[IC] TL-WR702N Datasheet
查看2026 | 回复1 | 2016-10-28 09:55:19 | 显示全部楼层 |阅读模式
150Mbps Wireless N Nano Router
Feature
- Compatible with IEEE 802.11n/g/b
- Wireless speed up to 150Mbps
- Compact and portable, small enough to take on the road
- Powered through a micro USB port by an external power adapter or USB connection to a computer
- Supports AP, Router, Client, Bridge and Repeater operation modes
- Supports WEP, WPA/WPA2, WPA-PSK/WPA2-PSK encryptions
TL-WR702N Datasheet.pdf (7.81 MB, 下载次数: 0)
longxuekai | 2016-10-29 00:18:29 | 显示全部楼层
