查看: 20951|回复: 124
[Allegro16.6以下] 富士康 8层盲孔埋孔 PXA935 智能手机 PCB文件共享下载
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2016-9-21 09:42:00 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    ANT1200M-ANT-3_42X1_5-1S1EM/CONN/SPRING/WN9149-N246-TR/FOXCONNM-ANT-3_42X1_5-1S1
    ANT1201M-ANT-3_42X1_5-1S1EM/CONN/SPRING/WN9149-N246-TR/FOXCONNM-ANT-3_42X1_5-1S1
    ANT1202M-ANT-3_42X1_5-1S1NI/EM/CONN/SPRING/WN9149-N246-TR/FOXCONNM-ANT-3_42X1_5-1S1
    ANT1401M-E-POGOPINEM/CONN/PoGOPIN/N103M5-01C000CR/PCCPM-E-POGOPIN
    ANT1500M-POGO-7_54X4_5-2EM/CONN/POGOPIN/P0620AA0002250RR/PCCPM-POGO-7_54X4_5-2
    ASW1M-TBGA-3X4-10S1AnalogSwitch/NLAS4717EPFCT1G/ONM-TBGA-3X4-10S1
    ASW300M-TBGA-3X4-10S1NL/IC/AnalogSwitch/MAX4717EBC-T/MAXIMM-TBGA-3X4-10S1
    CAVCAVITY_NUMBERS0-PADNI/CAVITY_NUMBERCAVITY_NUMBERS0-PAD
    CC100M-BA-XH311HGBackup Batt/XH311HGIV07E/SEIKOM-BA-XH311HG
    D1M-SOD-323NL/D/B0540WS/40V/0.5A/SOD323M-SOD-323
    D100M-SOD-323NL/D/B0540WS/40V/0.5A/SOD323M-SOD-323
    D101M-L-0402H0_5VARISTOR/22V/1A/0402M-L-0402H0_5
    D102M-L-0402H0_5VARISTOR/22V/1A/0402M-L-0402H0_5
    D103M-SOD-323NL/DIODE/ZENER/UDZSTE-174.3B/ROHMM-SOD-323
    D104M-SC-79NL/DIODE/30V/200mA/EMD2M-SC-79
    D405M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    D500M-L-0603H0_8F/Fuse/1.5A/0603/LITTELFUSEM-L-0603H0_8
    D501M-SC-79DIODE/30V/200mA/EMD2/RB520S-30TE61M-SC-79
    D601M-SC-79DIODE/30V/200mA/EMD2M-SC-79
    D602M-SC-79DIODE/30V/200mA/EMD2M-SC-79
    D700M-LD-S1_6X0_8-2LED/LTW-C193SN5/LITEONM-LD-S1_6X0_8-2
    D704M-LD-S1_6X0_8-2LED/LTW-C193SN5/LITEONM-LD-S1_6X0_8-2
    D705M-LD-S1_6X0_8-4LED/EVERLIGHT/18-225/R6G6C-A01/3T/Bi-colorStatus LEDM-LD-S1_6X0_8-4
    D1000M-LD-S2X1_4-2IRLED/CM3650D3WU/CapellaM-LD-S2X1_4-2
    D1101M-SOD-323DIODE/SBD/30V/0.5A/B0530WS-7-F/SOD-323/DIODESM-SOD-323
    D1800M-SOD-523Diode/ZEN/3.9V/200mW/BZX584C3V9M-SOD-523
    E2M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E3M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E500M-L-0402H0_6VARISTOR/14V/1A/0402/TVM0G140M151R/TKSM-L-0402H0_6
    E501M-L-0402H0_6ESD/VARISTOR/5V/0.00005mA/0402M-L-0402H0_6
    E502M-L-0402H0_6ESD/VARISTOR/5V/0.00005mA/0402M-L-0402H0_6
    E503M-L-0402H0_6ESD/VARISTOR/5V/0.00005mA/0402M-L-0402H0_6
