[Allegro16.6以下] 再爆-宏基Q77_B75H2  电脑主板 PCB文件共享
查看10415 | 回复53 | 2016-11-19 14:57:37 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
采用Q系列英特尔行业专供芯片组。稳定性跟耐用性都要比DIY市场的H系列好非常多。Q77主板。支持双DP高清接口,前后置USB3.0 sata6G接口。磁盘阵列。等。具体型号Q77H2-AM!支持全系列1155接口CPU。DDR3内存。
REFDESCOMP_DEVICE_TYPESYM_NAME
ACODEC1LQFP48LQFP48
ATX_12VATX_PWR_4PATX_PWR_4P
ATX_POWERATX_PWR_24PATX_PWR_24P
AUDIO1AUDIO_JACK_13P_3AUDIO_JACK_13P_3
BAT1BATTERY_1BATTERY_1
CLR_CMOSJ3X1J3X1
COM1COM_D-SUB_9P_MCOM_D-SUB_9P_M
COM2J5X2_COMJ5X2_COM
CPU1LGA1155LGA1155
CPU_FANFAN4X1FAN4X1
C_INTRUSIONJ2X1J2X1
D1BAT54_132_2BAT54_132_2
D2BAT54_132_2BAT54_132_2
D3FPC_4P10_R_1FPC_4P10_R_1
D4FPC_4P10_R_1FPC_4P10_R_1
D5SOD_523SOD_523
D6BAT54_132_2BAT54_132_2
D7SOD_123_2SOD_123_2
D8BAT54_132_2BAT54_132_2
D9BAT54_132_2BAT54_132_2
D101N41481N4148
D11FPC_4P10_R_1FPC_4P10_R_1
D12FPC_4P10_R_1FPC_4P10_R_1
D131N41481N4148
D14BAT54_132_2BAT54_132_2
D151N41481N4148
D16BAV99_132_2BAV99_132_2
D17BAV99_132_2BAV99_132_2
D18SOD_123_2SOD_123_2
DD1BAT54_132_2BAT54_132_2
DD2BAT54_132_2BAT54_132_2
DIMM1DDR3_240P_2DDR3_240P_2
DIMM2DDR3_240P_2DDR3_240P_2
DIMM3DDR3_240P_2DDR3_240P_2
DIMM4DDR3_240P_2DDR3_240P_2
DP1DISPLAY_20P_1DISPLAY_20P_1
DP2DISPLAY_20P_1DISPLAY_20P_1
DVI1DVI_29P_MB_1DVI_29P_MB_1
EC1EC2D5_6D3_H11MMEC2D5_6D3_H11MM
EC2EC2D5_6D3_H11MMEC2D5_6D3_H11MM
EC3EC2D5_6D3_H11MMEC2D5_6D3_H11MM
EC4EC2D5_6D3_H11MMEC2D5_6D3_H11MM
EC5EC2D5_6D3_H11MMEC2D5_6D3_H11MM
EC6EC2D5_6D3_H11MMEC2D5_6D3_H11MM
EC7EC2D5_6D3_H11MMEC2D5_6D3_H11MM
EC8EC3D5_8_H11MM_1PEC3D5_8_H11MM_1P
EC9EC3D5_8_H11D5MM_1PEC3D5_8_H11D5MM_1P
EC10EC3D5_8_H11D5MM_1PEC3D5_8_H11D5MM_1P
EC11EC3D5_8_H11D5MM_1PEC3D5_8_H11D5MM_1P
EC12EC3D5_8_H11D5MM_1PEC3D5_8_H11D5MM_1P
EC13EC3D5_8_H11D5MM_1PEC3D5_8_H11D5MM_1P
EC14OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC15OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC16OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC17OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC18OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC19OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC20OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC21OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC22OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC23OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC24EC3D5_8_H11D5MM_1PEC3D5_8_H11D5MM_1P
