重要提示:PCB作品文件展下载说明
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
Name | Part Type | PCB Decal | Value | B329 | BEAD-180OHM-0603 | SL0603 | 180ohm | D103 | DIODE-SCHOTTKY-RB521S-30 | SOD523 | | D104 | DIODE-LED-RED-0603 | LED-0603 | | D107 | DIODE-SCHOTTKY-RB060M-30 | SOD-123(RB060M) | | D108 | DIODE-SCHOTTKY-RB550V-30 | SOD-323 | NF | D110 | DIODE-DAN222 | SOT-416(2SC4617) | | D800 | DIODE-ZENER-UDZSTE-176.8B | UMD2-ZENER-UDZS5.1B | 3V | D903 | DIODE-MMBD4148SE | SOT23 | | D904 | DIODE-ZENER-UDZSTE-176.8B | UMD2-ZENER-UDZS5.1B | 18V | J100 | POWERJACK-DC-2.35MM | DCJACK-AJ426-A-D-1 | | J101 | KEY-SIDE-IT-1188E | KEY-SIDE-IT-1188E | | J300 | USB-UAF95-05254-1500-B | USB-UAF95-05254-1500-B | USBmin_10P | J500 | TFLASH-1.5H | TFLASH-CARD-1.5H-CONN | | J501 | TFLASH-AC-0100-057 | TFLASH-AC-0100-057 | | J700 | AUDIO-EAR-LK-DJ521 | AUDIO-EAR-LK-DJ521 | | J800 | HDMI_TYPE_C | HDMI-19PF_C | HDMI_C | J801 | KEY-SIDE-IT-1188E | KEY-SIDE-IT-1188E | | J1200 | MM4829-2702-4 | MM4829-2702-2 | | J1202 | SIM-CAF99-06203-1503 | SIM-CAF99-06203-1503 | | L200 | IND-POWER-22UH-1212 | IND-POWER-22UH-1212 | 22uH | Q100 | FET-N-2SK3019 | SOT-416 | SI2306 | Q106 | TRIODE-NPN-2SC4617 | SOT-416(2SC4617) | WNM2021/2SK3018 | Q107 | SI2305 | SOT23 | SI2305 | Q200 | FET-P_DIODE-FDFMA2P853 | MICROFET-2X2 | | Q202 | TRIODE-NPN+PNP-UMC4NTR | UMT5 | | Q203 | TRIODE-PNP-2SA1774G | SOT-416(2SA1774G) | | Q300 | FET-N-2SK3019 | SOT-416 | SI2306 | Q301 | TRIODE-NPN-2SC4617 | SOT-416(2SC4617) | WNM2021/2SK3018 | U102 | FP8102/TP4056/CX9056 | SO8-EP | | U201 | PMU_TPS659102 | TPS659102_QFN48 | TPS659102 | U202 | 12.5PF-MC146 | MC146 | 32.768KHZ | U203 | SY8009B/UP1705A | SOT-25 | SY8009B | U300 | TZ0466A-24MHZ | 3225-DSCB12 | 24M-30ppm | U400 | DDRIII_8BIT | BGA78 | DDR3_256M_8BIT | U401 | DDRIII_8BIT | BGA78 | DDR3_256M_8BIT | U500 | NANDFLASH_0 | TSOP1-48 | NAND_FLASH | U701 | SWITCH-ANALOG-SGM3157 | SC-70-6(SGM3001) | | U703 | SWITCH-ANALOG-SGM3157 | SC-70-6(SGM3001) | | U706 | AUDIO-AMP-MD4103/MD4105 | DFN8-2X2-BCT3220 | | U900 | WDFN-8L-2X2-1 | WDFN-8L-2X2-1 | | U901 | CP2121 | SOT23-6(ZXT10P20DE6) | CP2121 | U1001 | MCU_RK2928_BGA | RK2928_BGA313 | MCU_RK2928_BGA | U1002 | SENSOR-MOTION-LIS3DH | SENSOR-MOTION-LIS3DH | | U1003 | AP3216C | AP3216C | | U1100 | SAW_WIFI2012 | RF-FILTER-WIFI2012 | NF | U1101 | XTAL-CRYSTAL_26M-3225 | CRYSTAL-26M | | U1102 | RDA5990P_QFN7X7-48L_V1.0 | RDA_QFN_77MM_48P | | U1200 | M0_GSM_MODULE | M0_FOOTPRINT | | U2100 | L3G4200D | L3G4200D | L3G4200D | U2102 | AK8975C | AK8975C | AK8975C | XJ102 | AUDIO_SPK_2.5X5 | AUDIO_SPK_2.5X5 | | XJ301 | VIB-PRJ8625 | VIB-PRJ8625 | | XJ302 | PAD-1.0X2.4 | PAD-1.0X2.4 | | XJ700 | AUDIO-RECEIVER-XH150601C-01 | RECEIVER-XH150601C-01 | | XJ701 | F15LX42-221-C10C33EP(W158) | 221-C10C33EP | | XJ703 | AUDIO-CON_SPK(MIC-RE-MOT) | AUDIO-CON_SPK | | XJ1100 | RF-ANT-PAD-2X3BA | RF-RFANT-2X3BA | |
重要提示:PCB作品文件展下载说明
