查看: 9791|回复: 67
[Allegro16.6以下] 独一无二 PXA310 方案PCB 和原理图整套资料共享 HDI盲孔埋孔
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2016-9-21 09:24:35 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    资料不是最新,但是绝对是全网唯一, 就连这个CPU 的板子,互联网上也找不到一个。
    AN4ANT_2_ANT_CONN_ANT_WIFIANT_WIFIANT_CONN
    BAT2BATTERY_MS621FE-FL11E_MS621FE-FMS621FE-FL11EMS621FE-FL11E
    BAT34HEADER_0_SMT_CON4_1_25MM_4 HE4 HEADERSMT_CON4_1_25MM
    D11.5KE100A_DO-214AA_B340B340DO-214AA
    D31.5KE100A_SOD123_A_MBR0530T1GMBR0530T1GSOD123_A
    D4LED_LN1351CRED_LEDD_LED-0603
    D5LED_LN1351CRED_LEDD_LED-0603
    D61.5KE100A_SOD123_A_MBR0530T1GMBR0530T1GSOD123_A
    D7DIODEZENER1_SOD123_A_MBRM120LTMBRM120LT1GSOD123_A
    D8DIODEZENER1_SOD123_A_MBRM120LTMBRM120LT1GSOD123_A
    D9DIODEZENER1_SOD123_A_MBRM120LTMBRM120LT1GSOD123_A
    D10LED_LN1351CRED_LEDD_LED-0603
    D11LED_LN1351CRED_LEDD_LED-0603
    D14DIODE BI-DIRTRIG_SOD_523_NW_SESESD5Z5CSOD_523_NW
    D15DIODE BI-DIRTRIG_SOD_523_NW_SESESD5Z5CSOD_523_NW
    D16DIODE BI-DIRTRIG_SOD_523_NW_SESESD5Z5CSOD_523_NW
    D17DIODE BI-DIRTRIG_SOD_523_NW_SESESD5Z5CSOD_523_NW
    D18DIODE BI-DIRTRIG_SOD_523_NW_SESESD5Z5CSOD_523_NW
    D19DIODE BI-DIRTRIG_SOD_523_NW_SESESD5Z5CSOD_523_NW
    D20DIODE BI-DIRTRIG_SOD_523_NW_SESESD5Z5CSOD_523_NW
    D211.5KE100A_SOD123_A_MBR0530T1GMBR0530T1GSOD123_A
    D22DIODEZENER1_SOD123_A_MBRM120LTMBRM120LT1GSOD123_A
    D231.5KE100A_SOD123_A_MBR0530T1GMBR0530T1GSOD123_A
    D24LED_LN1351CRED_LEDD_LED-0603
    D25DIODE BI-DIRTRIG_SOD_523_NW_SESESD5Z5CSOD_523_NW
    D26LED_LN1351CRED_LEDD_LED-0603
    D27DIODE BI-DIRTRIG_SOD_523_NW_SESESD5Z5CSOD_523_NW
    D28DIODE BI-DIRTRIG_SOD_523_NW_SESESD5Z5CSOD_523_NW
    D29DIODETVS_SOD_523_SESD5Z7VSESD5Z7VSOD_523
    D30LED_LN1351CRED_LEDD_LED-0603
    D31LED_LN1351CRED_LEDD_LED-0603
    D32LED_LN1351CRED_LEDD_LED-0603
    D33LED_LN1351CRED_LEDD_LED-0603
    D37DIODETVS_SOD_523_SESD5Z5VSESD5Z5VSOD_523
    D38DIODETVS_SOD_523_SESD5Z5VSESD5Z5VSOD_523
    D39DIODETVS_SOD_523_SESD5Z5VSESD5Z5VSOD_523
    D40DIODETVS_SOD_523_SESD5Z5VSESD5Z5VSOD_523
    D41DIODETVS_SOD_523_SESD5Z5VSESD5Z5VSOD_523
    D42DIODETVS_SOD_523_SESD5Z5VSESD5Z5VSOD_523
    D43DIODETVS_SOD_523_SESD5Z5VSESD5Z5VSOD_523
    D44DIODETVS_SOD_523_SESD5Z5VSESD5Z5VSOD_523
    D45DIODETVS_SOD_523_SESD5Z5VSESD5Z5VSOD_523
    D46DIODETVS_SOD_523_SESD5Z5VSESD5Z5VSOD_523
