查看: 11874|回复: 49
[Allegro16.6以下] OMAPL138+TVP5147M1PFP+MT29F4G16ABADAH4+LAN8710A-EZK+CDCM61001RHBT工业控制
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2016-10-4 08:19:36 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    请输入描述
    请输入描述
    BH1BATTERY_0_BATTERY_BATTERYHL, DBATTERY Hl, DNIBATTERY
    D1DIODEZENER_1_SOT23_3_BZX84B5V1BZX84B5V1LT1GSOT23_3
    D2LED_4_LED2-31SQ_LEDLEDLED2-31SQ
    D8TRANZORB_DO1006_CP64004TCP64004TDO1006
    DN1DIODE_DUAL_RS_AJK_1_SOT23_3_BAVBAV99LT1SOT23_3
    DN2DIODE_DUAL_RS_AJK_1_SOT23_3_BAVBAV99LT1SOT23_3
    FB1INDUCTOR_0805_MMZ2012S121AMMZ2012S121A805
    J1CONN_PWRJACK_RAPC712_RAPC712_POPower Jack RAPC712RAPC712
    J2MINI-USB-AB-SOCKET_2_USB5MINI_456579-0576USB5MINI_4SHIELDED_SMD-4
    J3MINI-USB-AB-SOCKET_2_USB5MINI_456579-0576USB5MINI_4SHIELDED_SMD-4
    J4MICROSD_CONN_8_SD-MICRO-SCHA5B0SCHA5B0200SD-MICRO-SCHA5B0300
    J5CONN_54819-0578_2_USB_A_SH_IO_UUSB-A Conn. -87520-xx1xxUSB_A_SH
    J6CON14AP_1_CON2X100P-14_V6_7245472454-014LFCON2X100P-14_V6
    J78HEADER_0_SATA_SD-67491-002SD-67491-002SATA
    J8CONN ASY CENT S/S14_1_DB15F_60070213FRDB15F_60-59LS
    J9CONNECTORCOAX-J_1_RCA4SMD_11X1RCJ-014RCA4SMD_11X15MM
    J10CX3_0.5-1230-08_CX3_5-1230-08_CCX3.5-1230-08CX3_5-1230-08
    J11KYCONST-3500_3_STX3500_STX-350STX-3500-4NTRSTX3500
    J13DUALUSB_ETHER_0_RJ45-2LED_ETHERETHERRJ45-2LED
    J14CONN PCB20X2-S_0_HEADER23X2_COCONN_PCB_23x2-SHEADER23X2
    J15CONN PCB20X2-S_0_HEADER23X2_COCONN_PCB_23x2-SHEADER23X2
    J16CONN FLEX36_0_CON36UPSMD_P5MM_52559-3652CON36UPSMD_P5MM
    JP1B2S_1_HEADER_2X1_HEADER2HEADER 2HEADER_2X1
    JP2HEADER_2X1_HEADER_2X1_HEADER2HEADER 2HEADER_2X1
    JP3HEADER_2X1_HEADER_2X1_HEADER2HEADER 2HEADER_2X1
    JP4HEADER_2X1_HEADER_2X1_HEADER2HEADER 2HEADER_2X1
    L1INDUCTORIRON_IND3P4SMD_5SQ_2.22.2uH/1.7AIND3P4SMD_5SQ
    L2INDUCTORIRON_IND3P4SMD_5SQ_3.33.3uH/2.6AIND3P4SMD_5SQ
    L3INDUCTORIRON_IND3P4SMD_5SQ_2.22.2uH/1.7AIND3P4SMD_5SQ
    L4INDUCTOR_0805_1UH/80MA1uH/80mA805
    L5INDUCTOR_0805_1UH/80MA1uH/80mA805
    L6INDUCTOR_0805_1UH/80MA1uH/80mA805
    P1HEADER_10X2_0_CONN2X10_4028_HEAHEADER_10X2CONN2X10_4028
    P2HEADER_10X2_0_CONN2X10_4028_HEAHEADER_10X2CONN2X10_4028
    Q12N1613_1_SOT23_3_MMBT3904LT1GMMBT3904LT1GSOT23_3
    Q22N1613_1_SOT23_3_MMBT3904LT1GMMBT3904LT1GSOT23_3
    Q32N1613_1_SOT23_3_MMBT3904LT1GMMBT3904LT1GSOT23_3
    Q42N1613_1_SOT23_3_MMBT3904LT1GMMBT3904LT1GSOT23_3
    Q5RN1907_SMINI6-F3-B_DMC56404DMC56404SMINI6-F3-B
    Q6RN1907_SMINI6-F3-B_DMC56404DMC56404SMINI6-F3-B
    S1SW_KT11P2JM_4_SWRST4_177X256LS-B3F-1000SWRST4_177X256LS-1
    S2SW_KT11P2JM_4_SWRST4_177X256LS-B3F-1000SWRST4_177X256LS-1
