/*****************能用按键实现时分秒的调节,与手表功能相差不大,本人已测试过*********************/
#include<reg51.h>
#define uchar unsigned char
#define uint unsigned int
#define LCD1602_DATAPINS P0
/****************位定义声明*****************/
sbit LCD1602_E=P2^7;
sbit LCD1602_RW=P2^5;
sbit LCD1602_RS=P2^6;
sbit K1=P1^0;
sbit K2=P1^1;
sbit K3=P1^2;
sbit K4=P1^3;
uchar count,K1num;
char miao=55,shi=23,fen=59;
uchar code table[17]=" 2016-8-11 Thur ";
uchar code table1[16]=" 23:59:55 ";
/****************函数声明*****************/
void write_sfm(uchar address,uchar data1);
void write_com(uchar com);
void write_date(uchar date);
void init();
void keyscan();
void delay(uint m);
/****************主函数*****************/
void main()
init();
while(1)
keyscan();
/****************初始化函数*****************/
void init()
uchar i;
LCD1602_E=0;
write_com(0x38); //开显示
write_com(0x0c); //开显示不显示光标
write_com(0x06); //写一个指针加1
write_com(0x01); //清屏
write_com(0x80); //设置数据指针起点
for(i=0;i<17;i++)
write_date(table);
delay(1);
write_com(0x80+0x40);
for(i=0;i<16;i++)
write_date(table1);
delay(1);
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
/****************按键扫描函数*****************/
void keyscan()
if(K1==0)
delay(5);
if(K1==0)
delay(5);
if(K1==0)
K1num++;
while(!K1);
if(K1num==1)
TR0=0;
write_com(0x80+0x40+11);//光标在秒位闪烁
write_com(0x0f);
if(K1num==2)
write_com(0x80+0x40+8);//光标在分位闪烁
if(K1num==3)
write_com(0x80+0x40+5); //光标在时位闪烁
if(K1num==4)
K1num=0;
write_com(0x0c);//光标不闪烁
TR0=1;
if(K1num!=0)
if(K2==0)
delay(5);
if(K2==0)
while(!K2);
if(K1num==1)
miao++;
if(miao==60)
miao=0;
write_sfm(10,miao);
write_com(0x80+0x40+10);
if(K1num==2)
fen++;
if(fen==60)
fen=0;
write_sfm(7,fen);
write_com(0x80+0x40+7);
if(K1num==3)
shi++;
if(shi==24)
shi=0;
write_sfm(4,shi);
write_com(0x80+0x40+4);
if(K3==0)
delay(5);
if(K3==0)
while(!K3);
if(K1num==1)
miao--;
if(miao==-1)
miao=59;
write_sfm(10,miao);
if(K1num==2)
fen--;
if(fen==-1)
fen=59;
write_sfm(7,fen);
if(K1num==3)
shi--;
if(shi==-1)
shi=23;
write_sfm(4,shi);
/****************写入时分秒的十位和个位*****************/
uchar shi,ge;
shi=data1/10;
ge=data1%10;
write_com(0x80+0x40+address);
write_date(0x30+shi);
write_date(0x30+ge);
/****************1ms延时函数*****************/
void delay(uint m)
uint x,y;
for(x=m;x>0;x--)
for(y=110;y>0;y--);
/*****************写入命令*******************/
LCD1602_E=0; //使能清零
LCD1602_RS=0; //选择发送命令
LCD1602_RW=0; //选择写入
LCD1602_DATAPINS=com; //放入命令
delay(1); //等待数据稳定
LCD1602_E=1; //写入时序
delay(1); //保持时间
LCD1602_E=0;
/*****************写入数据*******************/
LCD1602_E=0; //使能清零
LCD1602_RS=1; //选择输入数据
LCD1602_DATAPINS=date; //写入数据
delay(1); //等待数据稳定
LCD1602_E=1; //写入时序
delay(1); //保持时间
LCD1602_E=0;
/*****************定时器0中断*******************/
void timer0() interrupt 1
count++;
if(count==18)
count=0;
miao++;
if(miao==60)
miao=0;
fen++;
if(fen==60)
fen=0;
shi++;
if(shi==24)
shi=0;
write_sfm(4,shi);
write_sfm(7,fen);
write_sfm(10,miao);
