继续发布高大上。 INTEL 主板
REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | A2 | SOP127X780-8 | MX25L6406EM2I-12G | SOP127X780-8 | BZ1 | BUZ_SAT-1205 | BUZZER | BUZ_SAT-1205 | D1 | SOT-23 | BAT54C | SOT-23 | D2 | DO-214AC | EC31QS04_3A/40V | DO-214AC | D3 | SOT-23 | BAT54A | SOT-23 | D5 | SOT-23 | BAT54S | SOT-23 | D6 | SOT-23 | BAT54S | SOT-23 | D7 | SOT-23 | BAT54S | SOT-23 | D8 | SOT-23 | BAT54S | SOT-23 | D9 | SOT-23 | BAT54S | SOT-23 | D10 | SOT-23 | BAT54A | SOT-23 | D11 | SOT-23 | BAT54C | SOT-23 | D12 | DIOMLL34 | 1N4148/X | DIOMLL34 | D13 | SOT-23 | BAT54A/X | SOT-23 | D14 | SOT-23 | BAT54A | SOT-23 | D15 | SOT-23 | BAT54A | SOT-23 | D16 | SOT-23 | BAT54C | SOT-23 | D17 | SOT-23 | BAT54C | SOT-23 | D18 | SOT-23 | BAT54C | SOT-23 | D19 | SOT-23 | BAT54C | SOT-23 | D20 | SOT-23 | BAT54C/X | SOT-23 | D21 | DO-214AC | EC10QS04_1A/40V | DO-214AC | D22 | SOT-23 | BAT54C | SOT-23 | D23 | SOT-23 | BAT54A | SOT-23 | D24 | SOT-23 | BAT54A | SOT-23 | D25 | SOT-23 | BAT54A | SOT-23 | D26 | SOT-23 | BAT54A/X | SOT-23 | D27 | SOT-23 | BAT54A/X | SOT-23 | D28 | SOT-23 | BAT54C | SOT-23 | F1 | FUSE1812 | FUSE_1812-1.1A | FUSE1812 | F2 | FUSE1812 | FUSE_1812-1.1A/X | FUSE1812 | F3 | FUSE1812 | FUSE_1812-1.1A | FUSE1812 | F4 | FUSE1812 | FUSE_1812-1.1A | FUSE1812 | FB1 | L0603 | 600_1A | L0603 | FB2 | L0603 | 600_1A | L0603 | FB3 | L0805 | 120_300mA | L0805 | FB4 | L0805 | 120_300mA | L0805 | FB5 | L0805 | 120_300mA | L0805 | FB6 | L0805 | 120_300mA | L0805 | FB7 | L0805 | 120_3A | L0805 | FB8 | L0603 | 47_200mA | L0603 | FB9 | L0603 | 47_200mA | L0603 | FB10 | L0603 | 47_200mA | L0603 | FB11 | L0603 | 47_200mA | L0603 | FB12 | L0603 | 47_200mA | L0603 | FB13 | L0603 | 47_200mA | L0603 | FB14 | L0805 | 120_3A/X | L0805 | FB15 | L0603 | 120Z/100M/X | L0603 | FB16 | L0603 | 120Z/100M/X | L0603 | FB17 | L0603 | 120Z/100M/X | L0603 | FB18 | L0603 | 120Z/100M/X | L0603 | FB19 | L0805 | 120_3A | L0805 | FB20 | L0805 | 120_300mA | L0805 | FB21 | L0805 | 120_300mA | L0805 | FB22 | L0805 | 120_3A | L0805 | FB23 | L0805 | 120_3A | L0805 | FB24 | L0805 | 120_3A | L0805 | FB25 | L0603 | 120_200mA | L0603 | FB26 | L0603 | 120_200mA | L0603 | FB27 | L0603 | 120_200mA | L0603 | FB28 | L0603 | 120_200mA | L0603 | FB29 | L0603 | 120_200mA | L0603 | FB30 | L0805 | 120_3A | L0805 | FB31 | L0603 | 300Z_500mA/X | L0603 | FB32 | L0805 | 120_3A | L0805 | FB33 | L0603 | 300Z_500mA/X | L0603 | FB34 | L0805 | 10UH | L0805 | FB35 | L0805 | 10UH | L0805 | FB36 | L0805 | 10UH | L0805 | FB37 | L0805 | 10UH | L0805 | FB38 | L0805 | 10UH | L0805 | FB39 | L0805 | 10UH | L0805 | FB40 | L0805 | 10UH | L0805 | FB41 | L0805 | 10UH/X | L0805 | FB42 | L0805 | 10UH/X | L0805 | FB43 | L0805 | 10UH/X | L0805 | FB44 | L0805 | 10UH/X | L0805 | FB45 | L0603 | 120_200mA | L0603 | J1 | SOP8L-SKT-SPI | ACA-SPI-004-K01 | SOP8L-SKT-SPI | J2 | CR2032_SMD | CR2032_SMD | CR2032_SMD | J3 | DDR3S-SODIMM-9_2MM | DDR3-SODIMM-STD/H9.2 | DDR3S-SODIMM-9_2MM | J4 | DF13-40 | DF13-40DP-1.25V | DF13-40 | J5 | PIN_SH-1X6-2MM | JST-1X6-2MM | PIN_SH-1X6-2MM | J6 | QH11121-CP1 | DVI-I_RA | QH11121-CP1 | J7 | WL2300_2X6_2MM | WL2300_2x6 | WL2300_2X6_2MM | J8 | PIN_SH-1X6-2MM | JST-1X6-2MM/X | PIN_SH-1X6-2MM | J9 | DB9-R-MALE-5_08MM | DSUB9-RA-5.08MM | DB9-R-MALE-5_08MM | J10 | DB9-R-MALE-5_08MM | DSUB9-RA-5.08MM | DB9-R-MALE-5_08MM | J11 | WL2300_2X5_2MM | WL2300-2X5 | WL2300_2X5_2MM | J12 | WL2300_2X5_2MM | WL2300-2X5 | WL2300_2X5_2MM | J13 | SATA_LD1807V-S55AD | SATA_CONN | SATA_LD1807V-S55AD | J14 | MINI_PCIE_4V | MINI_PCI-E_6.8M | MINI_PCIE_4V | J15 | SATA_LD1807V-S55AD | SATA_CONN | SATA_LD1807V-S55AD | J16 | MINI_PCIE_4V | MINI_PCI-E_6.8M | MINI_PCIE_4V | J17 | JST-1X2-P2MM | CONN_JST-1X2-2MM/X | JST-1X2-P2MM | J18 | SW_1102V | TACT_SW-1102V | SW_1102V | J19 | JST-1X2-P2MM | CONN_JST-1X2-2MM | JST-1X2-P2MM | J20 | USB3_0X1 | USB2/3_PORTX1 | USB3_0X1 | J21 | USBX1_UP_RA | USB_PORTX1_UP_RA | USBX1_UP_RA | J22 | USBX1_UP_RA | USB_PORTX1_UP_RA | USBX1_UP_RA | J23 | USBX1_UP_RA | USB_PORTX1_UP_RA | USBX1_UP_RA | J24 | PIN_SH-1X6-2MM | JST-1X6-2MM/X | PIN_SH-1X6-2MM | J25 | PIN_SH-1X6-2MM | JST-1X6-2MM | PIN_SH-1X6-2MM | J26 | PHONEJACK-01016BFR006 | RA/D6/6P-PINK | PHONEJACK-01016BFR006 | J27 | PHONEJACK-01016BFR006 | RA/D6/6P-GREEN | PHONEJACK-01016BFR006 | J28 | JST-1X2-P2MM | CONN_JST-1X2-2MM | JST-1X2-P2MM | J29 | JST-1X2-P2MM | CONN_JST-1X2-2MM | JST-1X2-P2MM | J30 | RJ45_TAB_UP_1X1 | RJ45_TAB_UP_1X1 | RJ45_TAB_UP_1X1 | J31 | RJ45_TAB_UP_1X1 | RJ45_TAB_UP_1X1 | RJ45_TAB_UP_1X1 | J32 | ID-394 | ID-394 | ID-394 | J33 | JST-1X9-P2MM | JST_1X9-P2MM | JST-1X9-P2MM | J34 | PIN_H-2X5-2_54MM | PINHDR_2X5-2_54MM | PIN_H-2X5-2_54MM | J35 | JST-1X2-P2MM | CONN_JST-1X2-2MM | JST-1X2-P2MM | J36 | JST-1X4-P2MM | JST-4X1-2MM | JST-1X4-P2MM | J37 | JST-1X2-P2MM | CONN_JST-1X2-2MM | JST-1X2-P2MM | J38 | JST-1X3-P2MM | CONN_JST-1X3-2MM | JST-1X3-P2MM | J39 | JST-1X2-P2MM | CONN_JST-1X2-2MM | JST-1X2-P2MM | J40 | JST-1X6-P1_25MM | JST_1x6-P1_25MM | JST-1X6-P1_25MM | J41 | JST-1X2-P2MM | CONN_JST-1X2-2MM | JST-1X2-P2MM | J42 | WL2300_2X5_2MM | WL2300-2X5 | WL2300_2X5_2MM | J43 | JST-1X4-P2MM | JST-4X1-2MM | JST-1X4-P2MM | J45 | DDR3R-SODIMM-9_2MM | DDR3-SODIMM-REV/H9.2 | DDR3R-SODIMM-9_2MM | J46 | JST-1X9-P2MM | JST_1X9-P2MM | JST-1X9-P2MM | J47 | JST-1X2-P2MM | CONN_JST-1X2-2MM | JST-1X2-P2MM | J48 | JST-1X2-P2MM | CONN_JST-1X2-2MM | JST-1X2-P2MM | J49 | JST-1X2-P2MM | CONN_JST-1X2-2MM | JST-1X2-P2MM | J50 | JST-1X9-P1_25MM | JST_1X9-P1_25MM | JST-1X9-P1_25MM | JL1 | JP_SMT1 | SHORT-SMT1 | JP_SMT1 | JL2 | JP_SMT1 | SHORT-SMT1 | JP_SMT1 | JL3 | JP_SMT1 | SHORT-SMT1 | JP_SMT1 | JP1 | PIN_H-1X3-2MM | PINHDR_1X3-2MM | PIN_H-1X3-2MM | JP2 | PIN_H-2X4-2MM | PIN_H-2X4-2MM | PIN_H-2X4-2MM | JP3 | PIN_H-1X3-2MM | PINHDR_1X3-2MM | PIN_H-1X3-2MM | JP4 | PIN_H-2X1-2MM | PIN_H-2X1-2MM | PIN_H-2X1-2MM | JP5 | PIN_H-2X1-2MM | PIN_H-2X1-2MM | PIN_H-2X1-2MM | JP6 | PIN_H-2X1-2MM | PIN_H-2X1-2MM | PIN_H-2X1-2MM | JP7 | PIN_H-1X3-2MM | PINHDR_1X3-2MM | PIN_H-1X3-2MM | JP8 | PIN_H-2X5-2MM | PIN_H-2X5-2MM | PIN_H-2X5-2MM | JP9 | PIN_H-2X3-2MM | PIN_H-2X3-2MM | PIN_H-2X3-2MM | JP10 | PIN_H-1X3-2MM | PINHDR_1X3-2MM | PIN_H-1X3-2MM | L1 | DLW2012B-900NP | DLW2012B-900NP | DLW2012B-900NP | L2 | DLW2012B-900NP | DLW2012B-900NP | DLW2012B-900NP | L3 | DLW2012B-900NP | DLW2012B-900NP | DLW2012B-900NP | L4 | DLW2012B-900NP | DLW2012B-900NP | DLW2012B-900NP | L5 | DLW2012B-900NP | DLW2012B-900NP | DLW2012B-900NP | L6 | WCM2012F2S-900 | IND_WCM2012F2S-900 | WCM2012F2S-900 | L7 | DLW2012B-900NP | DLW2012B-900NP | DLW2012B-900NP | L8 | WCM2012F2S-900 | IND_WCM2012F2S-900 | WCM2012F2S-900 | L9 | WCM2012F2S-900 | IND_WCM2012F2S-900 | WCM2012F2S-900 | L10 | WCM2012F2S-900 | IND_WCM2012F2S-900 | WCM2012F2S-900 | L11 | WCM2012F2S-900 | IND_WCM2012F2S-900/X | WCM2012F2S-900 | L12 | WCM2012F2S-900 | IND_WCM2012F2S-900 | WCM2012F2S-900 | MH1 | NPTH400_800-VIA | NPTH6_4 | NPTH400_800-VIA | MH2 | NPTH400_800-VIA | NPTH6_4 | NPTH400_800-VIA | MH3 | NPTH400_800-VIA | NPTH6_4 | NPTH400_800-VIA | MH4 | NPTH400_800-VIA | NPTH6_4 | NPTH400_800-VIA | MH5 | NPTH400_800-VIA | NPTH6_4 | NPTH400_800-VIA | MH6 | NPTH400_800-VIA | NPTH6_4 | NPTH400_800-VIA | MH7 | NPTH400_800-VIA | NPTH6_4 | NPTH400_800-VIA | MH8 | NPTH400_800-VIA | NPTH6_4 | NPTH400_800-VIA | MH9 | NPTH350_800 | NPTH6_4 | NPTH350_800 | MH10 | NPTH350_800 | NPTH6_4 | NPTH350_800 | MH11 | NPTH350_800 | NPTH6_4 | NPTH350_800 | MH12 | NPTH350_800 | NPTH6_4 | NPTH350_800 | MH13 | MC240D100 | MC240D100 | MC240D100 | MH14 | MC240D100 | MC240D100 | MC240D100 | PC225 | CAPT7343 | 470U | CAPT7343 | PC226 | C0402 | 0.1U | C0402 | PC227 | C0402 | 1000P | C0402 | PC228 | CAPT3528 | 100U | CAPT3528 | PC229 | CAPT7343 | 470U | CAPT7343 | PC230 | C0402 | 0.01U | C0402 | PD1 | DO-214AC | EC10QS04_1A/40V | DO-214AC | PD2 | DO-214AC | EC31QS04_3A/40V | DO-214AC | PD3 | DO-214AC | EC31QS04_3A/40V | DO-214AC | PD4 | DO-214AC | EC31QS04_3A/40V | DO-214AC | PD5 | DO-214AC | EC31QS04_3A/40V | DO-214AC | PD6 | DO-214AC | EC31QS04_3A/40V | DO-214AC | PD7 | DO-214AC | EC10QS04_1A/40V | DO-214AC | PD8 | SOT-23 | BAT54A | SOT-23 | PD9 | DIOMLL34 | 14V | DIOMLL34 | PD10 | DO-214AC | EC10QS04_1A/40V | DO-214AC | PD11 | SOT-23 | BAT54A | SOT-23 | PD12 | DO-214AC | EC10QS04_1A/40V | DO-214AC | PD13 | DO-214AC | EC31QS04_3A/40V | DO-214AC | PD14 | SOT-23 | BAT54A | SOT-23 | PD15 | DO-214AC | EC31QS04_3A/40V | DO-214AC | PD16 | DIOMLL34 | 14V | DIOMLL34 | PD17 | DO-214AC | EC31QS04_3A/40V | DO-214AC | PD18 | SOT-23 | BAT54A | SOT-23 | PD19 | DO-214AC | EC31QS04_3A/40V | DO-214AC | PD20 | DO-214AC | EC31QS04_3A/40V | DO-214AC | PD21 | DO-214AC | EC31QS04_3A/40V | DO-214AC | PEC1 | CAPPR250-630X900 | 560U-6.3V-OS | CAPPR250-630X900 | PEC2 | CAPAE-D | 47U | CAPAE-D | PEC3 | CAPPR250-630X900 | 560U-6.3V-OS | CAPPR250-630X900 | PEC5 | CAPPR350-800X900 | 270U-16V-OS | CAPPR350-800X900 | PEC6 | CAPPR350-800X900 | 270U-16V-OS | CAPPR350-800X900 | PEC7 | CAPPR350-800X900 | 270U-16V-OS | CAPPR350-800X900 | PEC8 | CAPPR250-630X900 | 560U-6.3V-OS | CAPPR250-630X900 | PEC9 | CAPPR250-630X900 | 560U-6.3V-OS | CAPPR250-630X900 | PEC10 | CAPPR350-800X900 | 270U-16V-OS | CAPPR350-800X900 | PEC12 | CAPPR350-800X900 | 270U-16V-OS | CAPPR350-800X900 | PEC13 | CAPPR350-800X900 | 270U-16V-OS | CAPPR350-800X900 | PF1 | FUSE6127 | FUSE_6127-10A/125V | FUSE6127 | PFB1 | L0805 | 120_3A | L0805 | PFB2 | L0805 | 120_3A | L0805 | PFB3 | L0805 | 120_3A | L0805 | PFB4 | L0805 | 120_3A | L0805 | PFB5 | L0805 | 120_3A | L0805 | PFB6 | L0805 | 120_3A | L0805 | PFB7 | L0805 | 120_3A | L0805 | PFB8 | L0805 | 120_3A | L0805 | PFB11 | L0805 | 120_3A | L0805 | PFB12 | L0805 | 120_3A | L0805 | PFB13 | L0805 | 120_3A | L0805 | PFB14 | L0805 | 120_3A | L0805 | PJ1 | DIN_4P | FMDS042015 | DIN_4P | PJ2 | WELL-LIN_3960-WS-10 | CONN_BATTERY-10X1 | WELL-LIN_3960-WS-10 | PJ5 | WL5011-1X4P-2_5MM | CONN-1x4P-2_5MM | WL5011-1X4P-2_5MM | PJ6 | WL5011-1X4P-2_5MM | CONN-1x4P-2_5MM | WL5011-1X4P-2_5MM | PJL1 | JP_SMT1 | SHORT-SMT1 | JP_SMT1 | PJL2 | JP_SMT1 | SHORT-SMT1 | JP_SMT1 | PJL3 | JP_SMT1 | SHORT-SMT1 | JP_SMT1 | PL1 | DRRI127 | 15UH | DRRI127 | PL2 | IND_SMP1205 | 4.7UH_12A | IND_SMP1205 | PL3 | IND_SMP1205 | 4.7UH_12A | IND_SMP1205 | PL4 | IND_SMP1205 | 4.7UH_12A | IND_SMP1205 | PL5 | IND_SMP1205 | 4.7UH_12A | IND_SMP1205 | PL6 | CHOKE_FQ131507-R45MNP | 0.45uH_40A | CHOKE_FQ131507-R45MNP | PL7 | CHOKE_FQ131507-R45MNP | 0.45uH_40A | CHOKE_FQ131507-R45MNP | PL8 | CHOKE_FQ131507-R45MNP | 0.45uH_40A | CHOKE_FQ131507-R45MNP | PL9 | CHOKE_FQ131507-R45MNP | 0.45uH_40A | CHOKE_FQ131507-R45MNP | PQ1 | SOT-23 | 2N7002 | SOT-23 | PQ2 | SOT-23 | SI2301CDS | SOT-23 | PQ3 | SO8 | TPC8127 | SO8 | PQ4 | SOT-23 | SC431LCSK | SOT-23 | PQ5 | SO8 | TPC8127 | SO8 | PQ6 | SO8 | TPC8127 | SO8 | PQ7 | SOT-23 | 2N7002 | SOT-23 | PQ8 | SOT-23 | 2N7002 | SOT-23 | PQ9 | SOT-23 | 2N7002 | SOT-23 | PQ10 | SOT-23 | 2N7002 | SOT-23 | PQ11 | SOT-23 | 2N7002 | SOT-23 | PQ12 | SO8 | TPC8127 | SO8 | PQ13 | SO8 | TPC8127 | SO8 | PQ14 | SO8 | TPC8127 | SO8 | PQ15 | SOT-23 | 2222A | SOT-23 | PQ16 | SOT-23 | SI2301CDS | SOT-23 | PQ17 | SOT-23 | 2N7002 | SOT-23 | PQ18 | SOT-23 | 2N7002 | SOT-23 | PQ20 | SO8 | SI4840BDY | SO8 | PQ21 | SO8 | TPC8127 | SO8 | PQ22 | SO8 | SI4840BDY | SO8 | PQ23 | SOT-23 | 2N7002 | SOT-23 | PQ24 | SO8 | SI4840BDY | SO8 | PQ25 | SO8 | TPC8127 | SO8 | PQ26 | SO8 | SI4840BDY | SO8 | PQ27 | SOT-23 | 2N7002 | SOT-23 | PQ28 | SOT-23 | 2N7002 | SOT-23 | PQ30 | SO8 | TPC8127 | SO8 | PQ31 | SOT-23 | 2N7002 | SOT-23 | PQ32 | SOT-23 | SC431LCSK | SOT-23 | PQ33 | SOT-23 | 2N7002 | SOT-23 | PQ37 | SO8-POWERPAK-S | SIR426DP | SO8-POWERPAK-S | PQ38 | SO8-POWERPAK-S | SIR416DP | SO8-POWERPAK-S | PQ39 | SO8-POWERPAK-S | SIR416DP | SO8-POWERPAK-S | PQ40 | SO8-POWERPAK-S | SIR426DP | SO8-POWERPAK-S | PQ41 | SO8 | TPC8127 | SO8 | PQ42 | SO8 | TPC8127 | SO8 | PQ43 | SOT-23 | 2N7002 | SOT-23 | PQ44 | SOT-23 | 2N7002 | SOT-23 | PQ45 | SO8-POWERPAK-S | SI7686DP | SO8-POWERPAK-S | PQ46 | SO8 | SI4800BDY | SO8 | PQ47 | SO8-POWERPAK-S | SI7170DP | SO8-POWERPAK-S | PQ48 | SO8-POWERPAK-S | SI7686DP | SO8-POWERPAK-S | PQ49 | SO8 | SI4800BDY | SO8 | PQ50 | SO8-POWERPAK-S | SI7170DP | SO8-POWERPAK-S | PQ51 | SO8-POWERPAK-S | SI7170DP | SO8-POWERPAK-S | PQ52 | SOT-23 | 2N7002 | SOT-23 | PQ53 | SO8-POWERPAK-S | SI7686DP | SO8-POWERPAK-S | PQ54 | SO8-POWERPAK-S | SI7170DP | SO8-POWERPAK-S | PQ55 | SO8-POWERPAK-S | SI7170DP | SO8-POWERPAK-S | PQ56 | SO8-POWERPAK-S | SI7686DP | SO8-POWERPAK-S | PQ57 | SO8-POWERPAK-S | SI7170DP | SO8-POWERPAK-S | PQ58 | SO8-POWERPAK-S | SI7170DP | SO8-POWERPAK-S | PQ59 | SOT-23 | 2N7002 | SOT-23 | PQ60 | SOT-23 | SC431LCSK | SOT-23 | U1 | FCBGAF25X27-1170 | Valleyview | FCBGAF25X27-1170 | U2 | QFN4-8X8-69 | CH7511B | QFN4-8X8-69 | U3 | SO8 | NM24C08 | SO8 | U4 | SO8 | LM258M | SO8 | U5 | SOT-23-5 | 74LVC1G08 | SOT-23-5 | U6 | SOP65X660-14 | TXB0104PWR | SOP65X660-14 | U7 | SOP65X660-14 | TXB0104PWR | SOP65X660-14 | U8 | SOG65X425-8 | TCA9406DCTR | SOG65X425-8 | U10 | SOG65X425-8 | TCA9406DCTR | SOG65X425-8 | U11 | SOP65X660-14 | TXB0104PWR | SOP65X660-14 | U12 | SOP65X660-14 | TXB0104PWR | SOP65X660-14 | U13 | QFN5-7X7-48 | MAX9406ETM+ | QFN5-7X7-48 | U14 | SOPT65X480-8 | AZ1065-06Q | SOPT65X480-8 | U15 | SOPT65X480-8 | AZ1065-06Q | SOPT65X480-8 | U16 | SOT-23-5 | NC7ST08M5X | SOT-23-5 | U17 | SOT-23-5 | NC7ST08M5X | SOT-23-5 | U18 | LQFP14X14-128 | F81866AD-I | LQFP14X14-128 | U19 | SOP65X780-20 | 74F244 | SOP65X780-20 | U20 | SOP65X780-28 | HIN213ECAZ-T | SOP65X780-28 | U21 | SOP65X780-28 | HIN213ECAZ-T | SOP65X780-28 | U22 | SO8 | LTC485 | SO8 | U23 | SO8 | LTC485 | SO8 | U24 | SOP65X780-28 | HIN213ECAZ-T | SOP65X780-28 | U25 | SOP65X780-28 | HIN213ECAZ-T | SOP65X780-28 | U26 | SOT-23-5 | 74LVC1G08 | SOT-23-5 | U27 | SQFN5-7X7-49 | USB4604 | SQFN5-7X7-49 | U28 | SOPT65X480-8 | RT9715BGF | SOPT65X480-8 | U29 | SOPT65X480-8 | AZ1065-06Q | SOPT65X480-8 | U30 | SOT-23-5 | 74LVC1G08/X | SOT-23-5 | U31 | SOT-23-5 | RT9711APBG | SOT-23-5 | U32 | SOT-23-5 | RT9711APBG | SOT-23-5 | U33 | QFPS7X7-48 | ALC262-VD2-GR | QFPS7X7-48 | U34 | SOT-23-5 | 74LVC1G08/X | SOT-23-5 | U35 | TSSOP24-TH | AA7011/TPA6011A | TSSOP24-TH | U36 | QFN5-9X9-65 | I210-AT/IT | QFN5-9X9-65 | U37 | SO8 | PCT25VF040B-80-4I-SAE | SO8 | U38 | QFN5-9X9-65 | I210-AT/IT | QFN5-9X9-65 | U39 | SO8 | PCT25VF040B-80-4I-SAE | SO8 | U40 | SOT-223 | LX8117-3.3V | SOT-223 | U41 | SOT-363 | SI1555DL | SOT-363 | U42 | SOT-23 | APX803-29SAG-7/SOT-23/X | SOT-23 | U43 | QFPT7X7-64 | EXC7700 | QFPT7X7-64 | U44 | QFN5-4X4-25 | C8051F394 | QFN5-4X4-25 | U45 | SO8 | LM293 | SO8 | U46 | SO8 | LM293 | SO8 | U47 | QFPT14X14-128 | NPCE791L | QFPT14X14-128 | U48 | SOP127X380-8 | PCT25VF080B-80-4I-SAE | SOP127X380-8 | U51 | SOT-23-5 | 74LVC1G08 | SOT-23-5 | X1 | XTAL_HC-49US | 25MHz | XTAL_HC-49US | X2 | XTAL_MC-146 | 32.768KHz | XTAL_MC-146 | X3 | XTAL_HC-49US | 27MHz | XTAL_HC-49US | X4 | XTAL_HC-49US | 24MHz | XTAL_HC-49US | X5 | XTAL_HC-49US | 25MHz | XTAL_HC-49US | X6 | XTAL_HC-49US | 25MHz | XTAL_HC-49US | X7 | XTAL_HC-49US | 12MHz | XTAL_HC-49US |
