[Pads_VX.2x] MediaTek MT6757 (Helio P20) 原理图和参考设计
查看9608 | 回复19 | 2017-1-11 09:34:46 | 显示全部楼层 |阅读模式
NamePart TypePCB DecalValue
ANT3705SPR_/_1_/_QM-40G_2ANT/SMD/QM-40GSPR / 1 / QM-40G
ANT3706SPR_/_1_/_QM-40G_2ANT/SMD/QM-40GSPR / 1 / QM-40G
ANT3707SPR_/_1_/_QM-40G_2ANT/SMD/QM-40GSPR / 1 / QM-40G
ANT3708SPR_/_1_/_QM-40G_2ANT/SMD/QM-40GSPR / 1 / QM-40G
ANT3709SPR_/_1_/_QM-40G_2ANT/SMD/QM-40GSPR / 1 / QM-40G
ANT3710SPR_/_1_/_QM-40G_2ANT/SMD/QM-40GSPR / 1 / QM-40G
ANT5001SPR_/_ANT-SPRING_3X1SPR/ANT-SPRING-3X1SPR / ANT-SPRING_3x1
ANT5101SPR_/_CSS5301-6800FANT/1P/SMD/CSS5301-6301F/SMK/RANDENSPR / CSS5301-6800F
ANT5102SPR_/_CSS5301-6800FANT/1P/SMD/CSS5301-6301F/SMK/RANDENSPR / CSS5301-6800F
CON2101CON_/_6_/_CPL6506-0130ESZBAT/6P/SMD/P1.2/CPL6506-0130ESZ/SMKCON / 6 / CPL6506-0130ESZ
CON2301CON_/_10_/_AXE510127CON5X2/SMD/P0.4/F/AXE510127CON / 10 / AXE510127
CON3301CAR_KIT_/_MM8130-2600_2MM8130-2602Car_Kit / MM8130-2600
CON3302CAR_KIT_/_MM8130-2600_2MM8130-2602Car_Kit / MM8130-2600
CON3401TST_PORT_0MM8130-2602Car_Kit / MM8130-2600
CON3402TST_PORT_0MM8130-2602Car_Kit / MM8130-2600
CON3702CON_/_MM5829-2700RJ4COAXIAL/SMD/MM5829-2700BCON / MM5829-2700RJ4
CON3703CON_/_MM5829-2700RJ4COAXIAL/SMD/MM5829-2700BCON / MM5829-2700RJ4
CON4001CON_/_12_/_TA-M017-012-07-811MICROSD/8P/SMD/TA-M017-012-07-811CON / 12 / TA-M017-012-07-811
CON5002TST_PORT_0MM8130-2602Car_Kit / MM8130-2600
CON6001CON_/_5_/_EJ-36952-10-GPAUDIOJACK/5P/DIP/EJ-36952-10-GPCON / 5 / EJ-36952-10-GP
CON6002CON_/_16_/_24-5804-016-000-829+CON8X2/SMD/F/P0.4/24-5804-016-000-829CON / 16 / 24-5804-016-000-829+
CON6101CON_/_10_/_AXE510127_2CON5X2/SMD/P0.4/F/AXE510127CON / 10 / AXE510127
CON6102CON/DSI-4L/24-5804-034-000-829+CON17X2/SMD/F/P0.4/24-5804-034-000-829CON / 34 / 24-5804-034-000-829+
CON6201CON_/_30_/_24-5804-030-000-829+CAMERA_MODULE/30P/SMD/CM9156-B1300BA-ECON / 30 / 24-5804-030-000-829+
CON6202CON_/_30_/_AXT530124CAMERA_MODULE/30P/SMD/Q5V22K-0JGCON / 30 / AXT530124
CON6301CON_/_10_/_AXE510127_2CON5X2/SMD/P0.4/F/AXE510127CON / 10 / AXE510127
CON6401CON_/_5_/_KEIRAKU_KIU90511S1RMICROUSB/5P/SMD/P0.65/R/KIU90511S1RCON / 5 / KEIRAKU KIU90511S1R
CON6501CON_/_10_/_SCGD1B0314SIM/10P/SMD/SCGD1B0307CON / 10 / SCGD1B0314