    D521.5KE100A_SOD123_A_MBR0530T1GMBR0530T1GSOD123_A
    D531.5KE100A_SOD123_A_MBR0530T1GMBR0530T1GSOD123_A
    D541.5KE100A_SOD123_A_MBR0530T1GMBR0530T1GSOD123_A
    D551.5KE100A_SOD123_A_MBR0530T1GMBR0530T1GSOD123_A
    D561.5KE100A_SOD123_A_MBR0530T1GMBR0530T1GSOD123_A
    D58DIODETVS_SOD_523_SESD5Z5VSESD5Z5VSOD_523
    D601.5KE100A_SOD123_A_MBR0530T1GMBR0530T1GSOD123_A
    D611.5KE100A_SOD123_A_MBR0530T1GMBR0530T1GSOD123_A
    D621.5KE100A_SOD123_A_MBR0530T1GMBR0530T1GSOD123_A
    F1FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F2FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F3FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F4FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F5FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F6FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F7FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F8FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F9FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F10FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F11FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F12FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F13FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F14FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F15FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F16FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F17FUSE_R_1812_PTC1500MAPTC1500mAR_1812
    F20FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F21FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F22FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F24FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    F25FUSE_0_F_0805_SMD0805P110TFSMD0805P110TFF_0805
    FB3FB_0_L0603_MMZ1608S301MMZ1608S301L0603
    FB4FB_0_L0603_MMZ1608S301MMZ1608S301L0603
    FB5FB_0_L0603_MMZ1608S301MMZ1608S301L0603
    FB6FB_0_L0603_MMZ1608S301MMZ1608S301L0603
    FB8FB_0_L0603_MMZ1608S301MMZ1608S301L0603
    FB9FB_0_L0603_MMZ1608S301MMZ1608S301L0603
    H1CON1_T71_CON1CON1T71
    H2CON1_T71_CON1CON1T71
    H3CON1_T71_CON1CON1T71
    H4CON1_T71_CON1CON1T71
    J1CON40_2_FH19SC-40S-5_FH19SC-40SFH19SC-40S-0.5SHFH19SC-40S-5
    J2OV3640CON_0_FH19SC-24S-5_CA_FHFH19SC-24S-0.5SHFH19SC-24S-5_CA
    J3CON24_0_FH19SC-24S-5_FH19SC-24SFH19SC-24S-0.5SHFH19SC-24S-5
    J4POWER_IN_0_DC_01_03_A_POWER_INPOWER_IN 2.1-12DC_01_03_A