    S3SW_KT11P2JM_4_SWRST4_177X256LS-B3F-1000SWRST4_177X256LS-1
    SW1SWDIP-8/SM_SWDIP16_340SMD_SW DSW DIP-8/SMSWDIP16_340SMD
    TP19T POINT A_BEZEL_BEZELbezelBEZEL
    TP20T POINT A_BEZEL_BEZELbezelBEZEL
    U1TPS3705_0_SOIC8_TPS3707-33DRTPS3707-33DRSOIC8
    U2IC_MCP349_0_DFN6-1P6X2_NCP349MNNCP349MNAEDFN6-1P6X2
    U3TPS650250_3_QFN32_9V_TPS650250RTPS650250RHBRQFN32_9V
    U4TPS2087B_SOIC16_TPS2087DTPS2087DSOIC16
    U5TPS2087_1_MSOP8_0256P_167_TPS20TPS2068DGNRMSOP8_0256P_167
    U6NC7SZ14P5X_2_DBV5_SN74AHC1G04DBSN74AHC1G04DBVRDBV5
    U7OMAP-L138_0_BGA361_W19_P8_16X16OMAPL138ZWTBGA361_W19_P8_16X16
    U8FT232RQ_1_QFN32_9V_FT232RQFT232RQQFN32_9V
    U9CDCM61001RHBT_0_QFN32_CDCM61001CDCM61001RHBTQFN32
    U11SN74LVC1G11_DBV_SN74LVC1G11DBVRSN74LVC1G11DBVRDBV
    U12SN74LVC2T45DCUT_DCU_SN74LVC2T45SN74LVC2T45DCUDCU
    U13THS8135PHP_8_LQFP48_THS8135PFPTHS8135PFPLQFP48
    U14OCT_DS_BUSTRASCEIVER_0_SOP-DGG4SN74AVC16T245DGGRSOP-DGG48
    U15SN74LVC2T45DCUT_DCU_SN74LVC2T45SN74LVC2T45DCUDCU
    U16TXS0102DCUR_DCU_TXS0102DCURTXS0102DCURDCU
    U17MT47H64M16HR_1_BGA84_R9_P8_K4TK4T1G164QF-BCF8BGA84_R9_P8
    U18K9F1208R0C_9_BGA-63_MT29F4G16ABMT29F4G16ABADAH4BGA-63
    U21TVP5146M2_1_PQFP80_25V_TVP5147MTVP5147M1PFPPQFP80_25V
    U22TLV320AIC3106_5_QFN48_25V_TLV32TLV320AIC3106IRGZQFN48_25V
    U23LAN8700_SMALL_0_QFN32_LAN8710A-LAN8710A-EZKQFN32
    U24SN74LVC2T45DCUT_DCU_SN74LVC2T45SN74LVC2T45DCUDCU
    U25TXS0102DCUR_DCU_TXS0102DCURTXS0102DCURDCU
    U26AES850_0_LGA23_E5_P1_6P8X6P8_AEAES850LGA23_E5_P1_6P8X6P8
    U2774LVC1G126DBV_0_DBV5_74LVC1G12674LVC1G126DBVDBV5
    U28SN74AVC1T45DBV_DBV_SN74AVC1T45DSN74AVC1T45DBVDBV
    Y1CRYSTAL25MHZABM3_SM_OSC_ABM3_2525MHzSM_OSC_ABM3
    Y2CM200S_4FX135A-327XTAL2_FX135
    Y3ASEM4-24_0.000MHZ-LR_XTAL4_74X8ASE-24.000MHZ-LCXTAL4_74X83LS_98X126SMD
    Y4CRYSTAL_5_CSM-7_ECS-143-20-5P-TECS-143-20-5P-TRCSM-7
    Y5OSC4/SM_0_OSC4_90-100SMD_130X20CB3LV-3I-24M5760OSC4_90-100SMD_130X200
    Y6CRYSTAL25MHZABM3_SM_OSC_ABM3_2525MHzSM_OSC_ABM3
    游客,如果您要查看本帖隐藏内容请回复
    重要提示:PCB作品文件展下载说明
    昨天 08:36
  • 签到天数: 182 天
    终身成就奖社区居民特殊贡献奖优秀斑竹奖
    发表于 2016-10-4 10:01:20 | 显示全部楼层
    社区居民忠实会员社区劳模原创达人最爱沙发终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2016-10-5 06:36:44 | 显示全部楼层
    发表于 2016-10-5 08:51:25 | 显示全部楼层
    发表于 2016-10-5 12:22:57 | 显示全部楼层
    看看图,谢谢楼主分享
    发表于 2016-10-5 21:21:30 | 显示全部楼层
    社区居民忠实会员社区劳模原创达人终身成就奖
    发表于 2016-10-6 03:29:38 | 显示全部楼层
    社区居民终身成就奖优秀斑竹奖宣传大使奖社区劳模最爱沙发社区明星灌水天才奖幽默大师奖贴图大师奖新人进步奖忠实会员
    发表于 2016-10-7 09:08:44 | 显示全部楼层
    昨天 09:57
  • 签到天数: 231 天
    发表于 2016-10-8 06:45:55 | 显示全部楼层
    发表于 2016-10-10 19:16:19 | 显示全部楼层
