SKW17 – USB Wi-Fi Module datasheet
Features
Compliant to IEEE 802.11b/g/n WLANs
Security: WEP 64/128, WPA, WPA2, TKIP, AES, WAPI
Supports for Windows XP 32/64, 2000, Vista 32/64bit, Windows 7 32/64bit, Linux, Android.
Supported Linux kernel AP/Station/IBSS/Monitor-mode drivers .
USB 2.0 interface. Supports 72.2 Mbps for 20 MHz and 150 Mbps for 40 MHz channel operations.
The only one-stream 802.11n solution with one antenna port.
RoHS compliance meets environment-friendly requirement.
18.5(L) x 16.6(W) x 2.75(H) mm small dimension
SKW17 – USB Wi-Fi Module datasheet.pdf
(433 KB, 下载次数: 0)