    J5CON24_0_FH19SC-24S-5_FH19SC-24SFH19SC-24S-0.5SHFH19SC-24S-5
    J6SDCARDSOCKET_1_T_FLASH_T-FLASHT-Flash SocketT_FLASH
    J8CON4_0_FH19SC-4S-5_FH19SC-4S-0.FH19SC-4S-0.5SHFH19SC-4S-5
    J13SUBD9_M_COUDE_SUBD9M_H_C_SUBD9_SUBD9_M_COUDESUBD9M_H_C
    J14MC58_2_MINI_USB_5AB_HMT-USB-008HMT-USB-00810-005MINI_USB_5AB
    J15USB_A_2_USB_A3160104-X90-R_USB_USB_AUSB_A3160104-X90-R
    J16CON40ACON40ADIP40_P2MM
    J17J2GS-NS2-88-3.05RJ45_BOT_P254MM
    J18J2GS-NS2-88-3.05RJ45_BOT_P254MM
    J19USB_A_2_USB_A3160104-X90-R_USB_USB_AUSB_A3160104-X90-R
    L1INDUCTOR_L26W28_VLF3010AT-2R2M1VLF3010AT-2R2M1R0L26W28
    L2INDUCTOR_L26W28_VLF3010AT-2R2M1VLF3010AT-2R2M1R0L26W28
    L3INDUCTOR_L26W28_VLF3010AT-2R2M1VLF3010AT-2R2M1R0L26W28
    L4L_CDRH3D14_CDRH3D14/HPNP-6R8NCDRH3D14/HPNP-6R8NCDRH3D14
    L5L_0_CDRH3D14_CDRH3D14/HPNP-6R8NCDRH3D14/HPNP-6R8NCDRH3D14
    L6L_CDRH2D14_CDRH2D14NP-2R2NCDRH2D14NP-2R2NCDRH2D14
    L7L_CDRH2D14_CDRH2D14NP-2R2NCDRH2D14NP-2R2NCDRH2D14
    L8L_CDRH3D14_CDRH3D14/HPNP-6R8NCDRH3D14/HPNP-6R8NCDRH3D14
    MIC1MICROPHONE_4_DKO4015BP323C1033-DKO4015BP323C1033-022DKO4015BP323C1033-022
    Q21R1001_0_D_SOT23_STD_A_90139013D_SOT23_STD_A
    Q4IRLML6302_D_SOT23_STD_A_IRLML63IRLML6302D_SOT23_STD_A
    Q51R1001_0_D_SOT23_STD_A_90139013D_SOT23_STD_A
    Q71R1001_0_D_SOT23_STD_A_90139013D_SOT23_STD_A
    Q91R1001_0_D_SOT23_STD_A_90139013D_SOT23_STD_A
    Q111R1001_0_D_SOT23_STD_A_90139013D_SOT23_STD_A
    Q12Q2N3508_3_D_SOT23_STD_A_90139013D_SOT23_STD_A
    S1SWPUSHBUTTON-SPST_0_L123_STS-0STS-06L123
    S2SWPUSHBUTTON-SPST_0_L123_STS-0STS-06L123
    SPK1SPEAKER_4_SMT_CON2_1_0MM_AV6020AV6020-AOX14SMT_CON2_1_0MM
    SPK2SPEAKER_4_SMT_CON2_1_0MM_AV6020AV6020-AOX14SMT_CON2_1_0MM
    U1MHLV_BGA50P24X24-400_88AP31088AP310BGA50P24X24-400
    U2K9F1216U0A_Y_4_TSOP48_P5MM_K9F2K9F2G08U0A-PCB00TSOP48_P5MM
    U34506_6_P_VFBGA60_P8MM_EDD10163BEDD10163BH-5ELS-FP_VFBGA60_P8MM
    U5100302_21_QFN24_P5MM_USB3319C-CUSB3319C-CP-TRQFN24_P5MM
    U6DS2411_D_SOT23_STD_A_DS2411DS2411D_SOT23_STD_A
    U7DM9000AE_4_LQFP48_P5MM_ETHERNETETHERNETLQFP48_P5MM
    U8LP3972_0_QFN5X5_40_A_LP3972SQ-ELP3972SQ-E514QFN5X5_40_A
    U9DS1302Z_SOIC8_DS1302ZNDS1302ZNSOIC8
    U10WM9714LGEFL/RV_3_QFN48_P5MM_WM9WM9713LGEFL/RVQFN48_P5MM
    U11EL2019/EL_3_MSOP8_P65MM_KBA2338KBA2338B-MSOPMSOP8_P65MM
    U12KB4313_3_SOT23_6LEAD_KB4317GREKB4317GRESOT23_6LEAD
    U13MIC5207_13_SOT23_5LEAD_XC6219B3XC6219B332MRSOT23_5LEAD
