AutoChips 是MTK 在大陆的主打车载方面的子公司。
Name | Value | PCB Decal | Part Type | +5V | | TP_1.5MM | TEST | ACC1 | NC | TEST | TEST | AMP1 | NC | TEST | TEST | ANT-GND | | TP_1.5MM | TEST | ANT1 | GPS.ANT | ANT_RF1 | GPS_ANT | ANT3 | | RADIO_ANT_4PIN | RADIO_ANT_4PIN | ANT4 | | TP_1.5MM | TEST | ANT5 | WIFI.ANT | ANT_RF1 | GPS_ANT | ANT6 | | RADIO_ANT_5PIN | RADIO_ANT_5PIN | AP_GND | | TP_1.5MM | TEST | AP_RX | | TP_1.5MM | TEST | AP_TX | | TP_1.5MM | TEST | B+ | NC | TEST | TEST | BACK1 | NC | TEST | TEST | BATT_IN | NC | TEST | TEST | BRAKE1 | NC | TEST | TEST | CAMERA_CVBS | NC | TEST | TEST | CANRX | | TP_1.5MM | TEST | CANTX | | TP_1.5MM | TEST | CCD-V | | TP_1.5MM | TEST | CON1 | FFC60PIN 0.5mm 180 | CON60P_0.5MMA | CON-60P-LVDS | CON2 | FFC40PIN/0.5mm/180 | CON-40P-0.5L | CONOWATFT_40P0.5+2_180 | CON3 | PH-4PW | HV_CON | HVP | CON4 | | OWA_RADIO_GND | OWA_RADIO_GND | CON5 | FFC6PIN/0.5mm/180 | FPC6P_0.5P | CON_6P0.5+2_180 | CON6 | FFC10PIN/0.5mm/180 | FFC10P_0.5_P | CON_10P0.5+2_180 | CON7 | CON_16PIN_2X8_2.0MM | CON_16PIN_2X8_2.0MM | CON_16PIN_2X8_2.0MM | CON11 | | RADIO_GND_4PINA | OWA_RADIO_GND | CON13 | | ISO-22P | 22P-ISO | CON14 | CON_18PIN_2X9_2.0MM | CON_18PIN_2X9_2.0MM | CON_18PIN_2X9_2.0MM | CON15 | PH-4PW | HV_CON | HVP | CON16 | CON_20PIN_2X10_2.0MM | CON_20PIN_2X10_2.0MM | CON_20PIN_2X10_2.0MM | CON19 | FFC12PIN/0.5mm/180 | FFC10P_0.5_P | CON_10P0.5+2_180 | CON20 | FFC10PIN/0.5mm/180 | FFC10P_0.5_P | CON_10P0.5+2_180 | CON22 | FFC6PIN/0.5mm/180 | FPC6P_0.5P | CON_6P0.5+2_180 | D1 | IN4001 | SOD106 | IN4001(DIP) | D2 | IN4001 | SOD106 | IN4001(DIP) | D3 | NC | SOD106 | IN4001(DIP) | D4 | IN4001 | SOD106 | IN4001(DIP) | D5 | LED | 0603D | LED | D6 | NC | 0402RS | DIODE_SMD_0603_ESD_PROTECTION | D7 | NC?ESD3Z3V£? | D0603 | DIODE_0 | D8 | UMD0521B | 0402RS | DIODE_0 | D9 | UMD0521B | 0402RS | DIODE_0 | D10 | UMD0521B | 0402RS | DIODE_0 | D11 | UMD0521B | 0402RS | DIODE_0 | D12 | IN4148 | SOD-323 | IN4001(DIP) | D13 | IN4148 | SOD-323 | IN4001(DIP) | D14 | IN4148 | SOD-323 | IN4001(DIP) | D15 | IN4148 | SOD-323 | IN4001(DIP) | D16 | BAV99 | SOT-23 | BA99 | D17 | IN4148 | SOD-323 | IN4001(DIP) | D18 | NC | SOD-323 | IN4001(DIP) | D19 | IN4148 | SOD-323 | IN4001(DIP) | D20 | IN4148 | SOD-323 | IN4001(DIP) | D21 | IN4148 | SOD-323 | IN4001(DIP) | D22 | BAV99 | SOT-23 | BA99 | D23 | IN4148 | SOD-323 | IN4001(DIP) | D25 | IN4148 | SOD-323 | IN4001(DIP) | D26 | IN4148 | SOD-323 | IN4001(DIP) | D27 | NC | SOD-323 | IN4001(DIP) | D28 | IN4148 | SOD-323 | IN4001(DIP) | D31 | IN4148 | SOD-323 | IN4001(DIP) | D37 | S3G | S3G | D | D39 | BAV99 | SOT-23 | BA99 | D40 | IN5822 | DO214AC | IN5819 | D41 | IN5822 | DO214AC | IN5819 | D42 | B540C | DIO/DO-214AB | DIODE/DO-214 | D45 | IN4148 | SOD-323 | IN4001(DIP) | DITH | | TP_1.5MM | TEST | DVRD+ | | TP_1.2MM | TEST | DVRD- | | TP_1.2MM | TEST | ELINKD+ | | TP_1.5MM | TEST | ELINKD- | | TP_1.5MM | TEST | ESD104 | ESD0603 | 0603R | PGB1010603 | F4 | 1A | FUSE-1206 | FUSE | F8 | 0.5A | FUSE-1206 | FUSE | FL+1 | NC | TEST | TEST | FL-1 | NC | TEST | TEST | FR+1 | NC | TEST | TEST | FR-1 | NC | TEST | TEST | GND1 | NC | TEST | TEST | GND3 | | TP_1.5MM | TEST | GND4 | | TP_1.5MM | TEST | GND5 | | TP_1.5MM | TEST | GND6 | | TP_1.5MM | TEST | GND7 | | TP_1.5MM | TEST | GND11 | | TP_1.5MM | TEST | GND12 | | TP_1.5MM | TEST | GND13 | | TP_1.5MM | TEST | GND14 | | TP_1.5MM | TEST | GND18 | | TP_1.5MM | TEST | GND19 | | TP_1.5MM | TEST | GND20 | | TP_1.5MM | TEST | GND21 | | TP_1.5MM | TEST | GND22 | | TP_1.5MM | TEST | GND23 | | TP_1.5MM | TEST | GPSANT | | TP_1.5MM | TEST | GPSGND | | TP_1.5MM | TEST | IC1 | MP1584 | PSOP8 | MP1584 | IC2 | 24C02 | SO8-OPT | AT24C02 | IC603 | TDA7388 | TDA7388A | TDA7384 | ILL1 | NC | TEST | TEST | J1 | 4PIN/NC | SIP-4P1 | CON4 | KEY+/ | | TP_1.5MM | TEST | KEY1/ | | TP_1.5MM | TEST | KEY2/ | | TP_1.5MM | TEST | L/R | | TP_1.5MM | TEST | L1 | 100M/100R | 0603R | INDUCTOR_0 | L2 | 2.2UH/3A | MJC0402 | INDUCTOR_4 | L3 | 2.2UH | PANVGG3X3-1 | INDUCTOR_4 | L4 | 100M/100R | 0603R | INDUCTOR_0 | L5 | LQM21PN4R7NGR | 0805R | INDUCTOR_2 | L6 | 0 | 0402RS | INDUCTOR | L7 | 47nh | 0402RS | INDUCTOR_0 | L8 | 2.7PF | 0402RS | FERRITE_BEAD_SMD_0402 | L9 | 6.8nH | 0402RS | FERRITE_BEAD_SMD_0402 | L10 | 0 | 0402RS | INDUCTOR | L11 | 0 | 0402RS | INDUCTOR | L12 | 6.8nH | 0402RS | FERRITE_BEAD_SMD_0402 | L13 | 47nh | 0402RS | INDUCTOR_0 | L14 | 100M/100R | 0603R | INDUCTOR | L15 | 1.8uH | L0603 | INDUCTOR/CHIP | L16 | FB | L0603 | L-1 | L17 | 1.8uH | L0603 | INDUCTOR/CHIP | L18 | 10uH | L0603 | L-1 | L19 | 220nH | L0603 | L-1 | L20 | PB1608 | L0603 | INDUCTOR/CHIP | L21 | PB1608 | L0603 | INDUCTOR/CHIP | L22 | FB3216 | L1206 | INDUCTOR/CHIP | L23 | NC | L7X5 | IND | L24 | 1.5uH | MMD-04BZ-4440-2.0MM | IND | L25 | PB1608 | L0603 | INDUCTOR/CHIP | L26 | 22uH | L7X5 | IND | L28 | 22uH | L7X5 | IND | L30 | FB3216 | L1206 | INDUCTOR/CHIP | L31 | FB3216 | L1206 | INDUCTOR/CHIP | L34 | 1.5uH | MMD-04BZ-4440-2.0MM | IND | L38 | 380uH | L_13_26 | (LGJ)IND-CDRH74 | L48 | 15uH/3A | SHC0605 | IND | L50 | 1.5uH | MMD-04BZ-4440-2.0MM | IND | LCD+10V | | TP_1.5MM | TEST | LCD3V3 | | TP_1.5MM | TEST | LCDGND | | TP_1.5MM | TEST | LCDGND1 | | TP_1.5MM | TEST | LED+ | | TP_1.5MM | TEST | LED- | | TP_1.5MM | TEST | LS1 | | LS_OWA | LS_PST | LS2 | | LS_OWA | LS_PST | LS3 | | LS_OWA | LS_PST | LS4 | | LS_OWA | LS_PST | MARK1 | MARK | PST_MARK | MARK | MARK2 | MARK | PST_MARK | MARK | MARK3 | MARK | PST_MARK | MARK | MARK4 | MARK | PST_MARK | MARK | MIC+// | | TP_1.5MM | TEST | MIC-// | | TP_1.5MM | TEST | Q1 | S8550 | SOT-23 | PNP | Q2 | S8050 | SOT-23 | NPN | Q3 | KRC103S | SOT23 | 8050C | Q4 | KRC103S | SOT23 | 8050C | Q5 | NC | SOT23FET | _N_DGS_5 | Q6 | KRC103S | SOT23 | 8050C | Q8 | S8550 | SOT-23 | PNP | Q9 | S8550 | SOT-23 | PNP | Q10 | S8050 | SOT-23 | NPN | Q11 | AO3401 | SOT-23 | SI2323 | Q12 | S8050 | SOT-23 | NPN | Q13 | S8050 | SOT-23 | NPN | Q14 | S8050 | SOT-23 | NPN | Q15 | AO3401 | SOT-23 | SI2323 | Q19 | S8050 | SOT-23 | NPN | Q20 | S8050 | SOT-23 | NPN | Q21 | AO3401 | SOT-23 | SI2323 | Q28 | 9018 | SOT-23 | NPN | Q29 | S8050 | SOT-23 | NPN | Q30 | NC | SOT-23 | NPN | Q31 | KTC437 | TO-89 | NPN | Q34 | 9018 | SOT-23 | NPN | Q36 | 2SK3018 | Q/SOT-23/SMD-ZR | MOSFET_N | Q38 | S8550 | SOT-23 | PNP | Q43 | S8050 | SOT-23 | NPN | Q44 | S8550 | SOT-23 | PNP | Q48 | S8550 | SOT-23 | PNP | Q49 | S8550 | SOT-23 | PNP | Q51 | 2SK3018 | Q/SOT-23/SMD-ZR | MOSFET_N | Q52 | 2SK3018 | Q/SOT-23/SMD-ZR | MOSFET_N | Q55 | AO3401 | SOT-23 | SI2323 | Q56 | S8050 | SOT-23 | NPN | Q57 | S8050 | SOT-23 | NPN | RST | | TP_1.5MM | TEST | SAW1 | HDF1588E-B2 | SAW5PIN | GPS-FILTER_2 | SELB | | TP_1.5MM | TEST | STBYB | | TP_1.5MM | TEST | SW1 | | TP_1.5MM | TEST | SW2 | | TP_1.5MM | TEST | SW3 | NC | TEST | TEST | SW4 | NC | TEST | TEST | SYS5V/ | | TP_1.5MM | TEST | T1 | | ANT_F | ANT_F | TP14 | TEST POINT SMD0.6 | TPBAK | TEST_POINT_SMD0.6 | TP15 | TEST POINT SMD0.6 | TPBAK | TEST_POINT_SMD0.6 | TP17 | TEST POINT SMD0.6 | TPBAK | TEST_POINT_SMD0.6 | TP26 | TEST POINT SMD0.6 | TPBAK | TEST_POINT_SMD0.6 | TP27 | TEST POINT SMD0.6 | TPBAK | TEST_POINT_SMD0.6 | TP29 | TEST POINT SMD0.6 | TPBAK | TEST_POINT_SMD0.6 | TP30 | TEST POINT SMD0.6 | TPBAK | TEST_POINT_SMD0.6 | TP_3V3 | | TP_1.5MM | TEST | TP_INT | | TP_1.5MM | TEST | TP_RST | | TP_1.5MM | TEST | TP_SCL | | TP_1.5MM | TEST | TP_SDA | | TP_1.5MM | TEST | U/D | | TP_1.5MM | TEST | U1 | EML3179-00FH08NRR | TDFN8X3 | L7808_10 | U2 | HK-02 | SO8 | R_9 | U3 | SI4730 | SSOP24_0.635MM | SI4730_SSOP24 | U4 | EMP8739A-33VF05GRR | TDFN6 | L7808_7 | U5 | EMP8739A-12VF05GRR | TDFN6 | L7808_7 | U6 | TDA7786 | TDA7786 | TDA7786 | U7 | AC8217 | AC8317 | AC8317/HSFBGA614/P0.8/B0.4/23X23 | U8 | YD1521/1522 | ESOP-16 | YD1521/1522 | U9 | IPOD-2.0C | IPOD_CP2.0C | IPOD-2.0C | U10 | EMP8042-33VF05NRR | TSOT23-5 | L7808_9 | U11 | SSDCI3128AF/NC | TDFN8 | L7808_2_2 | U12 | SGM809_2.93V | SOT-23 | IMP809 | U13 | EMP8739A-18VF05GRR | TDFN6 | L7808_7 | U14 | STM8AH | QFP80-1414-0.65 | MB1013 | U15 | K4B4G1646Q-HYK0 | BGA96 | K4B4G1646Q-HYK0 | U16 | THGBMBG6D1KBAIL | INAND | THGBMBG6D1KBAIL | U17 | K4B4G1646Q-HYK0 | BGA96 | K4B4G1646Q-HYK0 | U18 | SGM809_2.93V | SOT23RST | AAT3520_0 | U19 | EML3023AB00VF05NRR | TSOT23-5 | L7808_11 | U20 | 26MHz/0.5ppm/3.3V | TCXO3225 | TCXO_2 | U21 | MT3336 | MQFN48/P0.4/6X6 | MT3301-140_SMD_PBGA-140_1 | U22 | MXDLN16G | MAX2659 | NJG1107HB3_2 | U23 | EMP8739A-33VF05GRR | TDFN6 | L7808_7 | U24 | MT6622 | QFN40/P0.4/5X5 | MT6611_SMD_WLCSP-61_1 | U25 | LFB212G45CF7D291 | BPF_6611 | BALUN_0 | U26 | EMP8739A-33VF05GRR | TDFN6 | L7808_7 | U27 | EMP8739A-33VF05GRR | TDFN6 | L7808_7 | U28 | NC | SOT252A | 78XX | U30 | CSC1307 | TSSOP20 | L7808_15 | U31 | MLK-033A | RL_UM02BS | WIFI(UM02BS) | U33 | NJM4558 | SO8-OPT | NJM4558 | U35 | AU6268 | SSOP28 | AU6268 | U38 | MP1540 | SOT23-(5) | MP1504 | U40 | BIT3252A | SO8-OPT | BIT3252 | U43 | EMP8739A-33VF05GRR | TDFN6 | L7808_7 | U45 | BL1117-3.3V | SOT223 | LD1117 | USBD+/ | | TP_1.5MM | TEST | USBD-/ | | TP_1.5MM | TEST | VCOM | | TP_1.5MM | TEST | VGH | | TP_1.5MM | TEST | VGL | | TP_1.5MM | TEST | VOL+/ | | TP_1.5MM | TEST | VOL+/1 | | TP_1.5MM | TEST | XT1 | 32.768K | TL146 | CRYSTAL_1 | XT2 | 32.768K | TL146 | CRYSTAL_1 | Y1 | 27MHZ | XT3225 | CRYSTAL_1_3 | Y2 | 8MHz | CRY/HC-49USM | XTAL | Y3 | 32.768K | TL146 | CRYSTAL_1 | YT3 | 12MHZ | XT3225 | CRYSTAL_1_3 | Z1 | 5.6V | ZD_1206 | ZD_1206 | Z2 | 5.6V | ZD_1206 | ZD_1206 | Z4 | 10V | ZD_1206 | ZD_1206 | Z5 | 8.2V | ZD_1206 | ZD_1206 | Z8 | NC | ZD_1206 | ZD_1206 | Z9 | 5.6V | ZD_1206 | ZD_1206 |
评分
查看全部评分
