查看: 1558|回复: 12
[技术讨论] 在Tiny210v2上实现四线电阻屏触摸,有兴趣的朋友可以看看
发表于 2016-9-6 18:17:31 | 显示全部楼层 |阅读模式
[hide]
Tiny210v2上没有四线电阻屏的接口,可直接从核心板上引出四根线连接至四线电阻屏,下面为四线电阻屏的驱动源码,我已经在Tiny210v2上测试OK。有兴趣的朋友可以看看。
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/slab.h>
#include <linux/input.h>
#include <linux/init.h>
#include <linux/errno.h>
#include <linux/serio.h>
#include <linux/delay.h>
#include <linux/clk.h>
#include <linux/wait.h>
#include <linux/sched.h>
#include <linux/cdev.h>
#include <linux/miscdevice.h>
#include <asm/io.h>
#include <asm/irq.h>
#include <asm/uaccess.h>
#include <mach/map.h>
#include <mach/regs-clock.h>
#include <mach/regs-adc.h>
#include <mach/regs-gpio.h>
#include <plat/regs-timer.h>
struct tiny210_ts_regs{
    unsigned long tsadccon1;
    unsigned long tscon1;
    unsigned long tsdly1;
    unsigned long tsdatx1;
    unsigned long tsdaty1;
    unsigned long tspenstat1;
    unsigned long clrintadc1;
    unsigned long noregs;
    unsigned long clrintpen1;
struct tiny210_ts_regs_1{
    unsigned long tsadccon0;
    unsigned long tscon0;
    unsigned long tsdly0;
    unsigned long tsdatx0;
    unsigned long tsdaty0;
    unsigned long tspenstat0;
    unsigned long clrintadc0;
    unsigned long adcmux;
    unsigned long clrintpen0;
static struct input_dev *tiny210_ts_dev;
static volatile struct tiny210_ts_regs *tiny210_ts_regs;
static volatile struct tiny210_ts_regs_1*tiny210_ts_regs_1;
static struct timer_list ts_timer;
static void enter_wait_pen_down_mode(void)
    tiny210_ts_regs->tscon1 = 0xd3;
static void enter_wait_pen_up_mode(void)
    tiny210_ts_regs->tscon1 = 0x1d3;
static void enter_measure_xy_mode(void)
    tiny210_ts_regs->tscon1 = (1<<3) (1<<2);
static void start_adc(void)
    tiny210_ts_regs->tsadccon1 = (1<<0);
static int tiny210_filter_ts(int x[], int y[])
#define ERR_LIMIT 50
    int avr_x, avr_y;
    int det_x, det_y;
    avr_x = (x[0]+x[1])/2;
    avr_y = (y[0]+y[1])/2;
    det_x = (x[2] > avr_x) ? (x[2] - avr_x) : (avr_x - x[2]);
    det_y = (y[2] > avr_y) ? (y[2] - avr_y) : (avr_y - y[2]);
    if((det_x > ERR_LIMIT) (det_y > ERR_LIMIT))
        return 0;
    avr_x = (x[1] + x[2])/2;
    avr_y = (y[1] + y[2])/2;
    det_x = (x[3] > avr_x) ? (x[3] - avr_x) : (avr_x - x[3]);
    det_y = (y[3] > avr_y) ? (y[3] - avr_y) : (avr_y - y[3]);
        return 0;
    return 1;
static void tiny210_ts_timer_function(unsigned long data)
    if(tiny210_ts_regs->tsdatx1 & (1<<15))
            input_report_abs(tiny210_ts_dev, ABS_PRESSURE, 0);
            input_report_key(tiny210_ts_dev, BTN_TOUCH, 0);
            input_sync(tiny210_ts_dev);
            enter_wait_pen_down_mode();
    else
            enter_measure_xy_mode();
            start_adc();
static irqreturn_t adc_irq(int irq, void *dev_id)
    tiny210_ts_regs->clrintadc1 = 0;
    static int cnt = 0;
    static int x[4], y[4];
    int adcdatx,adcdaty;
    adcdatx = tiny210_ts_regs->tsdatx1;
    adcdaty = tiny210_ts_regs->tsdaty1;
            cnt = 0;
    else
            //printk("adc_irq cnt = %d, x = %d, y = %d
",++cnt,adcdatx & 0xfff, adcdaty & 0xfff);