    U14XC9013_3_SOT23_5LEAD_SP6641BEK-SP6641BEK-5.0/TRSOT23_5LEAD
    U15KB4313_3_SOT23_6LEAD_KB4317GREKB4317GRESOT23_6LEAD
    U16RT9711D_3_SOT23_5LEAD_TPS2051BTPS2051BSOT23_5LEAD
    U17ISP1105BS_HBCC16_1105_ISP1105WISP1105WHBCC16_1105
    U18SP3223E_0_TSSOP20_P65MM_SP3223ESP3223ECATSSOP20_P65MM
    U19MIC5207_13_SOT23_5LEAD_XC6219B1XC6219B152MRSOT23_5LEAD
    U20MIC5207_13_SOT23_5LEAD_XC6219B2XC6219B282MRSOT23_5LEAD
    U21MIC5207_13_SOT23_5LEAD_XC6219_1XC6219B302MRSOT23_5LEAD
    U22PIC16F506_1_TSSOP20_P65MM_PIC16PIC16F687-I/SSTSSOP20_P65MM
    U23MIC5207_13_SOT23_5LEAD_XC6219B3XC6219B332MRSOT23_5LEAD
    U24EL2019/EL_3_MSOP8_P65MM_KBA2338KBA2338B-MSOPMSOP8_P65MM
    U25MIC5207_13_SOT23_5LEAD_XC6219B3XC6219B332MRSOT23_5LEAD
    U27P3000_15_TH-BT41_TH-BT41TH-BT41TH-BT41
    U28MIC5207_13_SOT23_5LEAD_XC6219B3XC6219B332MRSOT23_5LEAD
    U29WM-G-MR-09_0_WM-G-MR-09_WM-G-MRWM-G-MR-09WM-G-MR-09
    U30DM9000AE_4_LQFP48_P5MM_ETHERNETETHERNETLQFP48_P5MM
    U33SI9435_2_SOIC8_SI9435DYSi9435DYSOIC8
    U35U29AU9254SSOP28_P65MM
    U36BQ24032A_3_R_PQFP_N20_5MM_BQ240BQ24032ARHLTR_PQFP_N20_5MM
    U37PH163539_H1102_PH163539GPH163539GH1102
    U38RT8020_2_DFN12_P45MM_RT8020APQWRT8020APQWDFN12_P45MM
    U39PH163539_H1102_PH163539GPH163539GH1102
    U43SI9435_2_SOIC8_SI9435DYSi9435DYSOIC8
    Y1CRYSTAL_0_SSPT7_A_32.768KHZ32.768KHzSSPT7_A
    Y2CRYSTAL_2_MINI_CRYSTAL_A_13MHZ13MHzMINI_CRYSTAL_A
    Y3CRYSTAL_0_SSPT7_A_32.768KHZ32.768KHzSSPT7_A
    Y4CRYSTAL_1_CRYSTAL24_576_25M25MCRYSTAL24_576
    Y5CRYSTAL_2_MINI_CRYSTAL_A_12MHZ12MHzMINI_CRYSTAL_A
    Y8CRYSTAL_1_CRYSTAL24_576_25M25MCRYSTAL24_576
    游客,如果您要查看本帖隐藏内容请回复
    重要提示:PCB作品文件展下载说明
    社区居民社区劳模原创达人最爱沙发忠实会员终身成就奖优秀斑竹奖
    发表于 2016-9-21 09:34:47 | 显示全部楼层
    社区居民忠实会员社区劳模最爱沙发终身成就奖优秀斑竹奖
    发表于 2016-9-21 11:03:49 | 显示全部楼层
    谢谢分享~ 看起来很高大上啊~
    困……
    发表于 2016-9-21 11:22:27 | 显示全部楼层
    终身成就奖社区居民忠实会员社区劳模最爱沙发原创达人优秀斑竹奖
    发表于 2016-9-21 12:54:21 | 显示全部楼层
    Marvell公司中央处理器简介 基于第三代Intel XScale技术的这一Marvell PXA3xx应用处
    终身成就奖社区居民忠实会员
    发表于 2016-9-21 14:45:49 | 显示全部楼层
    社区居民忠实会员社区劳模原创达人最爱沙发终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2016-9-21 17:05:43 | 显示全部楼层
    发表于 2016-9-21 18:02:02 | 显示全部楼层
    发表于 2016-9-21 21:03:52 | 显示全部楼层
    学习学习,谢谢。。。。。。
    社区居民忠实会员社区劳模终身成就奖
    发表于 2016-9-22 08:16:25 | 显示全部楼层
    这可真少见啊。。。
    因为卖的太少了。。。
    哈哈。。。多谢分享!