EC25OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC26OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC27OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC28OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC29OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC30OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC31EC2D5_6D3_H11MMEC2D5_6D3_H11MM
EC32EC2D5_6D3_H11MMEC2D5_6D3_H11MM
EC33EC2D5_6D3_H11MMEC2D5_6D3_H11MM
EC34OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC35OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC36OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
EC37EC3D5_8_H9MM_1PEC3D5_8_H9MM_1P
EC38EC3D5_8_H9MM_1PEC3D5_8_H9MM_1P
EC39EC2D5_6D3_H11MMEC2D5_6D3_H11MM
EC40EC2D5_6D3_H11MMEC2D5_6D3_H11MM
EC41EC2D5_6D3_H11MMEC2D5_6D3_H11MM
EC42EC2D5_6D3_H11MMEC2D5_6D3_H11MM
EC43OSCON2D5_6D3_H9MMOSCON2D5_6D3_H9MM
F1FUSE_SMD_1FUSE_SMD_1
F2F1812F1812
FB1FB0603-SHORT_1FB0603-SHORT_1
FB2FB0603-SHORT_1FB0603-SHORT_1
FB3FB0603-SHORT_1FB0603-SHORT_1
FB4FB0603-SHORT_1FB0603-SHORT_1
FB5FB0603-SHORT_1FB0603-SHORT_1
FB6FB0603-SHORT_1FB0603-SHORT_1
F_AUDIOJ5X2_AUDIO_1J5X2_AUDIO_1
F_PANELJ7X2_PANEL_10PJ7X2_PANEL_10P
F_USB1J5X2_USB_1394J5X2_USB_1394
F_USB2J5X2_USB_1394J5X2_USB_1394
F_USB3J5X2_USB_1394J5X2_USB_1394
GPIO1J2X1J2X1
GPIO2J2X1J2X1
H1HOLE8_5HOLE8_5
H2HOLE8_5HOLE8_5
H3HOLE8_5HOLE8_5
H4HOLE8_5HOLE8_5
H5HOLE8_5HOLE8_5
H6HOLE8_5HOLE8_5
INT_SPKJ4X2_4PJ4X2_4P
L5CHOKE_NLC252018_SMD_2PCHOKE_NLC252018_SMD_2P
L6CHOKE_9D5X11_PT7MM_H_2CHOKE_9D5X11_PT7MM_H_2
L7CHOKE_1R0M-R_1CHOKE_1R0M-R_1
L8CHOKE-R56M_PT6D6X4D2MM_2CHOKE-R56M_PT6D6X4D2MM_2
L9CHOKE-R56M_PT6D6X4D2MM_2CHOKE-R56M_PT6D6X4D2MM_2
L10CHOKE-R56M_PT6D6X4D2MM_2CHOKE-R56M_PT6D6X4D2MM_2
L11CHOKE-R56M_PT6D6X4D2MM_2CHOKE-R56M_PT6D6X4D2MM_2