            x[cnt] = adcdatx & 0xfff;
            y[cnt] = adcdaty & 0xfff;
            ++cnt;
            if(cnt == 4)
                    if(tiny210_filter_ts(x,y))
                            //printk("x = %d, y = %d
",(x[0]+x[1]+x[2]+x[3])/4, (y[0]+y[1]+y[2]+y[3])/4);
                            input_report_abs(tiny210_ts_dev, ABS_X, (x[0]+x[1]+x[2]+x[3])/4);
                            input_report_abs(tiny210_ts_dev, ABS_Y, (y[0]+y[1]+y[2]+y[3])/4);
                            input_report_abs(tiny210_ts_dev, ABS_PRESSURE, 1);
                            input_report_key(tiny210_ts_dev, BTN_TOUCH, 1);
                    cnt = 0;
                    enter_wait_pen_up_mode();
            else
                    start_adc();
    return IRQ_HANDLED;
static irqreturn_t pen_down_up_irq(int irq, void *dev_id)
    tiny210_ts_regs->clrintpen1 = 0;
            //printk("pen up
    else
            //printk("pen down
            //enter_wait_pen_up_mode();
            start_adc();
    return IRQ_HANDLED;
static int tiny210_ts_init(void)
    struct clk* clk;
    tiny210_ts_dev = input_allocate_device();
    set_bit(EV_KEY, tiny210_ts_dev->evbit);
    set_bit(EV_ABS, tiny210_ts_dev->evbit);
    set_bit(BTN_TOUCH, tiny210_ts_dev->keybit);
    input_set_abs_params(tiny210_ts_dev, ABS_X, 0, 0xfff, 0, 0);
    input_set_abs_params(tiny210_ts_dev, ABS_Y, 0, 0xfff, 0, 0);
    input_set_abs_params(tiny210_ts_dev, ABS_PRESSURE, 0, 1, 0, 0);
    input_register_device(tiny210_ts_dev);
    tiny210_ts_regs_1= ioremap(0xE1700000, sizeof(struct tiny210_ts_regs_1));
    tiny210_ts_regs = ioremap(0xE1701000,sizeof(struct tiny210_ts_regs));
    clk = clk_get(NULL, "adc");
    clk_enable(clk);
       tiny210_ts_regs_1->tsadccon0 = (1<<17);
    tiny210_ts_regs->tsadccon1 &= ~(1<<2);
    tiny210_ts_regs->tsadccon1 = (1<<14) (1<<16) (65<<6);
    request_irq(IRQ_PENDN1, pen_down_up_irq, IRQF_SAMPLE_RANDOM, "ts_pen", NULL);
    request_irq(IRQ_ADC1, adc_irq, IRQF_SAMPLE_RANDOM, "adc", NULL);
    tiny210_ts_regs->tsdly1 = 0xffff;
    init_timer(&ts_timer);
    ts_timer.function = tiny210_ts_timer_function;
    add_timer(&ts_timer);
    return 0;
static void tiny210_ts_exit(void)
    input_unregister_device(tiny210_ts_dev);
    input_free_device(tiny210_ts_dev);
    iounmap(tiny210_ts_regs);
    iounmap(tiny210_ts_regs_1);
    free_irq(IRQ_PENDN1, NULL);
    free_irq(IRQ_ADC1, NULL);
    del_timer(&ts_timer);
module_init(tiny210_ts_init);
module_exit(tiny210_ts_exit);
MODULE_AUTHOR("jany_linux");
[table=100%,#ffffff]MODULE_LICENSE("GPL");
[/table][/hide]
购买主题 本主题需向作者支付 5 枚金币 才能浏览
社区居民忠实会员社区劳模原创达人终身成就奖
发表于 2016-9-6 19:14:46 | 显示全部楼层
社区居民忠实会员社区劳模最爱沙发终身成就奖优秀斑竹奖
发表于 2016-9-7 08:53:00 | 显示全部楼层
发表于 2017-4-26 10:02:31 | 显示全部楼层
社区居民忠实会员终身成就奖
发表于 2020-3-3 14:19:44 | 显示全部楼层
    5 小时前
  • 签到天数: 144 天
    发表于 2020-9-10 08:38:15 | 显示全部楼层
    5 小时前
  • 签到天数: 144 天
    发表于 2020-9-14 09:00:09 | 显示全部楼层
    5 小时前
  • 签到天数: 144 天
    发表于 2020-9-15 08:54:37 | 显示全部楼层
    5 小时前
  • 签到天数: 144 天
    发表于 2020-12-23 08:57:34 | 显示全部楼层
    5 小时前
  • 签到天数: 144 天
    发表于 2020-12-24 08:47:36 | 显示全部楼层
