板子有以下主要元件。
Name | Part Type | PCB Decal | Value | 5V | TP | TP-R2.0 | T(L) | 8V5 | TESTPOINT-1 | TP-R1.5 | | ACC | TP | TP-1.0 | RL- | ACCOM1 | ACCOM | ACCOM-CHOKES | | AGND | TEST_POINT_1 | TP-1.5 | TP | B+ | TP | TP-R2.0 | RL- | B3V3 | TEST_POINT_1 | TP-1.2 | TP | BREAK | TP | TP-1.0 | RL- | B_3V3 | TP | TP-1.0 | T(L) | CN5 | POWER_INTERFACE | CON-16-PWR-776A | CON16(power) | CN7 | TV_ANT | ANT-ESTT-10 | ANT | CON1 | FPC-12PIN-0.5MM | FPC-12PIN-0.5MM | NC | CON2 | CON-SMT-50PIN | SFPC-50PIN-0.5MM-B | | CON3 | CON-4P | DEBUD4 | NC | CON4 | AV_CON | NAVI_BUILT_IN_CON | 20P CON | CON5 | AV_CON_EXTRA | AV_CON_EXTRA | 18P CON | CON6 | CON-7PIN | CON7-1.25/SOJ | 7PIN/1.25/SMD | CON7 | CON-SMT-4PIN | CON-4PIN-SOJ-1.25 | 4PIN CON 1.25mm li | CON8 | CON-SMT-10PIN | CON-10PIN-SOJ-1.25 | | CON9 | FPC-12PIN-0.5MM | FPC-12PIN-0.5MM | NC | CON10 | CON-SMT-10PIN | CON-10PIN-SOJ-1.25 | | CON11 | CON-SMT-10PIN | CON-10PIN-SOJ-1.25 | | CON12 | CON-4P | DEBUD4 | NC | CON13 | CON-4P | DEBUD4 | NC | CON15 | CON-SMT-2PIN | CON-2PIN-SOJ-1.25 | | D1 | DIODE | SOD-323-776 | 1N4148 | D2 | DIODE | SOD-323-776 | 1N4148 | D3 | DIODE | SOD-323-776 | 1N4148 | D4 | DIODE-2 | SOD-106 | 1N4004 | D5 | DIODE | DIODE_TVS_DIP_V_U | TVS | D6 | 1SR154-400 | SOD-106 | IN4004 | D7 | DIODE-1 | SOD-106 | 1N4004 | D8 | DIODE-2 | SOD-106 | 1N4004 | D9 | DIODE-3 | SOD-106 | SS16 | D10 | DIODE | SOD-323-776 | 1N4148 | D120 | 1SR154-400 | SOD-106 | IN4004 | D121 | 1SR154-400 | SOD-106 | IN4004 | DGND | TP | TP-1.0 | T(L) | FL+ | TEST_POINT_1 | TESTP-1.0 | TP | FL- | TEST_POINT_1 | TESTP-1.0 | TP | FR+ | TEST_POINT_1 | TESTP-1.0 | TP | FR- | TEST_POINT_1 | TESTP-1.0 | TP | FU1 | FUSE | FUSE-1210 | 1.5A | FU2 | FUSE | FUSE-1210 | 1A5 | FU4 | FUSE | FUSE-1206 | 1.5A | FU5 | FUSE | FUSE-1206 | 1.5A | FU14 | FUSE | FUSE-1206 | 1.5A | FU100 | FUSE | FUSE-1206 | 1206(200mA) | FU101 | FUSE | FUSE-1206 | 1206(200mA) | GND | TP | TP-1.0 | RL- | IC1 | TEF6606T | TEF6606V2 | TEF6621 | IC2 | STM8-64 | LQFP64-P-1010-0.5A | STM8-80 | IC3 | 74HC4052 | TSSOP-16 | | IC4 | LSP3132 | SOP-8 | LSP3132 | IC6 | LP2950 | SOP-8 | LP2950(3.3V) | IC14 | LDO_7808 | TO-252 | 78D09 | IC48 | IPOD_ADS | IPOD_2_0_B | | ILL | TP | TP-1.0 | RL- | J1 | R-JUMP | JUMP-PAD2.0-776 | | J2 | R-JUMP | JUMP-PAD2.0-776 | | J3 | R-JUMP | JUMP-PAD2.0-776 | | J5 | R-JUMP | JUMP-PAD2.0-776 | | J6 | R-JUMP | JUMP-PAD2.0-776 | | J7 | R-JUMP | JUMP-PAD2.0-776 | | J8 | CON-SMT-52PIN | | | J9 | SHORT_DOT | JUMP-1.0 | SHORT | J11 | JUMP | JUMP-2.0 | | J12 | JUMP | JUMP-2.0 | | J14 | R-JUMP | JUMP-PAD2.0-776 | | J15 | R-JUMP | JUMP-PAD2.0-776 | | J16 | R-JUMP | JUMP-PAD2.0-776 | | J22 | R-JUMP | JUMP-PAD2.0-776 | | JP101 | HEADER_3_0A | DEBUG3 | BOOTSEL | L1 | L | IND-SMT-CD54 | 100uH//CD54 | L2 | L | IND-SMT-CD32 | 0R | L3 | CDH-125 | CDH-125 | 22uH/5A(CDH129) | L5 | IND | FB0805 | 10uH/0805 | L6 | L | IND-SMT-CD54 | 100uH//CD54 | L8 | L | IND-SMT-CD32 | 100uH//CD32 | L9 | L | IND-SMT-CD32 | 22uH/CD32 | L10 | LL | IND-SMT-0603 | 2.2UH | L11 | IND-215NH-1206 | IND-SMT-1206-776 | 215NH/1206 | L12 | L | L1210 | 1A 60R | L13 | L | IND-SMT-CD32 | 10uH/CD32 | L14 | IND-290NH-1206 | IND-SMT-1206-776 | 290NH/1206 | L15 | LL | IND-SMT-0805 | 1UH/1.1UH? | L16 | LL | IND-SMT-0805 | 1.8UH | L17 | L | IND-SMT-CD32 | 10uH/CD32 | L18 | L | IND-SMT-0805 | 10uH/0805 | L19 | L | IND-SMT-0805 | 10uH/0805 | L20 | L | IND-SMT-0805 | 10uH/0805 | L21 | LL | IND-SMT-0603 | 2.2UH | L22 | L | L1210 | 560uH | L23 | L | L1210 | 560uH | L25 | L | IND-SMT-CD32 | 15uH/CD32 | M-IN_SW | TEST_POINT_1 | TP-1.2 | TP | M-OUT_SW | TEST_POINT_1 | TP-1.2 | TP | M1 | PCHANNEL | SOT-23-MOSFET | IRLML6402 | M2 | IRF7205 | SOP8 | 4459 | M5 | PCHANNEL | SOT-23-MOSFET | IRLML6402 | MCU_3V3 | TP | TP-R2.0 | T(L) | MOTO-RIN | TEST_POINT_1 | TP-1.2 | TP | MOTO_FIN | TEST_POINT_1 | TP-1.2 | TP | M_OP_A | TEST_POINT_1 | TP-1.2 | TP | M_RX | TEST_POINT_1 | TESTP-1.0 | TP | M_TX | TEST_POINT_1 | TESTP-1.0 | TP | P14V | TP | TP-R1.5 | T(L) | P58 | TP | TP-1.0 | T(L) | PCLK | TEST_POINT_1 | TP-1.2 | TP | P_ANT | TP | TP-1.0 | RL- | P_CNTR | TP | TP-1.0 | RL- | Q2 | PNP | SOT-23-3906 | 3906 | Q3 | 2N3904S | SOT-23-776 | 2N3904 | Q4 | TRANS-NPN | SOT-23 | 2N3904 | Q5 | 2N3904S | SOT-23-776 | 2N3904 | Q6 | 2N3904 | SOT-23-776 | 2N3904 | Q7 | 2N3904 | SOT-23-776 | 2N3904 | Q8 | 2N3904 | SOT-23-776 | 2N3904 | Q9 | PNP | SOT-23 | MMBBT2907A | Q10 | PNP | SOT-23-3906 | 3906 | Q11 | PNP | SOT-23 | MMBBT2907A | Q12 | PNP | SOT-23-3906 | 3906 | Q14 | KRC402 | USM | KRC402 | Q15 | TRANS-NPN | SOT-23 | 3904 | Q16 | TRANS-PNP | SOT-89 | 3CG1663 | Q17 | 2N3904 | SOT-23-776 | 2N3904 | Q18 | 2N3904 | SOT-23-776 | 2N3904 | Q19 | 2N3904 | SOT-23-776 | 2N3904 | Q22 | KTC3265Y | SOT-23-776 | 2N3904 | Q24 | TRANS-NPN | SOT-89-776 | KTD1624 | Q25 | TRANS-NPN | SOT-23-776 | SC3265 | Q26 | TRANS-NPN | SOT-23-776 | SC3265 | Q27 | TRANS-NPN | SOT-23-776 | SC3265 | Q28 | TRANS-NPN | SOT-23-776 | SC3265 | Q29 | TRANS-NPN | SOT-23-776 | SC3265 | Q35 | TRANS-NPN | SOT-23 | 2N3904 | Q36 | 2N3904S | SOT-23-776 | 2N3904 | Q43 | TRANS-NPN | SOT-23 | 2N3904 | Q70 | KRC402 | USM | KRC402 | RESET | TP | TP-1.0 | T(L) | REVERSE | TP | TP-1.0 | RL- | RF1 | TP | TESTP-1.0 | | RL+ | TEST_POINT_1 | TESTP-1.0 | TP | RL- | TEST_POINT_1 | TESTP-1.0 | TP | RR+ | TEST_POINT_1 | TESTP-1.0 | TP | RR- | TEST_POINT_1 | TESTP-1.0 | TP | S_1V8 | TP | TP-R2.0 | T(L) | S_3V3 | TP | TP-R2.0 | T(L) | TC3 | ECAP | ECAP-DIP-8.0 | 1000UF/6.3V ESR | TC4 | ECAP | ECAP-DIP-5.0 | 47UF/6.3V/ | TC5 | ECAP | ECAP-DIP-5.0 | 47UF/6.3V/ | TC8 | CAP-E | ECAP-SMT-6.5 | 220uF/16V | TC10 | T-CAP | ECAP-DIP-5.0 | 100uF/6V3 | TC19 | ECAP | ECAP-DIP-5.0 | 47UF/6.3V/ | TC53 | CAP-E | ECAP-SMT-6.5 | 220uF/16V | TC57 | ECAP | ECAP-DIP-6.5 | 100uF/16V | TC58 | ECAP | ECAP-DIP-6.5 | 100uF/16V | TP2 | TP | TP-1.0 | | TP6 | TP | TESTP-1.0 | | TP10 | TP | TESTP-1.0 | | TP15 | TP | TP-1.0 | RL- | TP24 | TP | TP-1.0 | RL- | TP25 | TP | TP-1.0 | RL- | TP30 | TP | TP-1.0 | RL- | TP179 | TP | TP-1.0 | RL- | TP181 | TP | TP-1.0 | RL- | TV1 | TVTUN | TCPN9081 | TNJ3321PF | U1 | LB1641 | SIP-10P | | U2 | TDA7386 | FLEXWATT25 | TDA7388 | U3 | BA3121F | SOP-8 | 4558 | U5 | TDA7719 | TDA7719_TSSOP28_H1M2 | TDA7719 | U7 | RT9164 | TO-252 | LD1117-3.3(S0T-252) | U10 | RT9164 | SOT-223 | LD1117-1.8(S0T-223) | U12 | V9_9_1.0 | QFP-128-XE | ZR36970 | U14 | CS4344 | TSSOP10 | | U20 | BA5954FP | HSOP28 | BA5954 | U24 | NAT24C01A-10SC | SO8NB | 24C16-S | U26 | FMS6502 | TSSOP-24 | FMS6502 | U28 | 4558 | SOP8 | 4558 | U100 | 24C01A_0 | ATMELSOP_8 | SPI FLASH-SOP8 | U301 | HY57V641620HG_7 | TSOP-54 | 64Mbit: K4S161622C-TC/L70
/W9864G6GH-6 /IC42S16400F-7TL | U501 | LB1641 | SIP-10P | | VR1 | VR | CAP-0603 | 200PF/5V5 | VR3 | VR | CAP-0603 | 200PF/5V5 | VR9 | VR | CAP-0603 | 5PF/18V | X1 | XTAL | HC49US-SMT | 27MHz/ê¥ìì/27PF | X5 | TCXO-C-16M-HC-49S/SMD-AA | HC-49US-SMT | | Y1 | XTAL | HC49US-SMT | 4MHz | ZD1 | 1N6263 | SOD-323-776 | 5.1V | ZD2 | 1N6263 | SOD-323-776 | | ZD3 | 1N6263 | SOD-323-776 | 18V | ZD4 | 1N6263 | SOD-323-776 | 5V1 | ZD5 | FTZ5.6E | TVS | | ZD6 | FTZ5.6E | TVS | | ZD9 | FTZ5.6E | TVS | | ZD10 | 1N6263 | SOD-323-776 | 5V1 | ZD11 | 1N6263 | SOD-323-776 | | ZD21 | ZDIODE | SOD-323-776 | 10V |
