重要提示:PCB作品文件展下载说明
HB301 设计的2Port网路打印机或 NAS
BOM | | | | | | | | 序 號 | 品 名 | 規 格 | 單位 | 用量 | 最近進價(NTD) | 材料成本(NTD) | └40─----------------------- | PACKING ASS'Y | V1.1 | PCS | 1 | | | ├10─--------------------- | CARTON | REV.A | PCS | 0.0333 | 18.91 | 0.629703 | ├20─--------------------- | CARTON,PAD | REV.A | PCS | 0.0667 | 2.06 | 0.137402 | ├30─--------------------- | Box Partition | REV A | PCS | 1 | 0.52 | 0.52 | ├40─--------------------- | PWR ADAPTOR SWITCH | 90-264V,3W,5V/0.6A,US,啟益 | PCS | 1 | 36.5 | 36.5 | ├50─--------------------- | BAG | POLY 145x102xT0.08MMREV.A | PCS | 1 | 0.112 | 0.112 | ├60─--------------------- | GIFT COLOR BOX | REV A | PCS | 1 | 4.41 | 4.41 | ├70─--------------------- | CE LABEL | REV A | PCS | 1 | 0.43 | 0.43 | ├80─--------------------- | LABEL,GIFT BOX | 透明40番42MM | PCS | 1 | 0.47 | 0.47 | └90─--------------------- | QIG | REV A | PCS | 1 | 1 | 1 | ├30─----------------------- | PRODUCT ASS'Y | REV1.1 | PCS | 1 | | | │├10─--------------------- | CASE,TOP | ABS+PC/WHITE,REV.A | PCS | 1 | 10.5 | 10.5 | │├20─--------------------- | CASE BOTTOM | ABS+PC/WHITE,REV.A | PCS | 1 | 9.5 | 9.5 | │├30─--------------------- | SCREW | PAN PHILIPS M2x10mmREV.A | PCS | 4 | 0.06 | 0.24 | │├40─--------------------- | MAGNET | F105P REV.A | PCS | 2 | 6.6 | 13.2 | │├50─--------------------- | RUBBER FOOT | RF6-2 6x2MM BLACK | PCS | 4 | 0 | 0 | │├60─--------------------- | PCBA ASSY CHINA | REV:2.0 | PCS | 1 | | | ├001───────── | PHONE JACK | WITH TRANSF/LED101110FD2S2M442ZA 8P8Cx1P,90 | PCS | 2 | 24 | 48 | ├002───────── | CAP,CHINA | EC,470UF,16V,20%,RA 8*11 | PCS | 2 | 0.4 | 0.8 | ├003───────── | CAP.EC | 22UF,16V,20%,RA 5x11 | PCS | 1 | 0.121 | 0.121 | ├004───────── | CAP.EC | 47UF,16V,20%,RA 5x11 | PCS | 2 | 0.121 | 0.242 | ├005───────── | CAP.EC | 220UF,16V,20%,RA6.3x11 | PCS | 2 | 0.28 | 0.56 | ├006───────── | CAP.EC | 10UF,16V,20%,RA 5x11 | PCS | 2 | 0.121 | 0.242 | ├007───────── | HEADER | PIN,6x1PIN 180 2.54MMPT=6.1 | PCS | 1 | 0.45 | 0.45 | ├008───────── | HEADER CN | PIN,4*1PIN,180,2.54MM | PCS | 1 | 0.09 | 0.09 | ├009───────── | SW CHINA | TACK,4P2T,WO/KNOB,4PIN,2.54MM | PCS | 2 | 0.77 | 1.54 | ├010───────── | CONN DC JACK | DC16V,3A,PIN-2MM,90 | PCS | 1 | 0.77 | 0.77 | ├011───────── | XTAL (鑫谷) | 25MHZ,30PPM,HALF,DIP-2 | PCS | 1 | 1.15 | 1.15 | ├011───────── | LED, | 3MM,X-G,W/HOLDER | PCS | 3 | 0 | 0 | └012───────── | SMD ASSY CN | L2LEVB REV.2.0 | SET | 1 | | | ├001───────── | CAP.MULT | CHIP 6.8nF, 16V,X7R,+-10%,0402 | PCS | 1 | 0.4 | 0.4 | ├002───────── | CAP,MULT | CHIP 33PF NPO DC50V+-5% 0402 | PCS | 2 | 0.032 | 0.064 | ├003───────── | CAP.MULT | .CHIP 0.1UF,DC16V,+80-20%.0402 | PCS | 3 | 0.024 | 0.072 | ├004───────── | CAP.MUL | T.CHIP,0.1UF,DC50V,+80%-20,0603 | PCS | 2 | 0.029 | 0.058 | ├005───────── | CAP,MULT | CHIP 22PF NPO DC50V+-5% 0402 | PCS | 2 | 0.028 | 0.056 | ├006───────── | CAP.MUL | T CHIP,0.01UF,DC50V,+80-20%,0603 | PCS | 4 | 0.034 | 0.136 | ├007───────── | CAP,MULT | CHIP,10UF,Y5V,16V,0805,+-20% | PCS | 6 | 0.525 | 3.15 | ├008──────── | CAP.MULT CHINA | CHIP,0.1UF,DC50V,+80%-20,0603 | PCS | 4 | 0.029 | 0.116 | ├012───────── | INDUCTOR | CHIP , 33uH,+-30%,3A, 10*10*4mm | PCS | 1 | 3.35 | 3.35 | ├013───────── | INDUCTOR | CHIP , 2.5uH,+-20%,1.2A, 2.5*2.4*1.0mm | PCS | 2 | 2.2 | 4.4 | ├014───────── | CORE,CHI | P BEAD 120 OHM,+-25%,700MA,0805 | PCS | 2 | 0.066 | 0.132 | ├015───────── | RES CHIP | 2K OHM,1%,0402 | PCS | 1 | 0 | 0 | ├016───────── | RES CHIP | 1K OHM 1/16W 1% 0402 | PCS | 8 | 0.014 | 0.112 | ├017───────── | RES CHIP | SIP 4.7Kx4 1/16W 5% 8PIN 0402 | PCS | 6 | 0 | 0 | ├018───────── | RES CHIP | 100 OHM 1/16W 1% 0402 | PCS | 1 | 0.0158 | 0.0158 | ├019───────── | RES CHIP | 37.4K OHM,1% 0402 | PCS | 1 | 0.0158 | 0.0158 | ├020───────── | RES CHIP | 40.2K OHM,1%, 0402 | PCS | 1 | 0.0179 | 0.0179 | ├021───────── | RES CHIP | 12K OHM , 1/16W ,1%,0402 | PCS | 1 | 0.0158 | 0.0158 | ├022───────── | RES CHIP | 100K OHM,1%,1/16W0402 | PCS | 3 | 0 | 0 | ├023───────── | RES CHIP | 330 OHM 1/16W 1% 0402 | PCS | 3 | 0.0158 | 0.0474 | ├024───────── | RES CHIP | 10 OHM 1/16W 1% 0402 | PCS | 45 | 0 | 0 | ├025───────── | RES CHIP | 4.7K OHM 1/16W 1%0402 | PCS | 35 | 0.0158 | 0.553 | ├026───────── | RES CHIP | 56 OHM 1% 0402 | PCS | 1 | 0 | 0 | ├027───────── | RES CHIP | 10K OHM 1/16W 1% 0402 | PCS | 2 | 0.014 | 0.028 | ├028───────── | RES CHIP | 1.5K OHM 1/16W 1%0402 | PCS | 1 | 0.014 | 0.014 | ├029───────── | RES CHIP | 6.2K OHM 1% 1/16W0402 | PCS | 2 | 0.015 | 0.03 | ├030───────── | RES CHIP | 5.1K OHM SMD 1% 0402 | PCS | 4 | 0.0179 | 0.0716 | ├031───────── | RES CHIP | 49.9 OHM 1/16W 1%0402 | PCS | 8 | 0.014 | 0.112 | ├032───────── | RES CHIP | 0 OHM 1/16W 1% 0402 | PCS | 2 | 0.0179 | 0.0358 | ├033───────── | RES CHIP | 200 OHM SMD 1% 0402 | PCS | 4 | 0.0158 | 0.0632 | ├034───────── | IC,RESET | EM6353BX2SP3B 2.9V200MS SOT23 | PCS | 1 | 3.2025 | 3.2025 | ├035───────── | IC,VOLTA | GE REGULATOR-IO/ZYAOZ1010,2A,SO-8 | PCS | 1 | 0 | 0 | ├036───────── | IC,REGUL | ATOR CAT7101CT50.6A,1.8MHz,ADJ SOT-25 | PCS | 2 | 0 | 0 | ├037───────── | IC CPU | HB301 BGA255 | PCS | 1 | | | ├038───────── | IC FLASH | L2LEVB,VB,CKSUM:6664 | PCS | 1 | | | │└001──────── | MX25L6455EMI-10G | 64M-BIT CMOS SERIALFLASH SOP-16 | PCS | 1 | | | ├039───────── | IC,SDRAM | NT5DS32M16BS-5T32Mx16x4 5NS | PCS | 1 | 0 | 0 | ├040───────── | IC,PHY | 10/100M IP101ALF LQFP-48 | PCS | 2 | 0 | 0 | └041───────── | 4/L | PCB REV 2.0 | PCS | 1 | 65 | 65 | | | | | | 合計: NTD | 212.88291 | [sub][/sub][sup][/sup] |
HB301.rar
1.91 MB, 下载次数: 2, 下载积分: 金币 -5 枚
请输入描述
重要提示:PCB作品文件展下载说明
