TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 20875
之前有发过一个跟这个不同的。
板子有以下主要元件
Name | PCB Decal | Value | Part Type | ANT1 | ANT_JACK | NC/ANT | ANT_JACK | ANT2 | ANT2G4_B | N/A | ANT2G4_B | CE1 | CD5.0/2.5 | 100UF/16V | CD5.0/2.5 | CE2 | CD5.0/2.5 | 100UF/16V | CD5.0/2.5 | CN1 | CON5_2.54MM | CON5_2.54MM_DIP | CON5_2.54MM | CN2 | CON4_2.54 | CON4_2.54MM_DIP | CON4_2.54 | CN3 | CON4_2.54 | CON4_2.54MM_DIP | CON4_2.54 | D1 | SOT23 | NC/BAT54C | SOT23 | D2 | SOD123 | NC/1N4148 | SOD123 | D3 | SOD123 | NC/1N5819 | SOD123 | D4 | SOD123 | 1N5819 | SOD123 | D5 | SOT23 | BAT54S | SOT23 | ED1 | E0402N | NC/ESD9B5V | E0402N | ED2 | SOT23 | NC/ESDA6V8UL/AZC199-02S | SOT23 | ED3 | SOT23 | NC/ESDA6V8UL/AZC199-02S | SOT23 | F1 | R0805 | NC | R0805 | FB1 | L0603D | NC/SDCW2012-2-900 | L0603D | FB2 | L0603D | NC/SDCW2012-2-900 | L0603D | H1 | H3.8MM | H3.8MM | H3.8MM | H2 | H3.8MM | H3.8MM | H3.8MM | IR1 | TO92ECB | IRM-3638 | TO92ECB | J1 | DC36-D | DC-208 | DC36-D | J9 | HDMI_DIP | HDMI_A | HDMI_DIP | J10 | AV3-D | AV_CONNECTOR | AV3-D | J11 | XH-2-2_54 | NC/XH-2-2_54 | XH-2-2_54 | J12 | CON4_2.54AAA | NC/CON4_2.54 | CON4_2.54 | J13 | LED-DIP | LED | LED-DIP | J14 | CON_10PIN_1.25 | CON_10PIN_1.25 | CON_10PIN_1.25 | JP1 | RJ45-D | RJ45S | RJ45-D | L1 | IND-3X3 | 2.2UH/1A | IND-3X3 | L2 | IND-4X4 | 1.0UH/2A | IND-4X4 | L3 | IND-4X4 | 1.0UH/2A | IND-4X4 | L4 | IND-3X3 | 2.2UH/1A | IND-3X3 | L5 | L0603 | BLM18PG181SN1 | L0603 | L6 | L0603 | BLM18PG181SN1 | L0603 | L7 | L0603 | NC/1.8UH | L0603 | L9 | R0402 | NC | R0402 | L10 | R0402 | NC | R0402 | L11 | L0603 | BLM18PG181SN1 | L0603 | L12 | L0603 | 1.0UH | L0603 | L52 | L0603 | NC | L0603 | L53 | L0603 | BLM18PG181SN1 | L0603 | Q1 | SOT23 | 8050 | SOT23 | Q2 | SOT23 | 8050 | SOT23 | Q3 | SOT23 | WPM2015/TCS1015 | SOT23 | Q5 | SOT23 | NC/8050 | SOT23 | SW1 | TS-019 | NC/RESET | TS-019 | SW2 | SW4-SKQG-5_2X5_2H1_5B | RECOVER1 | SW4-SKQG-5_2X5_2H1_5B | SW3 | IT-1185S | RECOVER2 | IT-1185S | U1 | BGA316-14X14_0.65 | RK3128 | BGA316-14X14_0.65 | U5 | FBGA96-10X14 | DDR3-128X16BIT | FBGA96-10X14 | U6 | FBGA96-10X14 | DDR3-128X16BIT | FBGA96-10X14 | U7 | SOP8 | NC/ZQ2996 | SOP8 | U8 | ROCKCHIPS | RK_LOGO | ROCKCHIPS | U9 | SOT25 | ETA3486/SY8088AAC | SOT25 | U10 | SOT25 | ETA3409A/TCS4201/SY8089AAAC | SOT25 | U11 | SOT25 | ETA3409A/TCS4201/SY8089AAAC | SOT25 | U12 | SOT25 | ETA3486/SY8088AAC | SOT25 | U13 | SOT25 | PT5108E23E-12/WL2801E-12 | SOT25 | U14 | SOT25 | PT5108E23E-33/WL2801E-33 | SOT25 | U15 | SOT23 | CE8809C263MA | SOT23 | U17 | SOT25 | SY6280AAC/WS4603 | SOT25 | U18 | TSOP1-48 | TSD_FLASH | TSOP1-48 | U19 | TSOP1-48 | NAND_FLASH | TSOP1-48 | U20 | INAND_169_A | EMMC | INAND_169_A | U21 | SLP2510P8 | NC/RCLAMP0524J/ESDA6V8UD | SLP2510P8 | U22 | SLP2510P8 | NC/RCLAMP0524J/ESDA6V8UD | SLP2510P8 | U23 | TSSOP14-0.65MM | TPF632/DRV632PW/DIO2112H | TSSOP14-0.65MM | U24 | QFN40_58 | DP83848J | QFN40_58 | U25 | SOIC16 | HR601680 | SOIC16 | U26 | SOT25 | NC/PT5108E23E-33 | SOT25 | U28 | QFN-44P | RTL8189ETV | QFN-44P | USB1 | USB_B | USBDIP90CE | USB_B | USB2 | USB_B | USBDIP90CE | USB_B | Y1 | CRY-D3225 | 24M-20PPM | CRY-D3225 |