    E504M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E505M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E506M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E507M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E508M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E700M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E714M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E715M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E716M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E717M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E718M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E719M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E720M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E721M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E722M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E723M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E724M-L-0402H0_5NL/VARISTOR/11V/1A/0402M-L-0402H0_5
    E725M-L-0402H0_5NI/VARISTOR/11V/1A/0402M-L-0402H0_5
    E1101M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E1102M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E1105M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    E1106M-L-0402H0_5VARISTOR/11V/1A/0402M-L-0402H0_5
    F1M-L-0603H0_8FUSE/32V/2.5A/049402.5NRHF/0603M-L-0603H0_8
    F100M-L-0603H0_8FUSE/32V/2.5A/049402.5NRHF/0603M-L-0603H0_8
    F400M-L-0603H0_8F/Fuse/1.5A/0603/LITTELFUSEM-L-0603H0_8
    F1101M-L-0603H0_8F/Fuse/1.5A/0603/LITTELFUSEM-L-0603H0_8
    FIL1500M-FIL-1_35X1_05-5AS0FILTER/1574.22-1576.62MHzM-FIL-1_35X1_05-5AS0
    FIL1501M-FIL-1_35X1_05-5AS0FILTER/1574.22-1576.62MHzM-FIL-1_35X1_05-5AS0
    J100M-BA-H003M7-3S2EM/CONN//H003M7-H03A310RR/PCCPM-BA-H003M7-3S2
    J400M-CN-DF30FC-24DSEM/CONN/CameraConnector/DF30FC-24DS-0.4V(81)/HIROSEM-CN-DF30FC-24DS
    J401M-CN-DF30FC-20DSEM/CONN/B-to-B/20pinsM-CN-DF30FC-20DS
    J402M-POGO-3_8X2-2S1EM/CONN/POGOPIN/H199M0-H02A170MR/PCCPM-POGO-3_8X2-2S1
    J500M-CN-FLZ-12BEM/CONN/ICECconnectorM-CN-FLZ-12B
    J501M-CJ-USB-2UB3122S2EM/CONN/10-PinUSBCONN/2UB2003-000111/singatronM-CJ-USB-2UB3122S2
    J502M-MODULE-T77N144T00S2EM/CONN/SUB-PCB-VIBRATORM-MODULE-T77N144T00S2
    J601M-CN-DF30FC-70DP-HDEM/CONN/70-Pin LCDCONNECTORM-CN-DF30FC-70DP-HD
    J602M-CN-S5X2-0_4SKEM/CONN/10pin BTBConnector/DF40C-10DS-0.4VM-CN-S5X2-0_4SK
