | U3 | PQFP240_N | OPA241 | JFET-Input Low-SupplyCurrent Operational Amplifier | U4, U5, U29, U30 | SOP2-8 | LTC2640-LZ10 | | U6, U7, U8, U9 | LTC2640 | LM1972 | | U10 | LM1972 | LME49722 | Dual PrecisionJFET-Input Operational Amplifier | U11 | SOP2-8 | LTC1655 | | U12 | SOP2-8 | POWER_JACK | Header, 3-Pin | U13 | POWER_INTERFACE | LT1959CS8 | | U14, U15, U17, U20 | SOP2-8 | AMS1117-3.3 | 800mA and 1A LowDropout Positive Regulator 2.85V, 3.3V, 5V, and Adjustable | U16 | SOT223 | AMS1117-1.25 | 800mA and 1A LowDropout Positive Regulator 2.85V, 3.3V, 5V, and Adjustable | U18, U21 | SOT223 | AMS1117-2.5 | 800mA and 1A LowDropout Positive Regulator 2.85V, 3.3V, 5V, and Adjustable | U19 | SOT223 | TXB0104 | | U22, U24, U25, U26,U28 | NLSX4014 | SP3485 | | U23 | SOP2-8 | MC74HCT244AF | | U27 | MC74HCT244A | NE5532P | Dual PrecisionJFET-Input Operational Amplifier | U31, U32, U34, U35,U37, U38 | SO-8 | TDA2822M | | U33, U36 | SO-8 | EPCS16SI16N | EPCS16 Series,In-system programmable 3.3V serial configuration device, 16-Pin SOIC,16-Megabit, Industrial Grade, Pb-Free | U39, U40 | SOIC16_N | crystals(50M) | | X1, X4 | crystals(24M) | 32.768kHz | | X2 | SIP-2 | 12MHz | | X3 | XTAL_49US |
