重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | CON1 | SFPC-40PIN-0.5MM | | CON-SMT-40PIN | CON2 | SCON-2PIN-1.25MM-V | | CON-SMT-2PIN | CON3 | SCON-2PIN-6.5MM | 3-J100-SM02-B0-30 | CON2P-SMD | CON4 | SFPC-40PIN-0.5MM | | CON-SMT-40PIN | CON5 | SCON-4PIN-1.25MM-V | | CON-SMT-4PIN | CON6 | SFPC-60PIN-0.5MM | | CON_SMT_60PIN | CON7 | SFPC-6PIN-0.5MMB | | FPC_6PIN_0.5MM | CON8 | SFPC-50PIN-0.5MM | | CON-SMT-50PIN | CON9 | SFPC-6PIN-0.5MMA | | FPC_6PIN_0.5MM | CON10 | SFPC-4PIN-1.0MM | | FPC4-1.0 | CON15 | SCON-4PIN-1.25MM-V | | CON-SMT-4PIN | CON17 | SCON-2PIN-1.25MM-V | | CON-SMT-2PIN | CON18 | SFPC-20PIN-0.5MM | CON-SMT-20PIN | CON-SMT-20PIN | CON19 | SFPC-20PIN-0.5MMA | CON-SMT-20PIN | CON-SMT-20PIN | CON21 | SFPC-4PIN-1.0MM | | FPC4-1.0 | D36 | SD-SOD106 | 4148 | DIODE | D37 | SD-SOD106 | RB050L-40 | SBD\RB063L | ESD84 | SD-ESD0603 | PJSD05TS | ESD0603 | IC3 | SOT23-6A | AIC1896 | AIC1896 | IC4 | SOT223 | LD117-3.3V | LD117 | J1 | JUMP-PAD2.0 | | R-JUMP | J2 | JUMP-PAD2.0 | | R-JUMP | L1 | SL0805 | BEAD/600 | L | L6 | SFB0805 | 120R 0805 | FB | L50 | SPL040418 | 22UH CDH3B16B | L | L51 | SL0805 | 600R | L | L52 | SL0805 | FB600 | FB | L53 | SL0805 | FB600 | FB | L54 | SPL050502 | 4.7uH/CDH4B28 | IND-22UH-CDH4B28 | L55 | SPL0302 | 10uH | INDUCTANCE | L56 | SL0805 | BEAD/600 | L | L57 | SL0805 | BEAD/600 | L | L59 | SL0805 | 100uH | L | L60 | SL0805 | 100uH | L | LED-2 | TP-1.5 | TP | TP | Q4 | SOT23-B | KRC402 | TRANS-PNP-EP | Q10 | SOT89 | 2SC4375 | TRANS-NPN | Q33 | SOT23-A | IRLML6402 | MOSFET | Q44 | SOT89 | 2SC4375 | TRANS-NPN | Q45 | SOT89 | 2SB1132 | TRANS-PNP | Q47 | SOT23-A | 2N3904S | TRANS_1 | Q48 | SOT23-A | 2N3904S | TRANS_1 | Q49 | SOT23-A | | MOSFET | T5V | TESTP-1.0-A | T_+5V | TESTPOINT-1 | TC14 | SC1206 | 22uF/6V3 | C | TC15 | SC1206 | 22uF/6V3 | C | TC17 | SEC5.0 | 47uF/16V | ECAP | TC19 | SEC5.0 | 47uF/16V | ECAP | TP29 | TESTP-1.0-A | TEST POINT SMD0.6 | TEST_POINT_SMD0.6_2 | TP30 | TESTP-1.0-A | TEST POINT SMD0.6 | TEST_POINT_SMD0.6_2 | TP193 | TESTP-1.0-A | TEST POINT SMD0.6 | TEST_POINT_SMD0.6_2 | U25 | SOT23-5A | | MP3302DJ | VDD3V3 | TESTP-1.0-A | T1 | TESTPOINT-1 | VGH(+15V)1 | TESTP-1.5-A | CCFL_EN | TESTPOINT-1 | VGL(-7V)1 | TESTP-1.5-A | CCFL_EN | TESTPOINT-1 | ZD22 | SOT23-A | | SOT23_BAS70_1 | ZD23 | SD-SOD323 | 7v5 | ZDIODE | ZD24 | SOT23-A | | SOT23_BAS70_1 | ZR1 | SOT23-A | TL431 | TL431_1 | ZR2 | SOT23-A | TL431 | TL431_1 |
6.5.7z
(409 KB, 下载次数: 5)
重要提示:PCB作品文件展下载说明