L12CHOKE_R30M_1CHOKE_R30M_1
L13CHOKE_4R7_PT2D65MM_SMDCHOKE_4R7_PT2D65MM_SMD
L14FB0805FB0805
L15CHOKE_9D5X11_PT7MM_H_2CHOKE_9D5X11_PT7MM_H_2
L16CHOKE_1R0M-R_1CHOKE_1R0M-R_1
L17FB0603FB0603
LAN1QFN48_PT04-4D4X4D4MM_1QFN48_PT04-4D4X4D4MM_1
LAN2FBGA121_BCM5761FBGA121_BCM5761
MC1C0805C0805
ME_DISABLEJ3X1J3X1
MF1TO251_GDS_PT90_1TO251_GDS_PT90_1
MN1SOT23_GDS_2SOT23_GDS_2
MN2SOT23_GDS_2SOT23_GDS_2
MN3SOT23_GDS_2SOT23_GDS_2
MN4TO252_GDSTO252_GDS
MN5TO252_GDSTO252_GDS
MN6TO252_GDSTO252_GDS
MN7SOT23_GDS_2SOT23_GDS_2
MN8SOT23_GDS_2SOT23_GDS_2
MN9SOT23_GDS_2SOT23_GDS_2
MN10SOT23_GDS_2SOT23_GDS_2
MN11SOT23_GDS_2SOT23_GDS_2
MN12SOT23_GDS_2SOT23_GDS_2
MN13SOT23_GDS_2SOT23_GDS_2
MN14SOT23_GDS_2SOT23_GDS_2
OBR1J2X1J2X1
OD1BAT54_132_2BAT54_132_2
OD2BAT54_132_2BAT54_132_2
P1SHORT2-NMNPSHORT2-NMNP
P2SHORT2-NMNPSHORT2-NMNP
P3SHORT2-NMNPSHORT2-NMNP
P4SHORT2-NMNPSHORT2-NMNP
P5FB0603-SHORT_1FB0603-SHORT_1
PCH1BGA942_CPTBGA942_CPT
PCIE16XPCIE_X16_164P_3PCIE_X16_164P_3
PCIE1X_1PCIE_X1_36P_2PCIE_X1_36P_2
PRINTERJ13X2_LPT_1J13X2_LPT_1
PSKMKB_MSKB_MS
QP2TO251_BCE_PT90_1TO251_BCE_PT90_1
ROM1SOP8_W210_PT50SOP8_W210_PT50
ROM2SOP8_W210_PT50SOP8_W210_PT50
RT1R0402R0402
RT2R0402R0402
RT3R0402R0402
RT4R0402R0402
RT5R0402R0402
SATA1SATA7P-M-HUANXUN_1SATA7P-M-HUANXUN_1
SATA2SATA7P-M-HUANXUN_1SATA7P-M-HUANXUN_1
SATA3SATA7P-M-HUANXUN_1SATA7P-M-HUANXUN_1
SATA4SATA7P-M-HUANXUN_1SATA7P-M-HUANXUN_1
SBT1BAT54_132_2BAT54_132_2
SD1SOD_123_2SOD_123_2
SD2SOD_123_2SOD_123_2
SD3SOD_123_2SOD_123_2
SD4SOD_123_2SOD_123_2
SJ12X30_XDP_CONN-NMNP2X30_XDP_CONN-NMNP
SP1SHORT2-NMNPSHORT2-NMNP
SP2SHORT2-NMNPSHORT2-NMNP
SP3SHORT2-NMNPSHORT2-NMNP
SPDIF_OUTJ4X1_SPDIFO_2PJ4X1_SPDIFO_2P
SPI_DEBUGJ6X2_PT1D27MM_SMD_2PJ6X2_PT1D27MM_SMD_2P
SQ1SOT23_BCE_2SOT23_BCE_2
SQ2SOT223_BCE_3P_1SOT223_BCE_3P_1
SU1QFN48_PT05-ASM1442_1QFN48_PT05-ASM1442_1
SYS_FANFAN4X1FAN4X1
TPMJ10X2_TPM_4P-FOXTEQJ10X2_TPM_4P-FOXTEQ
TP_VGATP30_SMDTP30_SMD
U1SOT23_6P_2SOT23_6P_2
U2SOT23_6P_2SOT23_6P_2
U3MSOP10_W120_PT05MSOP10_W120_PT05
U4MSOP10_W120_PT05MSOP10_W120_PT05
U5MSOP10_W120_PT05MSOP10_W120_PT05