    J700M-CJ-SIMCLE9114EM/CONN/SD&SIM/CLE9114-5703ESZ/SMKM-CJ-SIMCLE9114
    J703MTH067NL/Screw pin-holeMTH067
    J704MTH067NL/Screw pin-holeMTH067
    J705M-SIDEKEY-3BS0NL/EM/CONN/SIDEKEY-FPCPADM-SIDEKEY-3BS0
    J706M-SIDEKEY-4NL/EM/CONN/camerakey-FPC PADM-SIDEKEY-4
    J707M-SW-PADD6I2_2NI/KEYPAD/KEYM-SW-PADD6I2_2
    J708M-MTH043NL/Screw pin-holeM-MTH043
    J717M-MTH043NL/Screw pin-holeM-MTH043
    J718M-MTH043NL/Screw pin-holeM-MTH043
    J1200M-CN-KMC1001EM/CONN/CARKITM-CN-KMC1001
    J1401M-CN-KMC1001EM/CONN/CARKITM-CN-KMC1001
    J1601M-CN-S5X2-0_4S0EM/CONN/10pin BTBConnector/DF37B-10DS-0.4VM-CN-S5X2-0_4S0
    J7050M-MPTH98R158FNI/Screw boss-holeM-MPTH98R158F
    J7060M-MPTH98R158FNI/Screw boss-holeM-MPTH98R158F
    J7070MTH067NL/Screw pin-holeMTH067
    J7100MTH098NI/Screw boss-holeMTH098
    L1M-L-0402H0_5BEAD/220ohm/300mA/0.5ohm/0402M-L-0402H0_5
    L2M-L-LPS3015S0L/2.2UH/1.5A/0402M-L-LPS3015S0
    L3M-L-LPS3015S0L/2.2UH/1.5A/0402M-L-LPS3015S0
    L4M-L-LPS3015S0L/2.2UH/1.5A/0402M-L-LPS3015S0
    L5M-L-0402H0_5BEAD/220ohm/300mA/0.5ohm/0402M-L-0402H0_5
    L6M-L-0402H0_5RD/BEAD/600ohm/250mA/0.56ohm/0402M-L-0402H0_5
    L11M-L-0402H0_5BEAD/70ohm/500mA/0.15ohm/0402M-L-0402H0_5
    L12M-L-0402H0_5BEAD/70ohm/500mA/0.15ohm/0402M-L-0402H0_5
    L100M-L-S3X2_8L/3.3uH/1.1A/0.11ohmM-L-S3X2_8
    L101M-L-VLF3010AS0L/4.7uH/700mA/0.28ohmM-L-VLF3010AS0
    L400M-L-0402H0_5BEAD/1000ohm/200mA/1ohm/0402M-L-0402H0_5
    L500M-L-0402H0_5BEAD/120ohm/100MHz/1.3A/0.09ohm/0402M-L-0402H0_5
    L601M-L-0402H0_5BEAD/220ohm/300mA/0.5ohm/0402M-L-0402H0_5
    L602M-L-0402H0_5BEAD/220ohm/300mA/0.5ohm/0402M-L-0402H0_5
    L603M-L-0402H0_5BEAD/220ohm/300mA/0.5ohm/0402M-L-0402H0_5
    L700M-L-0402H0_5BEAD/1000ohm/200mA/1ohm/0402M-L-0402H0_5
    L701TOP10R-4S0NI/optics pointTOP10R-4S0
    L702TOP15L-4S0NI/optics pointTOP15L-4S0
    L703TOP15R-4S0NI/optics pointTOP15R-4S0
    L704TOP10L-4S0NI/optics pointTOP10L-4S0
    L706M-L-0402H0_45L/100nH/5%/150mA/1.25ohm/0402M-L-0402H0_45
    L707M-L-0402H0_45L/100nH/5%/150mA/1.25ohm/0402M-L-0402H0_45
    L708M-L-0402H0_5BEAD/1000ohm/200mA/1ohm/0402M-L-0402H0_5
    L709M-L-0402H0_5BEAD/1000ohm/200mA/1ohm/0402M-L-0402H0_5
    L1000M-L-0402H0_5BEAD/1000ohm/200mA/1ohm/0402M-L-0402H0_5
    L1101M-L-0402H0_5BEAD/1000ohm/200mA/1ohm/0402M-L-0402H0_5
