重要提示:PCB作品文件展下载说明
请输入描述
Name | Part Type | PCB Decal | Value | DU16 | LM7805CT_5_2 | TO-252 | AIC1085CE | FU1 | FUSE | SMR1206 | 1812L260 | H9 | HEADER_3_0 | CON-5P\2.0 | PH2.0X2.0 | H12 | HEADER_3_1 | CON-5P\2.0 | PH2.0X2.0 | J1 | HEADER_30_0_2 | ZIFF30L-0.5MM | ZIFF30-0.5MM-UP | J2 | HEADER_5X2 | CON-SQT-2X5-2.0 | HEADER5X2 | J3 | CONN_PCB_2 | SM034.0B | SM03(4.0)B-BHS-1-TB | J4 | HEADER_4_1 | ZIFF4-1.0-L | FPC1.0S-6S-4PWB-UP | J5 | HEADER_4_0 | CON3P-2.54 | CON3P-2.54(NC) | J6 | CONN_SOCKET_48_0 | CON-48P\DIN41612 | CONNSOCKET16X3 | J7 | HEADER_5X2_2 | CON-10P\2X5\2.54 | HEADER5X2-2.54-FEMALE(NC) | L1 | INDUCTOR_2 | L-0805 | BEAD-0805 | L2 | INDUCTOR_2 | L-0805 | BEAD-0805(NC) | L3 | XC6383A501PR_2 | L/5.5UH | K5S-4.8UH+->12%(3L) | L4 | INDUCTOR_2 | L-0805 | BEAD-0805 | L5 | INDUCTOR_2 | L-0805 | BEAD-0805 | L6 | INDUCTOR_2 | L-0805 | BEAD-0805 | L7 | CAP_NP | SMC0603 | 1UF-1206 | L8 | INDUCTOR_2 | L-SMTDRS0732 | 10UH-1.5A/SMTDRS0732-100M | L9 | INDUCTOR_2 | SMR0805 | 0-0805 | L10 | INDUCTOR_2 | L-0805 | 47UH-0805/SMI-201212-470K | L11 | INDUCTOR_2 | L-0805 | SMD-322522-151K | PD1 | DIODE_SCHOTTKY_1 | D-SMT5819 | 1N5819-SMT | PD2 | DIODE_0_2 | 1N4148-SMT | 1N4148-SMT | PD3 | DIODE_SCHOTTKY_1 | D-SMT5819 | 1N5819-SMT | PD4 | DIODE_0_2 | 1N4148-SMT | 1N4148-SMT | PL1 | INDUCTOR_2 | L-SMTDRRI0402 | 22UH/SMTDRRI0402-220M | PL2 | INDUCTOR | L1206 | BEAD-1206 | PL3 | INDUCTOR_2 | L-SMTDRRI0402 | 47-2010 | PL4 | INDUCTOR | L1206 | BEAD-1206 | PU1 | LT1940 | IC-LT1940 | LT1940 | Q1 | NPN_0_2 | 2N3904 | 2N3904-SMT | Q2 | XC62AP5002PR_4 | AIC1720-33CX | AIC1721D-33CX(NC) | Q3 | NPN_0_2 | 2N3904 | 2N3904-SMT | Q4 | LM7805CT_0_2 | SOT223 | LM2936MP-3.3 | Q5 | NPN_0_2 | 2N3904 | 2N3904-SMT | Q7 | XC62AP5002PR_3 | AIC1720-33CX | AIC1721D-33CX | Q8 | NPN_0_2 | 2N3904 | 2N3904-SMT | Q9 | NPN_0_2 | 2N3904 | 2N3904-SMT | SW3 | CON3_0_2 | EN11-2 | EC11P20L13.2F5.2M5V1S | TX1 | TRANSFORMER_POWER_3 | F0512A | F0512A | U1 | 14053_1 | 74HC4053-SOP | 74HC4053-SOP | U2 | QFP-64_0 | PVI-1004/PQFP | PVI-1004D/PQFP | U3 | XC6383A501PR_4 | BU4S81-SOT23 | BU4S81-SOT23 | U4 | ELM9827AA_0 | LM3480IM3-3.3 | LM3480IM3-3.3 | U5 | LM833 | LM8272-MSOP | LM8272-MSOP | U6 | P8 | DIP8\SO-4532 | 4532 | U7 | BIT3105_0 | BIT3107 | BIT3105-SSOP20 | U8 | P8 | DIP8\SO-4532 | 4532 | U9 | PCF8575_SSOP24_0 | AD7843-TSSOP/QSOP | AD7843-TSSOP | U10 | DS1307ZN | DS1307 | DS1307ZN | U11 | MTV230M-PQFP | IC-MTV230 | MTV230M-PQFP | U12 | AN2546FH-A_0 | AN2546FH-A | AN2546FH-A | U14 | 14053_0 | 74HC4053-SOP | 74HC4053-SOP | U15 | LM358N | IC-AD8092AR\SOP8 | AD8092AR | U17 | EPM7032_3 | IC-EPM7032\TQFP44 | EPM7032ATI44-10+soft | U18 | TL2932I | IC-TLC2932 | TLC2932IPWELE | U23 | LM7805CT_0_2 | SOT223 | LM2936MP-3.3 | U24 | 28F800CV_T_0 | SMT-SOP2-56 | E28F128JA-150 | U25 | CAT1161/2_2 | TRTQ144 | 6GV629A70 | U26 | 14053_1 | 74HC4053-SOP | 74HC4053-SOP | VA4 | JUMPER1_0 | | JUMPER1 | VR1 | RESISTOR_VAR_3 | VR-MVR22 | 10K-VR1 | VR2 | RESISTOR_VAR_3 | VR-MVR22 | 10K-VR1 | VR3 | RESISTOR_VAR_3 | VR-MVR22 | 33K-VR1 | X1 | CRYSTAL_0 | 32768KHZ | 32.768KHZ | X2 | 74HC4051_29 | DIP-CRYSTAL | 9.6M crystal | Y1 | CRYSTAL | CRY-02\SMD2 | 11.0592MHZ-1-U3B | Y2 | CRYSTAL_2 | CRY-02\SMD2 | 3.579545MHz-1-U3B | Y3 | CRYSTAL_2 | CRY-02\SMD2 | 4.433619MHz-1-U3B | ZIR1 | HEADER_3 | IRM-3438 | IRM-3438 | ZR1 | R_4 | SMR0603 | 200K-0603 | ZR2 | R_4 | PHOTO | PHOTORESISTER 10lux-3k-12k |
重要提示:PCB作品文件展下载说明
