重要提示:PCB作品文件展下载说明
Name | Part Type | PCB Decal | Value | CN1 | 2SJ-05101N13_0 | 2SJ-05101N13 | 2SJ-05101NC3 | CN2 | 2SJ-05101N13_0 | 2SJ-05101N13 | 2SJ-05101NC3 | CNF2 | FI-RE41S-HF_1 | FIRE-41MR-0.5 | WF23-400-413C | D1 | DIODE_SCHOTTKY | D-D3A | IN5819 | D2 | DIODE_SCHOTTKY | D-D3A | IN5819 | D10 | BAT54CW-F | SOT23 | BAT54CW-F | D11 | BAT54CW-F | SOT23 | BAT54CW-F | D12 | ZC2800E/SOT_2 | ZD0805 | UDZ5.6B | D13 | ZC2800E/SOT_2 | ZD0805 | UDZ5.6B | D14 | ZC2800E/SOT_2 | ZD0805 | NC/UDZ5.6B | D15 | ZC2800E/SOT_2 | ZD0805 | NC/UDZ5.6B | D16 | ZC2800E/SOT_2 | ZD0805 | UDZ5.6B | D17 | 24C08_1 | SOT23-6_ | AZC199-04S | D18 | ZC2800E/SOT_2 | ZD0805 | UDZ5.6B | D19 | 24C08_1 | SOT23-6_ | AZC199-04S | D20 | BAT54CW-F | SOT23 | BAT54CW-F | D21 | BAT54CW-F | SOT23 | BAT54CW-F | D22 | BAT54CW-F | SOT23 | NC/BAT54CW-F | D23 | BAT54CW-F | SOT23 | NC/BAT54CW-F | D38 | ZC2800E/SOT_3 | ZD0805 | UDZ5.6B | D39 | ZC2800E/SOT_4 | ZD0805 | UDZ5.6B | D40 | ZC2800E/SOT_2 | ZD0805 | UDZ5.6B | D41 | ZC2800E/SOT_3 | ZD0805 | UDZ5.6B | D42 | ZC2800E/SOT_3 | ZD0805 | UDZ5.6B | D43 | BAT54CW-F | SOT23 | BAT54CW-F | D44 | ZC2800E/SOT_2 | ZD0805 | NC/UDZ5.6B | D45 | BAS70-04/SOT | BAV99-SOT23 | BAV99 | D46 | BAS70-04/SOT | BAV99-SOT23 | BAV99 | D47 | BAS70-04/SOT | BAV99-SOT23 | BAV99 | D48 | DIODE_1 | SOD323 | 1N4148WS | D49 | DIODE_SCHOTTKY | D-D3A | IN5819 | D501 | BAT54CW-F | SOT23 | BAT54CW-F | D502 | 24C08_0 | SOT23-6_ | AZC199-04S | DP1 | DISPLAY_PORT_1 | DISPLAYPORT_P20 | DISPLAY_PORT-CON | DP2 | DISPLAY_PORT_2 | DISPLAYPORT_P20 | DISPLAY_PORT-CON | DP_1 | DISPLAY_PORT_4 | MINI_DISPLAYPORT_P20 | Mini_DISPLAY_PORT-CON | F1 | FUSE | FUSE1812 | NC/FUSE(5A) | F2 | FUSE | FUSE1812 | FUSE(5A) | F3 | FUSE | _FUSE1812 | FUSE(1A)_1206 | F4 | FUSE | _FUSE1812 | FUSE(1A)_1206 | F5 | FUSE | _FUSE1812 | FUSE(1A)_1206 | HDMI2 | CON34_3 | HDMI-19 | HDMI-CON | HDMI3 | CON34_3 | HDMI-19 | HDMI-CON | J1 | PLUG_DC_FEMALE_1 | PWR-JK-3P | NC\DC_FEMALE | J2 | PLUG_DC_FEMALE_0 | PWR-JK-3P | DC_FEMALE | JN1 | HEADER_30_0 | 2X17P200CHL | 34P-2X17 | JN2 | CON_0 | 2X20P200CHL_SKYWORTH | 40P-2X20 | JN3 | HEADER_30_0 | 2X17P200CHL | 34P-2X17 | JN4 | CON_0 | 2X20P200CHL_SKYWORTH | 40P-2X20 | JP1 | HEADER_9/SM_0 | 9P200CHR | HEADER 9/SM | JP2 | HEADER_4 | 4P200CHL | HEADER 4 | JP3 | HEADER_6_7 | JP6-200L | (2.0MM V.T/90 degree) | JP4 | HEADER_6_5 | SIP2/P2.54 | (2.54MM V.T) | JP5 | HEADER_6_6 | SIP2/P2.54 | (2.54MM V.T) | JP6 | CON34_4 | DVI30P2 | DVI-CON | L1 | INDUCTOR_IRON | L1206 | FEB_1206 | L2 | INDUCTOR_IRON | L1206 | FEB_1206 | L3 | INDUCTOR_2 | GSPC0603 | 4.7u/2.8A | L4 | INDUCTOR_IRON | L1206 | FEB_1206 | L5 | INDUCTOR_2 | GSPC0603 | 4.7u/2.8A | L6 | INDUCTOR_3 | CRH127 | 33UH/SMD | L7 | INDUCTOR_IRON | L1206 | FEB_1206 | L8 | INDUCTOR_IRON | L1206 | FEB_1206 | L9 | INDUCTOR_IRON | L1206 | FEB_1206 | L10 | INDUCTOR_2 | GSPC0603 | 4.7u/2.8A | L11 | INDUCTOR_3 | CRH127 | 33UH/SMD | L66 | INDUCTOR | L1206 | Bead_1206_80ohm_2A | L67 | INDUCTOR | L1206 | NC/Bead_1206_80ohm_2A | L68 | INDUCTOR_3 | CRH127 | 33UH/SMD | LW3 | L | L0805 | BEAD/60R/0805 | LW4 | L | L0805 | BEAD/60R/0805 | LW5 | L | L0805 | BEAD/60R/0805 | PW5V_1 | CON3_5 | SIP2/P2.54 | CON2 | PW5V_2 | CON3_5 | SIP2/P2.54 | CON2 | PW10V | CON3_5 | SIP2/P2.54 | CON2 | PW12V | CON3_5 | SIP2/P2.54 | CON2 | PW12V_1 | CON3_5 | SIP2/P2.54 | CON2 | PW12V_2 | CON3_5 | SIP2/P2.54 | CON2 | PW_DDR1 | 100301/LCC_0 | SIP3/P2.54 | OLED_Panel | PW_DDR2 | 100301/LCC_0 | SIP3/P2.54 | OLED_Panel | Q1 | MOSFET_P_GSD_2 | SOT23-GDS-132 | NC/AO3401 | Q2 | NPN/SOT23_1 | SOT23-BCE-132 | 2N3904 | Q3 | NPN/SOT23_1 | SOT23-BCE-132 | 2N3904 | Q4 | Q2N3508_0 | SOT23-BCE-132 | 2N3904 | Q5 | 2421_3 | SO8 | NDS9435A | Q6 | Q2N3508_1 | SOT23-BCE-132 | 2N3904 | Q7 | MOSFET_P_GSD_2 | SOT23-GDS-132 | AO3401 | Q8 | NPN/SOT23_1 | SOT23-BCE-132 | 2N3904 | Q9 | NPN/SOT23_1 | SOT23-BCE-132 | 2N3904 | Q13 | NPN/SOT23_1 | SOT23-BCE-132 | 2N3904 | Q14 | NPN/SOT23_1 | SOT23-BCE-132 | 2N3904 | Q15 | MOSFET_P_GSD_2 | SOT23-GDS-132 | AO3401 | Q16 | NPN_3 | SOT23 | PMBT3904 | Q17 | MOSFET_P_GSD_2 | SOT23-GDS-132 | AO3401 | Q18 | NPN_3 | SOT23 | PMBT3904 | Q19 | MOSFET_P_GSD_2 | SOT23-GDS-132 | AO3401 | Q20 | MOSFET_P_GSD_2 | SOT23-GDS-132 | AO3401 | Q21 | NPN_3 | SOT23 | PMBT3904 | Q22 | MOSFET_P_GSD_2 | SOT23-GDS-132 | NC/AO3401 | Q23 | MOSFET_P_GSD_2 | SOT23-GDS-132 | NC/AO3401 | Q24 | PNP_0 | SOT23 | SST3906F | Q25 | NPN_3 | SOT23 | PMBT3904 | Q26 | PNP_0 | SOT23 | SST3906F | Q27 | NPN_3 | SOT23 | PMBT3904 | Q34 | NPN_3 | SOT23 | PMBT3904 | U1 | MP28259DD_0 | TSOT23-8 | MP1497DJ | U2 | MP28259DD_0 | TSOT23-8 | MP1497DJ | U3 | HPR103/SO_0 | TO-263AB-5P | 5256 | U4 | LT1086_1 | TO-263-GOI-123 | AIC1084-CM | U5 | MP28259DD_0 | TSOT23-8 | MP1497DJ | U6 | HPR103/SO_2 | TO-263AB-5P | 5256 | U7 | LT1086 | SOT223-GOI-123 | 1117/3.3V | U8 | HPR103/SO_0 | TO-263AB-5P | NC/APE1705S | U9 | VGA_CON15_0 | 15P229-2F | VGA_CON15 | U10 | CS4334_2 | RT9026_MSOP-10 | RT9026 | U11 | RTD2796 | BGA1024_P0_8_27X27 | BGA_32X32 | U12 | ALC206_LONG_1 | QFN_24PIN | ALC122 | U13 | X24C04_0 | SO08 | X24C16 (SMD) | U14 | SN74LVC1G125DBVR/SOT23-5_0 | SOT23-5 | NC/SN74LVC1G125DBVR/SOT23-5 | U15 | FM-3238TM2-5CN/DIP_0 | SIP3/P2.54 | NC/FM-3238TM2-5CN | U16 | SOIC8/P1.27/7_0.98 | SOIC8/P1.27/6 | SFLASH | U19 | LT1086_0 | SOT223-GOI-123 | 1117/3.3V | UD3 | DDR2_9 | DDR3 | DDR3 | UD4 | DDR2_9 | DDR3 | DDR3 | UDDC2 | 2421_1 | SO08 | 24C02 | UDDC3 | 2421_1 | SO08 | 24C02 | UDDC6 | 2421_0 | SO08 | 24C02 | UDDC501 | 2421_0 | SO08 | AT24C02 | UOCP2 | 2421_0_2 | SOT-23-5 | AIC6163 | UOCP3 | 2421_0_2 | SOT-23-5 | AIC6163 | UX504 | CS4334_0 | MSOP10_P0_5_2_6X1_1 | RClamp0524P | Y3 | CRYSTAL_1 | XTAL-H | 14.318MHz | _ | R_6 | R0402 | NC/100K |
重要提示:PCB作品文件展下载说明