CON6502CON_/_10_/_SCGD1B0314SIM/10P/SMD/SCGD1B0307CON / 10 / SCGD1B0314
CON6503CON_/_10_/_AXE510127_2CON5X2/SMD/P0.4/F/AXE510127CON / 10 / AXE510127
CON6601VIB_/_3_/_Z3OC1T8219731VIBRATOR/3P/SMD/Z30C1T8219731VIB / 3 / Z3OC1T8219731
D2107LED_/_AK2M1BYLED/SMD/27-21-S2C-AK2M1BY-3CLED / AK2M1BY / NC
D2301D_/_RB160M-60RB160M-30-EVBD / RB160M-60
D6301LED_/_IR83-01C-L491-TR8LED/SMD/IR83-01CLED / IR83-01C-L491-TR8
D6401ESD_/_AZ4514-01FDFN1610P2E/SMD/AZ4514-01FESD / AZ4514-01F
MIC6002MIC_/_SPH0642HT5H-1MODULE/SMD/SPH0642HT5H-1MIC / SPH0642HT5H-1
NTC3101NTC_/_NCP03WF104F05RL_/_0201R0201NTC / NCP03WF104F05RL / 0201 / NC
NTC3201NTC_/_NTCG064EF104F_/_0201R0201NTC / NTCG064EF104F / 0201
NTC6301NTC_/_NTCG104EF104F_/_0402R0402NTC / NTCG104EF104F / 0402
PL2001PL_/_2.2_/_UH_/_2520L/IND/SMD/2520PL / 2.2 / uH / 2520
PL2101PL_/_1_/_UH_/_2520L/IND/SMD/DFE252012F/TOKOPL / 1 / uH / 2520
PL2205PL_/_0.33_/_UH_/_2520L/IND/SMD/2520PL / 0.33 / uH / 2520
PL2208PL_/_0.33_/_UH_/_2520L/IND/SMD/2520PL / 0.33 / uH / 2520
PL2303PL_/_4.7_/_UH_/_2016L/IND/SMD/VLS201610EPL / 4.7 / uH / 2016
PL2304PL_/_4.7_/_UH_/_2016L/IND/SMD/VLS201610EPL / 4.7 / uH / 2016
PL2305PL_/_1_/_UH_/_2520L/IND/SMD/MEMK2520PL / 1 / uH / 2520
PL2401PL_/_0.33_/_UH_/_2016L/IND/SMD/VLS201610EPL / 0.33 / uH / 2016 / NC
PL5001INDUCTOR_0L/IND/SMD/2520PL / VLS2520MNT-2R2N
PL6701PL_/_1_/_UH_/_2520_2L/IND/SMD/MAMK2520PL / 1 / uH / 2520
Q6302Q_/_RUM003N02GT2LVMT3/SMD/RUM003N02Q / RUM003N02GT2L
REC6001REC_/_2403_260_00031__2RECEIVER/SMD/2403-260-00087/KNOWLESREC / 2403 260 00087 / NC
SH1034R_/_0_/_OHM_/_0402_1NC0603R / 0 / ohm / 0603 / NC
SH2002NO_PAD_0402_SMD_1NC/MMD/L2/4MIL_SHORT / NC-MMD-L1-4MIL
SH2004NO_PAD_0402_SMD_1NC/RSHORT / 0402
SH2100NO_PAD_0402_SMD_1NC/MMD/L1/4MILSHORT / NC-MMD-L9-4MIL
SH2103R_/_0_/_OHM_/_0402_1NC0603NC/MMD/60MIL
SH2104R_/_0_/_OHM_/_0402_1NC0603NC/MMD/60MIL
SH2301R_/_0_/_OHM_/_0402_1NC0603NC/MMD/60MIL
SH4102NO_PAD_0402_SMD_1NC/MMD/L1/4MILSHORT / NC-MMD-L5-4MIL
SH4105R_/_0_/_OHM_/_0402_1NC0603R / 0 / ohm / 0402 / NC
SH5012NO_PAD_0402_SMD_1NC/4MILSHORT / NC-MMD-L7-4MIL
SW6500SW_/_4_/_SKSMAFE010KEYPAD/4P/SMD/SKSMAFE010SW / 4 / SKSMAFE010
TCXO5001TCXO_RAKON_SMD_4PTCXO/SMD/2.5X2.0/IT2205BETCXO / 26 / MHz / IT2205AE