    L1102M-L-0402H0_5BEAD/1000ohm/200mA/1ohm/0402M-L-0402H0_5
    L1103M-L-0402H0_5BEAD/220ohm/300mA/0.5ohm/0402M-L-0402H0_5
    L1104M-L-0402H0_5BEAD/220ohm/300mA/0.5ohm/0402M-L-0402H0_5
    L1107M-L-0402H0_5BEAD/1000ohm/200mA/1ohm/0402M-L-0402H0_5
    L1108M-L-0402H0_5BEAD/1000ohm/200mA/1ohm/0402M-L-0402H0_5
    L1109M-L-0402H0_5BEAD/220ohm/300mA/0.5ohm/0402M-L-0402H0_5
    L1118M-L-VLF3010AS0L/4.7uH/700mA/0.28ohmM-L-VLF3010AS0
    L1119M-L-0402H0_5BEAD/1000ohm/200mA/1ohm/0402M-L-0402H0_5
    L1200M-L-0402H0_5BEAD/1000ohm/200mA/1ohm/0402M-L-0402H0_5
    L1201M-L-0402H0_5BEAD/1000ohm/200mA/1ohm/0402M-L-0402H0_5
    L1203M-L-0402H0_45L/18nH/300mA/0402M-L-0402H0_45
    L1204M-L-0402H0_45NI/L/18nH/300mA/0402M-L-0402H0_45
    L1205M-L-0402H0_45L/12nH/300mA/0.41ohm/Q=8/0402M-L-0402H0_45
    L1206M-L-0402H0_45L/15nH/300mA/0.41ohm/Q=8/0402M-L-0402H0_45
    L1207M-L-0402H0_45NI/LM-L-0402H0_45
    L1208M-L-0402H0_45NI/LM-L-0402H0_45
    L1209M-L-0402H0_45NI/LM-L-0402H0_45
    L1210M-L-0402H0_45NI/LM-L-0402H0_45
    L1211M-L-0402H0_45NI/LM-L-0402H0_45
    L1212M-L-0402H0_45L/3.9nH/300mA/0402M-L-0402H0_45
    L1213M-L-0402H0_45L/3.9nH/300mA/0402M-L-0402H0_45
    L1214M-L-0402H0_45L/3.3nH/300mA/0402M-L-0402H0_45
    L1215M-L-0402H0_45L/3.3nH/300mA/0402M-L-0402H0_45
    L1216M-L-0402H0_45L/56nH/300mA/0402M-L-0402H0_45
    L1217M-L-0402H0_45L/6.8nH/300mA/0.29ohm/Q=8/0402M-L-0402H0_45
    L1218M-L-0402H0_45L/1.5nH/300mA/0402M-L-0402H0_45
    L1219M-L-0402H0_45L/5.1nH/140mA/0402M-L-0402H0_45
    L1220M-L-0402H0_45NI/L/18nH/300mA/0402M-L-0402H0_45
    L1221M-L-0402H0_45NI/L/18nH/300mA/0402M-L-0402H0_45
    L1300M-L-0402H0_45NI/L/8.2nH/300mA/0402M-L-0402H0_45
    L1301M-L-0402H0_45NI/L/8.2nH/300mA/0402M-L-0402H0_45
    L1302M-L-0402H0_45NI/L/8.2nH/300mA/0402M-L-0402H0_45
    L1303M-L-0402H0_45L/2.2nH/300mA/0402M-L-0402H0_45
    L1304M-L-0402H0_45L/3.3nH/300mA/0402M-L-0402H0_45
    L1408M-L-0402H0_5BEAD/220ohm/300mA/0.5ohm/0402M-L-0402H0_5
    L1409M-L-0402H0_5NI/BEAD/220ohm/300mA/0.5ohm/0402M-L-0402H0_5
    L1501R-0402H014HS40R/0ohm/0402/5%R-0402H014HS40
    L1502M-L-0402H0_45L/6.8nH/300mA/0.29ohm/Q=8/0402M-L-0402H0_45
    L1503M-L-0402H0_45L/6.8nH/300mA/0.29ohm/Q=8/0402M-L-0402H0_45
    L1504M-L-0402H0_5BEAD/1000ohm/200mA/1ohm/0402M-L-0402H0_5
    L1505M-L-0402H0_5BEAD/1000ohm/200mA/1ohm/0402M-L-0402H0_5