U6MSOP10_W120_PT05MSOP10_W120_PT05
U7SOT23_6P_2SOT23_6P_2
U8SOT23_6P_2SOT23_6P_2
U9SOT23_6P_2SOT23_6P_2
U10SOP8_W210_PT50SOP8_W210_PT50
U11PSOP8_W150_PT50_P6NMNPPSOP8_W150_PT50_P6NMNP
U12SOT23_6P_2SOT23_6P_2
U13SOT23_6P_2SOT23_6P_2
U14SOT23_6P_2SOT23_6P_2
U15SOT23_8P_1SOT23_8P_1
U16TSSOP20_W170_PT065TSSOP20_W170_PT065
U17TSSOP20_W170_PT065TSSOP20_W170_PT065
U18SOP8_W150_PT50SOP8_W150_PT50
U19SOP8_W150_PT50SOP8_W150_PT50
U20QFN20_ISL95870B_1QFN20_ISL95870B_1
U21QFN48_PT04-4D4X4D4MM_1QFN48_PT04-4D4X4D4MM_1
U22SOP8_W150_PT50SOP8_W150_PT50
U23DFN10_RT8106A_1DFN10_RT8106A_1
U24SOT23_6P_2SOT23_6P_2
U25SOT23_8P_1SOT23_8P_1
U26SOP8_W150_PT50-92X110SOP8_W150_PT50-92X110
U27SOT23_6P_2SOT23_6P_2
U28SOT23_8P_1SOT23_8P_1
U29SOP8_W150_PT50SOP8_W150_PT50
U30SOT23_6P_2SOT23_6P_2
U31SOT23_6P_2SOT23_6P_2
U32TSSOP28_W170_PT065TSSOP28_W170_PT065
U33SOT23_8P_1SOT23_8P_1
U34PSOP8_W150_PT50_P6NMNPPSOP8_W150_PT50_P6NMNP
U35SOP8_W150_PT50SOP8_W150_PT50
U36SOP8_W150_PT50SOP8_W150_PT50
U37QFP128QFP128
U38SOP8_W150_PT50-86X86_1SOP8_W150_PT50-86X86_1
USB3F1CON10X2_2MM_20P_USB3_1CON10X2_2MM_20P_USB3_1
USB3_1USB3_18P4R-LOTES-SHORTBODY_1USB3_18P4R-LOTES-SHORTBODY_1
USBLAN1USBLAN_LED_AUSBLAN_LED_A
X1CRYSTALCRYSTAL
X2CRYSTALCRYSTAL
X3CRYSTALCRYSTAL
Y1ETXTALS-SPADETXTALS-SPAD
重要提示:PCB作品文件展下载说明
老吴 | 2016-11-19 15:00:52 | 显示全部楼层
继续曝光 电脑主板 PCB文件。朝着 100份电脑主板共享的方向前进。
Q77V1.0.zip (16.37 MB, 下载次数: 27)
由于这个电脑主板目前还在市场上流通销售,PCB文件我不想让他随便流通。所以超高金币下载 1000金币。 有需要的自己想办法赚金币。
就像某专家说的, 中国房价为什么这么高,这么高对大家有什么好处?  中国房价这么高,还不是为了让大家有动力去赚钱啊,对生活要有追求,人要是没动力,对生活没追求了,那就是在等死了。。。这都是为大家好啊。。
点评
吴总 房价崩了  详情 回复 发表于 2024-9-25 17:51
xzcxnihd | 2016-11-19 16:28:18 | 显示全部楼层
一年后再来看看,估计那时候还是0下载,发跟没发一个样
单枪舞九州 | 2016-11-19 16:34:58 | 显示全部楼层
kkkiii2008 | 2016-11-19 17:51:38 | 显示全部楼层
老吴 | 2016-11-19 22:42:02 | 显示全部楼层
回 xzcxnihd 的帖子
xzcxnihd:一年后再来看看,估计那时候还是0下载,发跟没发一个样 (2016-11-19 16:28)
摆设,有需要的下载。
秋风式街球 | 2016-11-20 08:22:12 | 显示全部楼层
秋风式街球 | 2016-11-20 08:22:35 | 显示全部楼层
单枪舞九州 | 2016-11-20 08:50:37 | 显示全部楼层
miaomiao | 2016-11-20 08:52:34 | 显示全部楼层
第一次看到宏基的主板