U1001U_/_IC-MT6757-E1-SBSMT6757/VFBGA771/P0.4/B0.25/13X13.4U / MT6757V / CAMD-E-H
U2001U_/_MT6351DV/AHDD-HMT6351/VFBGA199/P0.4/B0.25/7X7U / MT6351DV/AHDD-H
U2101U_/_RT9466WQFNQFN24/SMD/P0.5/BQ25896U / RT9466WQFN
U2201U_/_MT6311DP/AED-HMT6311/WLCSP30/P0.4/B0.25/2.655X2.255U / MT6311DP/AED-H
U2304U_/_RT4801A-50WSCWLCSP15/P0.4/B0.25/RT4801AU / RT4801A-50WSC
U2305U_/_RT4531WSCWLCSP9/P0.4/B0.25/RT4531U / RT4531WSC
U2307U_/_RT9055-MMWSCWLCSP6/P0.4/B0.25/RT9055U / RT9055-MMWSC
U2308U_/_LM3643YFFRDSBGA12/P0.4/B0.25/LM3643U / LM3643YFFR
U2401U_/_FAN53526UC128XWLCSP15/P0.4/B0.2/FAN53526U / FAN53526UC128X / NC
U3101U_/_MT6176-MPMT6176/VFBGA196/P0.4/B0.25/6.2X6.2U / MT6176-MP
U3102VTCXO_/_KT2520K26000ZAW23ZMSTCXO/SMD/2.5X2.0/KT2520FVTCXO / KT2520K26000ZAW23ZMS / NC
U3201PA_/_SKY77651-11-MPRF5427/24P/SMD/4X2.8Ph3_L_PA_1
U3202PA_/_SKY77652-11-MPRF5426/28P/SMD/4X3.64Ph3_HM_PA_1
U3203LPF_/_DEA102025LT-6326B1MTFILTER/6P/SMD/1005LPF/TDKLPF / DEA102025LT-6326B1MT
U3204SAW_/_885049FILTER/SMD/885049
U3205SAW_/_F6HP2G593AP20SAW/8P/SMD/D6HN2G655BN56SAW / F6HP2G593AP20
U3206LPF_/_DEA102690LT-6328B1MTFILTER/6P/SMD/1005LPF/TDKLPF / DEA102690LT-6328B1MT
U3301LPF_/_DEA100960LT-6335B1MTFILTER/6P/SMD/1005LPF/TDKLPF / DEA100960LT-6335B1MT
U3302TXM_/_SKY77928-11-MPSKY7792XTXM / SKY77928-11-MP
U3303DPX_/_SAYEY897MBA0B0ASAW/8P/SMD/SAYEY1G95GA0F0ADPX / SAYEY897MBA0B0A
U3304DPX_/_SAYEY831MBA0B0ASAW/8P/SMD/SAYEY1G95GA0F0ADPX / SAYEY831MBA0B0A
U3305QPX_/_SAHRT1G74BA0B0AQUADPLEXER/14P/SMD/SAHRT1G74BA0B0AQPX / SAHRT1G74BA0B0A
U3306DPX_/_SAYEY806MBA0F0ASAW/8P/SMD/SAYEY1G95GA0F0ADPX / SAYEY806MBA0F0A
U3307DPX_/_SAYEY2G53BC0F0ASAW/8P/SMD/SAYEY1G95GA0F0ADPX / SAYEY2G53BC0F0A
U3308QPX_/_SAHRT1G73BA0B0AQUADPLEXER/14P/SMD/SAHRT1G74BA0B0AQPX / SAHRT1G73BA0B0A
U3309DPX_/_SAYEY733MBC0F0ASAW/8P/SMD/SAYEY1G95GA0F0ADPX / SAYEY733MBC0F0A
U3310DPX_/_SAYEY718MBC0F0ASAW/8P/SMD/SAYEY1G95GA0F0ADPX / SAYEY718MBC0F0A
U3311SAW_/_SAWFD1G90KE0F0ASAWFILTER/10P/SMD/B9923SAW / SAWFD1G90KE0F0A
U3401DIPX_/_DPX162700DT-8158C1MTDIPLEXER/6P/SMD/P0.57/DPX162700DT
U3402SAW_/_SAFRG2G59MA0F0AACPF-7141/SMD
U3403SAW_/_SAWFD1G84AA0F0ASAWFILTER/10P/SMD/SAWFD1G84AA0F0ASAW / SAWFD1G84AA0F0A
U3404SAW_/_SAFFB942MAN0F0ASAWFILTER/5P/SMD/SAFFB2G14AA0F0ASAW / SAFFB942MAN0F0A