    Q5M-SOT-963NFET/20V/220mA/SOT963M-SOT-963
    Q100M-E-SI7911DNNL/PFET/DUALPFET/20V/4.2A/P-PAK1212-8/VISHAYM-E-SI7911DN
    Q101M-SOT-963NL/IC/DUAL-BJT/NST3904DP6-D/SOT963/ONM-SOT-963
    Q704M-SOT-963NFET/20V/220mA/SOT963M-SOT-963
    Q705M-SOT-963NFET/20V/220mA/SOT963M-SOT-963
    Q1101M-SC-70-6NFET/30V/2.6AM-SC-70-6
    U1M-TBGA-26X26-484S0PXA935M-TBGA-26X26-484S0
    U2M-TBGA-14X14-196S0NP/IC/DIALOG/DA9035-00-CV2M-TBGA-14X14-196S0
    U3M-TBGA-3X2-5IC/ANDGate/SN74AUP1G08YZPRM-TBGA-3X2-5
    U4M-MBGA-8X8-64IC/IS-3510-CF-RD64/InsilicaM-MBGA-8X8-64
    U9M-CQFN-4X4-20IC/PMIC/88PW886/MarvellM-CQFN-4X4-20
    U21M-TBGA-3X2-5IC/ANDGate/SN74AUP1G08YZPRM-TBGA-3X2-5
    U22M-TBGA-3X2-6S0NI/IC/TI/SN74LVC1G97YZPRM-TBGA-3X2-6S0
    U26M-SC-70-5IC/INVERTER/SN74AUP1G14/TIM-SC-70-5
    U301M-FBGA-15X10-137IC/MEM/SAMSUNG/KA100O015M-AJTTM-FBGA-15X10-137
    U401M-FIL-MEA1608LCAS0FILTER/EMI/6.3V/50mA/0603M-FIL-MEA1608LCAS0
    U402M-FIL-MEA1608LCAS0FILTER/EMI/6.3V/50mA/0603M-FIL-MEA1608LCAS0
    U403M-PLPL-4S2LDO/2.8V/150mA/PLP1010-4/RP103K281D-TR/RICOHM-PLPL-4S2
    U404M-TQFN-2X1_8-6SLDO/2.8V/300mA/RP102K281D-TRM-TQFN-2X1_8-6S
    U406M-TQFN-2X1_8-6SLDO/2.8V/300mA/RP102K281D-TRM-TQFN-2X1_8-6S
    U407M-FIL-MEA1608LCAS0FILTER/EMI/6.3V/50mA/0603M-FIL-MEA1608LCAS0
    U408M-FIL-MEA1608LCAS0FILTER/EMI/6.3V/50mA/0603M-FIL-MEA1608LCAS0
    U409M-TSSOP-8S1IC/Level shift1.8&2.8/DRIVER-LINE/TXS0102DCUR/TIM-TSSOP-8S1
    U413M-TQFN-3X3-10ASHS0IC/FLASHLED/SP6685ER-L/TR/EXARM-TQFN-3X3-10ASHS0
    U421M-PLPL-4S2LDO/1.8V/150mA/PLP1010-4/RP103K181D-TR/RICOHM-PLPL-4S2
    U500M-TQFN-2X2-8NL/IC/RTC/ISL12058IRUZ-T/IntersilM-TQFN-2X2-8
    U501M-TQFN-2_6X1_6-6S0LDO/3.3V/150mA/R1163D331B-TR/SON-6/RICOHM-TQFN-2_6X1_6-6S0
    U600M-TQFN-3X2-8NL/IC/GAUGEIC/MAX17040G+T/MAXIMM-TQFN-3X2-8
    U601M-FIL-MEA1608LCAS0FILTER/EMI/6.3V/50mA/0603M-FIL-MEA1608LCAS0
    U602M-FIL-MEA1608LCAS0FILTER/EMI/6.3V/50mA/0603M-FIL-MEA1608LCAS0
    U603M-FIL-MEA1608LCAS0FILTER/EMI/6.3V/50mA/0603M-FIL-MEA1608LCAS0
    U604M-FIL-MEA1608LCAS0FILTER/EMI/6.3V/50mA/0603M-FIL-MEA1608LCAS0
    U605M-FIL-MEA1608LCAS0FILTER/EMI/6.3V/50mA/0603M-FIL-MEA1608LCAS0
    U606M-FIL-MEA1608LCAS0FILTER/EMI/6.3V/50mA/0603M-FIL-MEA1608LCAS0
    U607M-CQFN-1_6X1_2-4SHS0LDO/3.3V/300mA/RP101K331D-TR/RICOHM-CQFN-1_6X1_2-4SHS0
