重要提示:PCB作品文件展下载说明
MSD6A901 这个资料,目前网上一点都找不到。
Name | PCB Decal | Part Type | +3V3_NORMAL | TP-1MMB | TP-1MM | AGND | TP-1MMB | TP-1MM | CE3 | C-6.3X5.4-2 | C-6.3X5.4-2 | CE4 | C-6.3X5.4-2 | C-6.3X5.4-2 | CE5 | ECAP-8N | ECAP-8 | CE6 | C-6.3X5.4-2 | C-6.3X5.4-2 | CE8 | ECAP-8N | ECAP-8 | CE13 | C-6.3X5.4-2 | C-6.3X5.4-2 | CE14 | C-6.3X5.4-2 | C-6.3X5.4-2 | CE15 | C1206 | C1206 | CE16 | C-6.3X5.4-2 | C-6.3X5.4-2 | CE18 | C1206 | C1206 | CE19 | C-6.3X5.4-2 | C-6.3X5.4-2 | CE20 | ECAP-8N | ECAP-8 | CE21 | C-6.3X5.4-2 | C-6.3X5.4-2 | CE22 | C-6.3X5.4-2 | C-6.3X5.4-2 | CE23 | ECAP-8N | ECAP-8 | CE24 | ECAP-8N | ECAP-8 | CE25 | ECAP-8N | ECAP-8 | CE26 | C1206 | C1206 | CE27 | C1206 | C1206 | CE28 | ECAP-8N | ECAP-8 | CE29 | C-6.3X5.4-2 | C-6.3X5.4-2 | CE30 | C-6.3X5.4-2 | C-6.3X5.4-2 | CE31 | C1206 | C1206 | CE32 | C1206 | C1206 | CE903 | C-6.3X5.4-2 | C-6.3X5.4-2 | CL1 | C0805 | C0805 | CL2 | C0805 | C0805 | CL3 | C0805 | C0805 | CL4 | C0402 | C0402 | CL5 | C0402 | C0402 | CL6 | C0402 | C0402 | CL7 | C0402 | C0402 | CL8 | C0402 | C0402 | CL9 | C0402 | C0402 | CL10 | C0402 | C0402 | CL11 | C0402 | C0402 | CL12 | C0805 | C0805 | CL13 | C0402 | C0402 | CL14 | C0402 | C0402 | CN1 | CON25-J25-14A | CON25-J25-14A | CN2 | PH-12AWB-SMD | PH-12AWB-SMD | CN4 | USB\A1 | USB\A1 | CN5 | USB\A1 | USB\A1 | CN6 | USB-9P-USB3A9S | USB-9P-USB3A9S | CN7 | XH-5AB-SMD | XH-5AB-SMD | CN8 | WTB-4031A0-023N | WTB-4031A0-023N | CN9 | WHA-3031K-023NJ3 | WHA-3031K-023NJ3 | CN10 | EARPHONE-X-04(B) | EARPHONE-X-04(B) | CN11 | PCMCIA1 | PCMCIA1 | CN12 | WHA-3031K-023NJ3 | WHA-3031K-023NJ3 | CON1 | HDMI-19\W | HDMI-19\W | CON2 | HDMI-19\W | HDMI-19\W | CON3 | HDMI-19\W | HDMI-19\W | CON4 | CON8X2-J20-16B | CON8X2-J20-16B | CON5 | NETWORK_JACK | NETWORK_JACK | CON6 | VGA-PIN15 | VGA-PIN15 | CON7 | CON20X2-J20-46B | CON20X2-J20-46B | CON43 | TUNER-COVER-A | TUNER-COVER-A | CON1000 | SD_CARD_TECONN | SD_CARD_TECONN | D2 | R0805 | R0805 | D3 | R0805 | R0805 | D9 | D4148 | D4148 | D10 | D4148 | D4148 | D27 | D0402 | D0402 | D28 | D0402 | D0402 | D63 | D4148 | D4148 | D64 | D4148 | D4148 | D65 | D4148 | D4148 | D66 | D4148 | D4148 | D100 | SOT-23 | SOT-23 | D101 | SOT-23 | SOT-23 | D102 | R0603 | R0603 | D103 | R0603 | R0603 | DD700 | SOT-23 | SOT-23 | EEPROM-WP | TP-1MMB | TP-1MM | H1 | HOLE4-7 | HOLE4-7 | H2 | HOLE4-7 | HOLE4-7 | H3 | HOLE4-7 | HOLE4-7 | H4 | HOLE4-7 | HOLE4-7 | H5 | TPAD | TPAD | H6 | TPAD | TPAD | H7 | TPAD | TPAD | H8 | TPAD | TPAD | H13 | TPAD | TPAD | H14 | TPAD | TPAD | H15 | TPAD | TPAD | H16 | TPAD | TPAD | H18 | HOLE4-7 | HOLE4-7 | H19 | HOLE4-7 | HOLE4-7 | L1 | L-X-8-4-2.5 | L-X-8-4-2.5 | L2 | L-5.8X5.2 | L-5.8X5.2 | L3 | LX_8X8 | LX_8X8 | L4 | LX_8X8 | LX_8X8 | L13 | L1206 | L1206 | L14 | L1206 | L1206 | L16 | L0603 | L0603 | L19 | L0805 | L0805 | L20 | L1206 | L1206 | L23 | R0603 | R0603 | L28 | L0603 | L0603 | L31 | L0603 | L0603 | L32 | L0603 | L0603 | L33 | L0603 | L0603 | L34 | L0603 | L0603 | L35 | L0603 | L0603 | L36 | L0603 | L0603 | L100 | L0603 | L0603 | L106 | L0805 | L0805 | L107 | L0805 | L0805 | L113 | L0603 | L0603 | L117 | L0603 | L0603 | L700 | L0603 | L0603 | LA1 | L-POWER-1 | L-POWER-1 | LA2 | L-POWER-1 | L-POWER-1 | LA3 | L-POWER-1 | L-POWER-1 | LA4 | L-POWER-1 | L-POWER-1 | LL1 | R0603 | R0603 | LT1 | L0603 | L0603 | LT2 | L1206 | L1206 | LT3 | L1206 | L1206 | LT4 | L1206 | L1206 | MR37 | R0402 | R0402 | MR38 | R0402 | R0402 | MR39 | R0402 | R0402 | MR40 | R0402 | R0402 | MR41 | R0402 | R0402 | MR42 | R0402 | R0402 | MR43 | R0402 | R0402 | MR44 | R0402 | R0402 | MR300 | R0402 | R0402 | MR301 | R0402 | R0402 | MR302 | R0402 | R0402 | MR303 | R0402 | R0402 | MR304 | R0402 | R0402 | MR305 | R0402 | R0402 | MR306 | R0402 | R0402 | MR307 | R0402 | R0402 | MR308 | R0402 | R0402 | MR309 | R0402 | R0402 | MR310 | R0402 | R0402 | MR311 | R0402 | R0402 | MR312 | R0402 | R0402 | MR313 | R0402 | R0402 | MR314 | R0402 | R0402 | MR315 | R0402 | R0402 | MR316 | R0402 | R0402 | MR317 | R0402 | R0402 | MR318 | R0402 | R0402 | MR319 | R0402 | R0402 | MR320 | R0402 | R0402 | MR321 | R0402 | R0402 | MR322 | R0402 | R0402 | MR323 | R0402 | R0402 | MR324 | R0402 | R0402 | MR325 | R0402 | R0402 | MR326 | R0402 | R0402 | MR327 | R0402 | R0402 | MR330 | R0402 | R0402 | MR331 | R0402 | R0402 | MR332 | R0402 | R0402 | MR333 | R0402 | R0402 | MR334 | R0402 | R0402 | MR335 | R0402 | R0402 | MR336 | R0402 | R0402 | MR337 | R0402 | R0402 | MR338 | R0402 | R0402 | MR339 | R0402 | R0402 | MR340 | R0402 | R0402 | MR341 | R0402 | R0402 | MR342 | R0402 | R0402 | MR343 | R0402 | R0402 | MR344 | R0402 | R0402 | MR345 | R0402 | R0402 | MU300 | IC-96P-TFBGA-DDR3 | IC-96P-TFBGA-DDR3 | MU301 | IC-96P-TFBGA-DDR3 | IC-96P-TFBGA-DDR3 | MU302 | IC-96P-TFBGA-DDR3 | IC-96P-TFBGA-DDR3 | MU303 | IC-96P-TFBGA-DDR3 | IC-96P-TFBGA-DDR3 | M_SCL | TP-1MMB | TP-1MM | M_SDA | TP-1MMB | TP-1MM | P1 | EP4\3-5 | EP4\3-5 | P2 | EP4\3-5 | EP4\3-5 | P6 | AV-1X3-7D | AV-1X3-7D | P8 | EP4\3-5 | EP4\3-5 | P13 | CON5/2.0 | CON5/2.0 | P14 | CON5/2.0 | CON5/2.0 | P15 | CON6/2.0 | CON6/2.0 | P18 | EP4\3-5 | EP4\3-5 | Q704 | SOT-223A | SOT-23M | Q705 | SOT-223A | SOT-23M | Q902 | SOT-23 | SOT-23 | Q903 | SOT-23 | SOT-23 | Q904 | SOT-23 | SOT-23 | QA701 | SOT23-5 | SOT23-5 | S1 | HEATSINK40.2X41.5 | HEATSINK40.2X41.5 | TC1 | C0402 | C0402 | TC2 | C0402 | C0402 | TP13 | TP-1MM | TP-1MM | TP16 | TP-1MM | TP-1MM | TP17 | TP-1MM | TP-1MM | TP18 | TP-1MM | TP-1MM | TP19 | TP-1MM | TP-1MM | TP20 | TP-1MM | TP-1MM | TP21 | TP-1MM | TP-1MM | TP22 | TP-1MM | TP-1MM | TP23 | TP-1MM | TP-1MM | TP24 | TP-1MM | TP-1MM | TP25 | TP-1MM | TP-1MM | TR1 | R0402 | R0402 | TR2 | R0402 | R0402 | U1 | SOP8-225-50 | SOP8-225-50 | U2 | SOT-223 | SOT-223 | U3 | SOT-223 | SOT-223 | U4 | SOT23-5 | SOT23-5 | U5 | SOT-223 | SOT-223 | U6 | SOT23-8 | SOT23-8 | U7 | SOT23-8 | SOT23-8 | U8 | HLQF48R | HLQF48R | U9 | PE42750 | PE42750 | U10 | SOP8-225-50 | SOP8-225-50 | U12 | LQFP48 | LQFP48 | U15 | SOP8-225-50 | SOP8-225-50 | U16 | PFB48 | PFB48 | U18 | SOT-223 | SOT-223 | U20 | IC-169P-BGA-SDIN2C2 | IC-169P-BGA-SDIN2C2 | U21 | IC-48P-TSOP-12X20MM | IC-48P-TSOP-12X20MM | U22 | TSQFP48 | TSQFP48 | U23 | SOT-223 | SOT-223 | U100 | IC-953P-LFBGA | IC-953P-LFBGA | U101 | SOP8-225-50 | SOP8-225-50 | U103 | SOP8-255-50 | SOP8-255-50 | U651 | TRANSFORMER-16P | TRANSFORMER-16P | X2 | CRYS/SMD/49SM | CRYS/SMD/49SM | Y2 | CRYS/SMD/49SM | CRYS/SMD/49SM | Y100 | CRYS/SMD/49SM | CRYS/SMD/49SM | Y102 | CRYS/SMD/49SM | CRYS/SMD/49SM |
重要提示:PCB作品文件展下载说明
