重要提示:PCB作品文件展下载说明
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
Name | Part Type | PCB Decal | Value | D2 | TVS-ESD5Z3.3T1G | SOD-523 | | D4 | DIODE-SCHOTTKY-RB550V-30 | SOD-323 | NF | D107 | DIODE-SCHOTTKY-RB060M-30 | SOD-123(RB060M) | | D110 | DIODE-DAN222 | SOT-416(2SC4617) | | D901 | ZENER-UDZSTE-176.8B | UMD2-ZENER-UDZS5.1B | 6V | D902 | DIODE-MMBD4148SE | SOT23 | | J2 | KEY-SIDE-LS10 | KEY-SIDE-LS10 | | J3 | ZIF_0.5_12P_R | ZIF-0.5K-AX-NPWB-12P-R | | J5 | DC-33_0 | 757DC | DC-1520-A | J6 | TF_SD_SOCKET | TF-CARD | EM86TF01A | J7 | ZIF_0.5MM_30PIN_R | ZIF-0.5K-AX-NPWB-30P-R | | J10 | AUDIO-EAR-IPHONE4 | JAF3.5_6PIN | | J101 | KEY-SIDE-LS10 | KEY-SIDE-LS10 | | J300 | USB-UAF95-05254-1500-B | USB-UAF95-05254-1500-B | USBmin_10P | J900 | LCD-50PIN-WVGA | ZIF-0.5K-AX-NPWB-50P | | Q1 | FET-P_DIODE-FDFMA2P853 | MICROFET-2X2 | | Q6 | TRIODE-NPN-2SC4617 | SOT-416(2SC4617) | WNM2021/2SK3018 | Q100 | FET-N-2SK3019 | SOT-416 | SI2306 | Q107 | SI2305 | SOT23 | SI2305 | Q200 | FET-P_DIODE-FDFMA2P853 | MICROFET-2X2 | | Q300 | FET-N-2SK3019 | SOT-416 | SI2306 | Q900 | FET-P_DIODE-FDFMA2P853 | MICROFET-2X2 | | Q910 | TRIODE-NPN-2SC4617 | SOT-416(2SC4617) | WNM2021/2SK3018 | TVS300 | TVS-ESD5Z3.3T1G-523 | SOD-523 | | U1 | MCU_RK2926_LQFP176 | LQFP176 | MCU_RK2926 | U2 | MXC6225XU | MXC6225XU | | U4 | NANDFLASH_0 | TSOP1-48 | NAND_FLASH | U5 | NANDFLASH_0 | TSOP1-48 | NC/NAND_FLASH | U8 | DDR3_16BIT | FBGA96-9X14 | DDR3-512MB | U11 | PMU_TPS659102 | TPS659102_QFN48 | TPS659102 | U16 | USB_WIFI | WIFI_UM02BS | RL-UM12BS-8188EUS | U41 | CRYSTAL-4_1 | CRY-D3225 | 24M-20ppm | U102 | FP8102/TP4056/CX9056 | SO8-EP | | U202 | 32.768K-12.5PF-MC146 | MC146 | 32.768KHZ | U203 | SY8009B/UP1705A | SOT-25 | SY8009B | U703 | ZET6221/6231WMA | QFN40PIN-5X5 | | U706 | AUDIO-AMP-MD4103/MD4105 | DFN8-2X2-BCT3220 | | U900 | SYQ201 | SOT23-6(SYQ201) | SYQ201 | U901 | CP2121 | SOT23-6(ZXT10P20DE6) | CP2121 | U1000 | RTL8188EUS/ETV | QFN46-6.5X4.5-.4 | | U1002 | SENSOR-MOTION-LIS3DH | SENSOR-MOTION-LIS3DH | | U1101 | XTAL-CRYSTAL_26M-3225 | CRYSTAL-26M | 40MHz, 10ppm | U2301 | CP2121 | SOT23-6(ZXT10P20DE6) | CP2121 | XJ102 | AUDIO_SPK_2.5X5 | AUDIO_SPK_2.5X5 | | XJ301 | VIB-PRJ8625 | VIB-PRJ8625 | | XJ701 | AUDIO-MIC-8807PRJ | AUDIO-MIC-8807PRJ | | XJ702 | AUDIO-CON_SPK(MIC-RE-MOT) | AUDIO-CON_SPK | | XJ1101 | RF-ANT-PAD-2X3BA | RF-RFANT-2X3BA | |
重要提示:PCB作品文件展下载说明