    U610M-PLPL-4S2NP/LDO/3.1V/150mA/RP103K311D-TR/RICOHM-PLPL-4S2
    U700M-TBGA-5X4-20S0IC/ESD/NXP/IP4052CX20/LFM-TBGA-5X4-20S0
    U1000M-SR-2_35X1_8-6IC/Sensor/CM3602A3OP/CapellaM-SR-2_35X1_8-6
    U1003M-TLP-3X3-12IC/GSensor/BMA020/BOSCHM-TLP-3X3-12
    U1009M-TBGA-4X4-15NP/E-COMPASS/AKM/AK8973BM-TBGA-4X4-15
    U1101E-BECMS0EM/MICROPHONE/BSE/BECM-0413S-C1533E-BECMS0
    U1102M-TBGA-3X3-9AS0IC/AUDIOPA/YDA145_D-4H/YAMAHAM-TBGA-3X3-9AS0
    U1103M-TBGA-4X3-12CNL/IC/Earphone PA/MAX9724BEBC+TM-TBGA-4X3-12C
    U1200M-CLP-4_5X4_5-26SS0IC/GSMSwitch/plexer+SAW/LMSP4LMA_550T/MURATAM-CLP-4_5X4_5-26SS0
    U1201M-TBGA-9X9-72S0NP/TCVR/LS-R2A60177BG/RENESASM-TBGA-9X9-72S0
    U1202M-E-MODULE-T77N146NP/IC/ GSM/PA/LS-RPF59001B/RENESASM-E-MODULE-T77N146
    U1300M-FBGA-16X13-208NP/WCDMAModule/RGFW-I001A/LGM-FBGA-16X13-208
    U1404M-E-AW-GH831S0IC/WiFi&BT/AZUREWAVE/AW-GH381/88W8688ModuleM-E-AW-GH831S0
    U1500M-TLP-1_5X1-6S0IC/LNA/MAX2659ELT+/MAXIMM-TLP-1_5X1-6S0
    U1501M-PLPL-4S2LDO/1.8V/150mA/PLP1010-4/RP103K181D-TR/RICOHM-PLPL-4S2
    U1505M-TBGA-7X7-49AIC/GPS/GSD3TW-8220/WFBGA/SiRFM-TBGA-7X7-49A
    U1800M-TQFN-3X3-16ASHIC/Charge/BQ24072RGTM-TQFN-3X3-16ASH
    U1801M-TBGA-3X2-6S0IC/ChargeOCP/SN74LVC1G3157YZPRM-TBGA-3X2-6S0
    U1802M-TQFN-2X2-8ASNP/IC/Charge OVP/5.6~6.0V/ISL9211AIRU58XZ-TM-TQFN-2X2-8AS
    U1803M-SON-6ANP/R3133D20EA-TR-FM-SON-6A
    V005M-R-0201-H0_3S2NL/R/0/0201/5%M-R-0201-H0_3S2
    Y1M-O-3_2X1_5-2XTAL/32.768KHz/20ppm/12.5pFM-O-3_2X1_5-2
    Y500M-O-3_2X1_5-2NL/XTAL/32.768KHz/20ppm/12.5pFM-O-3_2X1_5-2
    Y1200M-O-2_5X2-6TCXO/TXC/7L26001005/26MHz/pm/10pFM-O-2_5X2-6
    Y1500M-O-2_5X2-6TCXO/16.369MHz/0.5ppm/10pF/7L16300003/TXCM-O-2_5X2-6
    全网首发,独一无二
    游客,如果您要查看本帖隐藏内容请回复
    重要提示:PCB作品文件展下载说明
    终身成就奖社区居民特殊贡献奖
    发表于 2016-9-21 10:09:41 | 显示全部楼层
    来学习学习了
    终身成就奖社区居民忠实会员
    发表于 2016-9-21 11:01:09 | 显示全部楼层
    来学习学习了+1
    发表于 2016-9-21 11:21:59 | 显示全部楼层
    终身成就奖社区居民宣传大使奖优秀斑竹奖
    发表于 2016-9-21 11:30:26 | 显示全部楼层
    好资料值得学习
    发表于 2016-9-21 11:56:13 | 显示全部楼层
    社区居民终身成就奖特殊贡献奖忠实会员社区明星宣传大使奖
    发表于 2016-9-21 12:47:57 | 显示全部楼层
    楼主太牛了,啥都有
    活着就是一种挑战!
    终身成就奖社区居民忠实会员灌水天才奖新人进步奖幽默大师奖贴图大师奖优秀斑竹奖宣传大使奖金点子奖社区明星
    发表于 2016-9-21 13:23:30 | 显示全部楼层
    看起来不错,下载看看
    发表于 2016-9-21 13:35:36 | 显示全部楼层
    发表于 2016-9-21 13:49:30 | 显示全部楼层
    手机板最好做参考了。