U3405DP12T_/_SKY13552-669LF-MPSKY13552Ph3_DP12T_ASM_1
U3406SAW_/_SAFFB2G35AA0F0ASAWFILTER/5P/SMD/SAFFB2G14AA0F0ASAW / SAFFB2G35AA0F0A
U3407SAW_/_SAFFB876MAA0F0ASAWFILTER/5P/SMD/SAFFB2G14AA0F0ASAW / SAFFB876MAA0F0A
U3408SAW_/_SAWFD1G96AQ1F0ASAWFILTER/10P/SMD/SAWFD1G84AA0F0ASAW / SAWFD1G96AQ1F0A
U3409SAW_/_SAFFB2G65AA0F0ASAWFILTER/5P/SMD/SAFFB2G14AA0F0ASAW / SAFFB2G65AA0F0A
U3410SP3T_/_SKY13582-676LF-MPSKY13582SP3T / RF1648
U3411SAW_/_SAFFB1G90KA0F0ASAWFILTER/5P/SMD/SAFFB2G14AA0F0ASAW / SAFFB1G90KA0F0A
U3412SAW_/_SAFFB806MAA0F0ASAWFILTER/5P/SMD/SAFFB2G14AA0F0ASAW / SAFFB806MAA0F0A
U3413SAW_/_SAFFB773MAA0F0ASAWFILTER/5P/SMD/SAFFB2G14AA0F0A
U3414SAW_/_SAFFB788MAA0F0ASAWFILTER/5P/SMD/SAFFB2G14AA0F0ASAW / SAFFB788MAA0F0A
U4101LP_DDR2(JEDEC_162B)_0FBGA221/P0.5/B0.27/11.5X13/HYNIXU / H9TQ26ADFTACUR-KUM / FBGA221
U5001MT6630_WLCSP_0MT6630/WLCSP113/P0.4/B0.25/5.013X5.013U / MT6630-WLCSP
U5002TRIQUINT_1FILTER/SMD/885033BPF / ACPF-7124 / Avago
U5003BL1608-05K2450BALUN/SMD/BL1608/ACXBAL / BL1608-05K2450
U5004MURATA_LFD211G57ME3FILTER/SMD/LFD211G57ME3TRPX / TPX205950MT-7010A1 / TDK
U5005SAFEB1G57KA0F00SAW/SMD/1.05X1.35BPF / B8313 / EPCOS
U5006NJG1107HB3_0TSLP6/SMD/P0.4/BGA725L6/SU / BGA725L6
U5101U_/_MT6605EN_/_BDC-LMT6605/MQFN32/SMD/P0.4/4X4/SU / MT6605EN / BDC-L
U6208U_/_RT9055-GJWSCWLCSP6/P0.4/B0.25/RT9055U / RT9055-GJWSC
U6301U_/_AK09911CWLCSP8/SMD/P0.4/B0.25/AK09911U / AK09911C
U6302U_/_LSM6DS3HLGA14/SMD/P0.5/LSM6DS3U / LSM6DS3H
U6304U_/_BMP280LGA8/SMD/P0.65/BMP280U / BMP280 / NC
U6701U_/_RT5509WLCSP48/P0.4/SMD/RT5509/RICHTEKU / RT5509
X2001X_/_32_/_KHZ_/_TFX-02SCRYS/SMD/3.2X1.5/9H032000XX/TXCX / 32 / KHz / TFX-02S
X2002TSX_/_CT2520DB26000C0FZZA1CRYS/SMD/2.5X2.0/CT2520DB/KYOCERATSX / CT2520DB26000C0FZZA1
X5101X_/_FA-128CRYS/SMD/FA-128X / FA-128
购买主题 本主题需向作者支付 10 枚金币 才能浏览
重要提示:PCB作品文件展下载说明
第九天的雪 | 2017-1-11 09:49:01 | 显示全部楼层
fanqiong1234ok | 2017-1-11 12:46:04 | 显示全部楼层
wonengxing2015 | 2017-1-16 18:29:38 | 显示全部楼层
james_zhangwk | 2017-1-17 10:00:07 | 显示全部楼层
leopard | 2017-3-16 20:51:24 | 显示全部楼层
zh9402 | 2017-11-6 11:33:02 | 显示全部楼层
wupeng0618 | 2019-6-17 17:23:37 | 显示全部楼层
好东西,真的是好东西
黄james | 2019-10-5 03:31:49 | 显示全部楼层
cityhu | 2019-10-5 09:03:02 | 显示全部楼层
